Home » Language IDEs » AspectJ » Installation of AJDT 2.1.0 in Eclipse 3.6
icon5.gif  Installation of AJDT 2.1.0 in Eclipse 3.6 [message #542746] Fri, 25 June 2010 15:20 Go to next message
Hi!
I have installed Eclipse Java EE IDE for Web Developers (Helios Release, Build id: 20100617-1415).
Then I have installed AJDT 2.1.0 dev builds for Eclipse 3.6 via Help > Install New Software (http://download.eclipse.org/tools/ajdt/36/dev/update).
But I cannot find the New Aspect wizard under File > New > Other > (AspectJ > Aspect is missing)
Also Run > Run > Aspect/Java application is missing.
Please, what do I miss to get AJDT installed correctly in Eclipse Helios?
Best regards, Elund
[Updated on: Fri, 25 June 2010 15:22] by Moderator
Re: Installation of AJDT 2.1.0 in Eclipse 3.6 [message #542791 is a reply to message #542746] Sat, 26 June 2010 00:31 Go to previous messageGo to next message
It seems like AJDT is not installed properly. To make sure, go to Help->About Eclipse...
Look in the features tab. Do you see the AJDT feature?
If you have already tried to install from the dev update site for 3.6, and the install appears to complete successfully, then the most common cause is that your install directory is read-only.
If this is not the case, then we should have a deeper look. Are there any relevant exceptions in your error log? If so, please paste them here.
Re: Installation of AJDT 2.1.0 in Eclipse 3.6 [message #542838 is a reply to message #542791] Sat, 26 June 2010 12:07 Go to previous messageGo to next message
Thank you very much for your answer Smile
Look likes AJDT is properly installed now.
A read-only directory probably caused my problems with installing AJDT.
[Updated on: Sat, 26 June 2010 12:12] by Moderator
Re: Installation of AJDT 2.1.0 in Eclipse 3.6 [message #601073 is a reply to message #542791] Sat, 26 June 2010 12:07 Go to previous message
Thank you very much for your answer :)
But I am still missing: Run > Run > Aspect/Java application.
Do you have more good ideas?
Previous Topic:Installation of AJDT 2.1.0 in Eclipse 3.6
Next Topic:Two questions about AspectJ possibilities before I dive in
Current Time: Sat Jul 26 19:19:11 EDT 2025
Powered by FUDForum. Page generated in 0.03365 seconds
