how to modify existing plugin [message #541350] |
Sun, 20 June 2010 07:28  |
could you please give me advice with regards to the following?
I would like to modify an existing plugin, more specifically
the cdo/emf editor plugin org.eclipse.emf.cdo.edit if that
matters.
The plugin in question is already part of my eclipse runtime.
What is the best way to create a "clone", modify it
and use the new version instead of the original one?
I already checked out the source code from the CVS.
I intended to export my plugin-version using
"export -> create deployable plug-ins and fragments",
but the wizard did not offer anything in the
"Available Plugins and Fragments" field.
I also tried to create a mini-RCP application and to add
my plugin to the applications dependencies. However,
the wizard does not seem to be aware of the existence of
my "cloned" plugin and offers the plugin from the
runtime only. (I know, that using a separate target
platform would be better.)
I would be grateful hints!
Kind regards
Harald
Re: how to modify existing plugin [message #542885 is a reply to message #541350] |
Sun, 27 June 2010 02:20  |
On 20/06/2010 16:58, Harald Finster wrote:
> Hello,
> matters.
> Kind regards
> Harald
The other plug-ins might be picking the old (and original) plug-in due to version binding. Also the
plug-ins may be signed jars and since your plug-in is unsigned it wont be picked up. I am not sure
if there is a workaround for this as this is supposed to be OSGi security mechanism.
However, if you do figure out a way, plz do r'ber to open a bug and submit your modifications as
required by EPL.
Ankur..
Eclipse PDE UI Committer | IBM India Software Lab, Bangalore
+91-99456-94011 | @ankur_sharma | http://blog.ankursharma.org
Re: how to modify existing plugin [message #606179 is a reply to message #541350] |
> Hello,
> matters.
> Kind regards
> Harald
required by EPL.
Ankur..
FUDForum. Page generated in 0.28241 seconds
