Home » Eclipse Projects » Eclipse Platform » "No repository found" problems in Helios
"No repository found" problems in Helios [message #542184] Thu, 24 June 2010 03:48 Go to next message
Hello!
As I usually do when a new version of Eclipse is available, I downloaded
the Platform Runtime Library. Once launched, I try to use the update
manager to install the plugins I need.
If I try to install the JDT from the Helios Update Site, for instance, I
get the following error:
An error occurred while collecting items to be installed
session context was:(profile=PlatformProfile,
phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=,
action=).
No repository found containing:
osgi.bundle,org.eclipse.ant.launching,1.0.0.v20100427
osgi.bundle,org.eclipse.ant.ui,3.5.0.v20100427
osgi.bundle,org.eclipse.jdt,3.6.0.v201006080911
osgi.bundle,org.eclipse.jdt.apt.core,3.3.400.v20100513-0845
osgi.bundle,org.eclipse.jdt.apt.pluggable.core,1.0.300.v2010 0513-0845
osgi.bundle,org.eclipse.jdt.apt.ui,3.3.300.v20100513-0845
osgi.bundle,org.eclipse.jdt.compiler.apt,1.0.300.v20100513-0 845
osgi.bundle,org.eclipse.jdt.compiler.tool,1.0.100.v_A58
No repository found containing: osgi.bundle,org.eclipse.jdt.core,3.6.0.v_A58
osgi.bundle,org.eclipse.jdt.core.manipulation,1.3.0.v2010052 0-0800
osgi.bundle,org.eclipse.jdt.debug,3.6.0.v20100526
osgi.bundle,org.eclipse.jdt.debug.ui,3.5.0.v20100602-0830
osgi.bundle,org.eclipse.jdt.doc.user,3.6.0.v20100608
org.eclipse.update.feature,org.eclipse.jdt,3.6.0.v20100526-0 800-7z8XFUJFMTfCWGoVuHImpms9H155
osgi.bundle,org.eclipse.jdt.junit,3.6.0.v20100526-0800
osgi.bundle,org.eclipse.jdt.junit.core,3.6.0.v20100526-0800
osgi.bundle,org.eclipse.jdt.junit.runtime,3.4.200.v20100526- 0800
osgi.bundle,org.eclipse.jdt.junit4.runtime,1.1.100.v20100526 -0800
osgi.bundle,org.eclipse.jdt.launching,3.5.100.v20100526
osgi.bundle,org.eclipse.jdt.ui,3.6.0.v20100602-1600
binary,org.eclipse.jdt_root,3.6.0.v20100526-0800-7z8XFUJFMTf CWGoVuHImpms9H155
osgi.bundle,org.hamcrest.core,1.1.0.v20090501071000
osgi.bundle,org.junit,3.8.2.v3_8_2_v20100427-1100
osgi.bundle,org.junit,4.8.1.v4_8_1_v20100427-1100
No repository found containing: osgi.bundle,org.junit4,4.8.1.v20100525
Moreover, the Eclipse Project Update Site at
http://download.eclipse.org/eclipse/updates/3.6 shows no items at all in
it...
Any hint?
Mauro.
Re: "No repository found" problems in Helios [message #542240 is a reply to message #542184] Thu, 24 June 2010 06:23 Go to previous messageGo to next message
I'm experiencing the same issue. Lots of reports around the 'net over a long period of time about this.
Some appear to be/have been caused by HTTP proxies - but my PC isn't going via a proxy, transparent or otherwise.
I cleared the p2 cache so the most recent resources were fetched:
cd eclipse/p2/org.eclipse.equinox.p2.repository/cache/
rm  *.jar
# Cause Eclipse to fetch resources
ls -l *.jar
-rw-r--r-- 1 tj tj    1900 2010-06-24 11:04 artifacts1225093372.jar
-rw-r--r-- 1 tj tj  258726 2010-06-24 11:04 artifacts2042621516.jar
-rw-r--r-- 1 tj tj     545 2010-06-24 11:04 artifacts-938627038.jar
-rw-r--r-- 1 tj tj     484 2010-06-24 11:04 compositeArtifacts-1578959201.jar
-rw-r--r-- 1 tj tj     448 2010-06-24 11:04 compositeArtifacts-1830830225.jar
-rw-r--r-- 1 tj tj     450 2010-06-24 11:04 compositeArtifacts625995868.jar
-rw-r--r-- 1 tj tj     480 2010-06-24 11:03 compositeContent-1578959201.jar
-rw-r--r-- 1 tj tj     452 2010-06-24 11:03 compositeContent-1830830225.jar
-rw-r--r-- 1 tj tj   77246 2010-06-24 11:03 content1225093372.jar
-rw-r--r-- 1 tj tj 2085384 2010-06-24 11:04 content625995868.jar
-rw-r--r-- 1 tj tj     383 2010-06-24 11:04 content-938627038.jar
[Updated on: Thu, 24 June 2010 06:24] by Moderator
Re: "No repository found" problems in Helios [message #542286 is a reply to message #542184] Thu, 24 June 2010 08:54 Go to previous message
I tried to use a platform definition (.target) containing the helios
repository. After selecting some contents to use, none of them can be
resolved.
Every entry has an error:
No repository found containing: binary, ...
Lars
Previous Topic:Second WorkbenchWindow instance which is fully customizable
Next Topic:p2 Help
Current Time: Fri Jul 25 23:46:30 EDT 2025
Powered by FUDForum. Page generated in 0.05252 seconds
