Home » Newcomers » Newcomers » Helios Error Installing PDE(Cannot install the plug-in development environment from within update manager)
Helios Error Installing PDE [message #542072] Wed, 23 June 2010 13:39 Go to next message
After downloading eclipse-hava-helios-linux-gtk.tar.gz. I cannot install the pde from within the update manager. I get the following error:
An error occurred while collecting items to be installed
session context was:(profile=epp.package.java, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.pde,3.6.0.v201006080911
No repository found containing: osgi.bundle,org.eclipse.pde.api.tools,1.0.201.v20100602-0930
No repository found containing: osgi.bundle,org.eclipse.pde.api.tools.ui,1.0.200.v20100601-1 815
No repository found containing: osgi.bundle,org.eclipse.pde.build,3.6.0.v20100603
No repository found containing: osgi.bundle,org.eclipse.pde.core,3.6.0.v20100601
No repository found containing: osgi.bundle,org.eclipse.pde.doc.user,3.6.0.v20100603-1350
No repository found containing: osgi.bundle,org.eclipse.pde.ds.core,1.0.100.v20100601
No repository found containing: osgi.bundle,org.eclipse.pde.ds.ui,1.0.100.v20100601
No repository found containing: org.eclipse.update.feature,org.eclipse.pde,3.6.0.v20100525-7 b7mFKtFEx2XmfZ4_B7NUJA
No repository found containing: osgi.bundle,org.eclipse.pde.junit.runtime,3.4.100.v20100601
No repository found containing: osgi.bundle,org.eclipse.pde.launching,3.6.0.v20100601
No repository found containing: osgi.bundle,org.eclipse.pde.runtime,3.4.200.v20100601
No repository found containing: osgi.bundle,org.eclipse.pde.ua.core,1.0.100.v20100504
No repository found containing: osgi.bundle,org.eclipse.pde.ua.ui,1.0.100.v20100504
No repository found containing: osgi.bundle,org.eclipse.pde.ui,3.6.0.v20100601
No repository found containing: osgi.bundle,org.eclipse.pde.ui.templates,3.4.200.v20100601
No repository found containing: osgi.bundle,org.objectweb.asm,3.2.0.v200909071300
Re: Helios Error Installing PDE [message #542091 is a reply to message #542072] Wed, 23 June 2010 16:11 Go to previous messageGo to next message
I have these error too, just download eclipse classic and copy plugin and feature folder from classic to your current eclipse
Re: Helios Error Installing PDE [message #542093 is a reply to message #542072] Wed, 23 June 2010 16:31 Go to previous messageGo to next message
I (always) download the minimum eclipse, in this case eclipse-platform-3.6-win32.zip and I am getting the same errors when trying to download any plugin. Very frustrating. I would hate to download a package. Any idea what this can be? I managed to find some references via Google, and it seems the same issue was present with the 3.4 release.
[Updated on: Wed, 23 June 2010 16:32] by Moderator
Re: Helios Error Installing PDE [message #542191 is a reply to message #542072] Thu, 24 June 2010 04:32 Go to previous messageGo to next message
same here. i've downloaded eclipse-php-helios-linux-gtk-x86_64
and it fails to install any plugin with similar error.
so i install them manually by extracting into dropins directory. at least pydev and subclipse work fine after manual install
Re: Helios Error Installing PDE [message #542230 is a reply to message #542072] Thu, 24 June 2010 05:52 Go to previous messageGo to next message
I've also encountered this problem on Mac.
Re: Helios Error Installing PDE [message #542236 is a reply to message #542072] Thu, 24 June 2010 06:05 Go to previous messageGo to next message
I recommend we all add a comment to this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=290782
and also vote for it!
Re: Helios Error Installing PDE [message #542249 is a reply to message #542072] Thu, 24 June 2010 07:15 Go to previous message
The same situation as when 3.5 was released. Was 1 year not enough to handle this problem?
Previous Topic:Java Noob
Next Topic:eclipse console
Current Time: Wed Nov 05 23:12:37 EST 2025
Powered by FUDForum. Page generated in 0.10062 seconds
