Installing WebTools 3.2.0 through update manager: server adapters [message #542192] |
Thu, 24 June 2010 03:51  |
trying to install WebTools in Helios through update manager, I find a
lot of different packages that confuse me.
For instance, there are:
1) JST Server Adapters 3.2.0.v201005241530-777HFGPCcNBDiBgIc4BA8
2) JST Server Adapters 3.2.0.v201005241530-208Z7w31211419
3) WST Server Adapters 3.2.0.v201005241510-51EoAkF77g8HBSc
What's the difference between 1) and 2)?
What's the difference between JST and WST Server Adapters?
Thanks in advance,
Mauro.
Re: Installing WebTools 3.2.0 through update manager: server adapters [message #542967 is a reply to message #542192] |
Sun, 27 June 2010 23:34  |
Mauro Molinari wrote:
> Hello,
> Thanks in advance,
> Mauro.
They confuse me too ... and I created them :(
We obviously need to improve the names we give these, but basically
you need all three for most normal WTP use. You can tell a little more
if you get "properties" for each, and see its full feature ID (instead
of just names).
The "wst vs. jst" distinction is that wst is for "non java ee" server
adapters, such as HTTPD only servers).
The two JST ones exist because we started work to have one basic,
required set ... and another "extended" set which would have some old,
legacy server adapters in it (which would be optional, but we never did
finish that work ... so I'd recommend getting both, for now, since
getting just the one basic, required set has not really been tested).
FUDForum. Page generated in 0.30341 seconds
