Home » Language IDEs » ServerTools (WTP) » No Tomcat Server Adapter for Helios? Really?(Tomcat does not show in the list of server adapters)
icon8.gif  No Tomcat Server Adapter for Helios? Really? [message #541875] Tue, 22 June 2010 17:09 Go to next message
I installed (from friends of Eclipse) the Helios release today.
When I try to create a server to run my project on, the only things available were: "HTTP Preview" and "HTTP Server".
So, I hit the link "Download additional server adapters"
The resulting list contains Geronimo, Jetty, Jonas, SAP, and WASCE.
Is this on purpose or just a bug?
Is there a way to get adapters that are actually useful?
Re: No Tomcat Server Adapter for Helios? Really? [message #542065 is a reply to message #541875] Wed, 23 June 2010 12:59 Go to previous messageGo to next message
Tomcat support is built in, so you should see:
http://www.eclipse.org/webtools/releases/3.2.0/NewAndNotewor thy/server.php
I would guess you may be missing some dependency that is preventing the
Tomcat support from showing up. I'm not sure off the top of my head
what that would be though.
Larry
Re: No Tomcat Server Adapter for Helios? Really? [message #542076 is a reply to message #542065] Wed, 23 June 2010 14:37 Go to previous messageGo to next message
Could you detail exactly what you installed? For instance, did you install Eclipse IDE for Java EE Developers or did you piece together your own configuration?
If option 2, chances are good that you've missed a dependency.
If option 1, I would guess that your Eclipse did not pickup a JVM that's compatible with all WTP components. Most WTP components require at least Java 5, while parts of Eclipse will work with Java 1.4. You can check in the about box under configuration to see which JVM Eclipse is running with. If it picked up the wrong one, you will need to edit eclipse.ini file to tell it which JVM to use. Just add the following to the start of the file...
-vm
[some-path]/javaw.exe
Re: No Tomcat Server Adapter for Helios? Really? [message #542077 is a reply to message #542076] Wed, 23 June 2010 14:41 Go to previous messageGo to next message
I installed the "Eclipse IDE for Java Developers" that came in my "friends of Eclipse" email as there was not one for Java EE devs.
From the Install new software dialog, I installed the WTP tools.
I'm running Java 1.6 update 20
icon10.gif  Re: No Tomcat Server Adapter for Helios? Really? [message #542086 is a reply to message #541875] Wed, 23 June 2010 15:50 Go to previous messageGo to next message
Update:
I reviewed the Friends of Eclipse mail and noticed there are two links for Eclipse for Javascript devs.
Checking the URLs, I noticed one of them is actually for Java EE.
I downloaded and ran that one and everything seems to be much better (all kinds of servers in the list).
WooHoo!!!
Re: No Tomcat Server Adapter for Helios? Really? [message #1744075 is a reply to message #542086] Thu, 22 September 2016 04:27 Go to previous message
how to add lighttpd web server in eclipse ide?
Previous Topic:add lighttpd web server into eclipse
Next Topic:Problem with WAR File Export (lastmodified)
Current Time: Thu Jul 24 22:52:33 EDT 2025
Powered by FUDForum. Page generated in 0.09201 seconds
