Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Maximized shell size is bigger, than monitor resolution. Why?
Maximized shell size is bigger, than monitor resolution. Why? [message #543140] Mon, 28 June 2010 10:34 Go to next message
1) run the following code:
final Display display = new Display();
final Shell shell = new Shell(display);
shell.setText("Shell");
shell.setSize(200, 200);
shell.setLayout(new FillLayout());
final Button bt = new Button(shell, SWT.PUSH);
bt.setText("Push");
bt.addSelectionListener(new SelectionAdapter() {
	public void widgetSelected(SelectionEvent arg0) {
		shell.setFullScreen(!shell.getFullScreen());
shell.addControlListener(new ControlAdapter() {
	public void controlResized(final ControlEvent event) {
		System.err.println("shell size = " + shell.getSize());
shell.open();
while (!shell.isDisposed()) {
	if (!display.readAndDispatch())
		display.sleep();
display.dispose();
2) Push the 'Push' button
3) Push the 'Push' button again
4) Push the maximize button on shell frame
5) Push the restore button on the shell frame
This is what I got on Linux with 1600x1200 resolution:
 shell size = Point {200, 200}
 shell size = Point {1600, 1200}
 shell size = Point {196, 203}
 shell size = Point {1601, 1182}
and on Windows XP with 1280x1024 resolution:
 shell size = Point {1286, 1030}
 shell size = Point {1288, 972}
As you can see the size of the shell exceeds the resolution of the monitor.
How is this possible?
Marton
Antw: Maximized shell size is bigger, than monitor resolution. Why? [message #543346 is a reply to message #543140] Tue, 29 June 2010 03:51 Go to previous message
Originally posted by: Ludger.Heisterkamp.gds.eu
Strange behaviour... I can reproduce it exactly on my XP with different SWT
versions.
The getSize() method is working correctly as I could verify it with an
external tool.
I changed getSize() to getBounds() and got his result:
shell bounds = Rectangle {22, 22, 200, 200}
shell bounds = Rectangle {-3, -3, 1286, 1030}
shell bounds = Rectangle {-4, -4, 1288, 979}
It seems that the borders of maximized windows are part of the size and
bounds calculation although they are not visible.
Ludger
>>> Marton Sigmond<marton_sigmond@yahoo.com> schrieb am Montag, 28. Juni
2010
um 16:34:
> bt.setText("Push");
> @Override
> @Override
> shell.open();
> display.sleep();
> display.dispose();2) Push the 'Push' button
> shell size = Point {196, 203}and on Windows XP with 1280x1024
> resolution:
> monitor.
> Marton
Previous Topic:flickering virtual table rows
Next Topic:TitleAreaDialog not correctly displaying long error messages
Current Time: Sat Jul 26 20:36:28 EDT 2025
Powered by FUDForum. Page generated in 0.04669 seconds
