Home » Eclipse Projects » Subversive » Workspace - Subversive(Challenging Import of Old projects)
Workspace - Subversive [message #539780] Sat, 12 June 2010 22:28 Go to next message
Hello
Under c:\workspace, I have my old projects (without subversive), which I used for Eclipse 3.2
After i moved to helios RC3, I planned to use subversive. Installed successfully and tested with few new projects (checked-out to c:\workspace). All good.
Now time to import existing projects from c:\workspace to SVN (checked-out to c:\workspace), where i plan to keep it.
What I am doing now, is right click on existing project (non-sub) and import --> svn project
..then point to an existing Project\trunk, in the wizard dialog, i get four options, and i tried using all four, but at the end of the wizard, I dont get the sVN folder filled with the source src and bin folders.
What am I doing wrong? Is it my usage? I didnt take any training in subversive and am figuring out the right method.
If my question is confusing, you may answer my alternate question, which is, how can i import an existing project (C:\workspace\projectA) into a svn:\\hostname:3520\ProjA\trunk (checked-out to c:\workspace)
Re: Workspace - Subversive [message #539880 is a reply to message #539780] Mon, 14 June 2010 03:53 Go to previous messageGo to next message
Hello Manny,
You can import project to SVN in the following way:
1. right-click the project and call Team/Share Project action, as a
result Share Project wizard will help you to specify all need options
2. select SVN
3. select existing repository location or create a new one
4. specify project location: you can use here either simple or advanced
mode. For simplicity select simple mode and provide the url or select it
by pressing Browse button.
5. specify comment and press Finish
6. then you'll have a commit dialog which lists resources to commit.
Press Ok to commit resources.
> Hello
> import --> svn project .then point to an existing Project\trunk, in the
Igor Burilo
Re: Workspace - Subversive [message #540092 is a reply to message #539880] Mon, 14 June 2010 16:42 Go to previous messageGo to next message
Thanks Mr. Burilo.
Worked like a charm
Re: Workspace - Subversive [message #542423 is a reply to message #539780] Thu, 24 June 2010 14:51 Go to previous messageGo to next message
I do not have the option "Share Project", all I see is "Apply Patch."
Re: Workspace - Subversive [message #542570 is a reply to message #539780] Fri, 25 June 2010 07:04 Go to previous message
I was able to get it working. For anyone having the same problem as I was, delete the project from Eclipse but leave the contents on the disk. Then import the project back into Eclipse. It should automatically recognize the svn info, at least it did for me.
Previous Topic:test pls ignore
Next Topic:Linking an existing Ecllpse project to an SVN repository
Current Time: Sat Jul 26 10:25:20 EDT 2025
Powered by FUDForum. Page generated in 0.03547 seconds
