Home » Modeling » TMF (Xtext) » Overriding terminal StRING
Overriding terminal StRING [message #542495] Fri, 25 June 2010 02:01 Go to next message
I had to override the terminal rule STRING because in my grammar there's no string with line breaks in it allowed and also a '$' should be escape-able. So I defined the rules:
terminal STRING:
	'"' (STR_ESC | !('"'|'\r'|'\n'|'\\'))* '"'
terminal STR_ESC:
	'\\'('b'|'t'|'n'|'f'|'r'|'"'|'\\'|'$')
The line break thing works fine but an input
"foo\$bar"
evokes a syntax error "Illegal escape character \$"
Is there anything that I should configure in the parser?
- Alex
Re: Overriding terminal StRING [message #542507 is a reply to message #542495] Fri, 25 June 2010 02:46 Go to previous messageGo to next message
Hi Alex,
if you override the terminal rule, you should consider to override the
value converter, too. Please refer to the documentation at
http://www.eclipse.org/Xtext/documentation/1_0_0/xtext.html# valueconverter
for details.
Sebastian
Am 25.06.10 08:01, schrieb Alex:
> terminal STRING:
> terminal STR_ESC:
> The line break thing works fine but an input "foo\$bar" evokes a syntax
> - Alex
Re: Overriding terminal StRING [message #542524 is a reply to message #542507] Fri, 25 June 2010 04:19 Go to previous messageGo to next message
Thanks for that hint!
I now added a binding to the MyDslRuntimeModule and tried to implement a MyDslStringValueConverter.
	public Class<? extends IValueConverterService> bindIValueConverterService() {
	  return MyDslStringValueConverter.class;
import org.eclipse.xtext.conversion.IValueConverterService;
import org.eclipse.xtext.conversion.ValueConverterException;
import org.eclipse.xtext.parsetree.AbstractNode;
public class MyDslStringValueConverter implements IValueConverterService {
	public Object toValue(String string, String lexerRule, AbstractNode node)
			throws ValueConverterException {
		// TODO Auto-generated method stub
		return null;
	public String toString(Object value, String lexerRule) {
		return null;
But where do I configure that my rule STRING should only return its value?
Do I now have to implement a value converter for each of my rules in the overridden method toValue() ?
I thought I could rather implement something like that:
public class MyDslStringValueConverter extends AbstractLexerBasedConverter<String> {
	public String toValue(String string, AbstractNode node)
		return node.getElement().toString();
But I don't know how to bind it...
[Updated on: Fri, 25 June 2010 04:25] by Moderator
Re: Overriding terminal StRING [message #542532 is a reply to message #542524] Fri, 25 June 2010 04:38 Go to previous messageGo to next message
Extend the DefaultTerminalConverters (that class gives you an idea what
to do) and see how it is bound in the DefaultRuntimeModule.
Alex
Re: Overriding terminal STRING [message #542987 is a reply to message #542532] Mon, 28 June 2010 02:51 Go to previous message
I did following:
public class MyDslRuntimeModule extends com.bosch.AbstractTpsRuntimeModule {
	public Class<? extends org.eclipse.xtext.conversion.IValueConverterService> bindIValueConverterService() {
		return MyTerminalConverters.class;
public class MyTerminalConverters extends DefaultTerminalConverters {
	public static class STRINGValueConverter extends AbstractValueConverter<String> {
		public String toString(String value) {
			if (value == null)
				throw new ValueConverterException("STRING-value may not be null.", null, null);
			return '"' + Strings.convertToJavaString(value, false) + '"';
		public String toValue(String string, AbstractNode node) {
			if (string == null)
				return null;
			try {
				return string.substring(1,string.length()-1);	// return value of string (without '"')
			} catch (IllegalArgumentException e) {
				throw new ValueConverterException(e.getMessage(), node, e);
	@Inject
	private org.eclipse.xtext.conversion.impl.STRINGValueConverter stringValueConverter;
	@ValueConverter(rule = "STRING")
	public IValueConverter<String> STRING() {
		return stringValueConverter;
But nevertheless I get the parser error "illegal escape character \$" for a input a = "hello\$world"
the rules for Strings are
terminal STRING:
terminal STR_ESC:
EDIT:
I forgot to change
	@Inject
to my own STRINGValueConverter
Sorry for that!
[Updated on: Mon, 28 June 2010 03:04] by Moderator
Previous Topic:Building with Maven xText 1.0
Next Topic:how to get cross reference with Standalone mode
Current Time: Mon Jul 21 17:30:51 EDT 2025
Powered by FUDForum. Page generated in 0.06154 seconds
