Home » Modeling » M2T (model-to-text transformation) » Iterating over extensions
Iterating over extensions [message #541996] Wed, 23 June 2010 09:38 Go to next message
I want to use my extension file as a library where I storage different functions. In order to implement a matching method which picks a function from the library for me, I want to iterate over the extensions (i.e. these functions) from a Java class. XtendFacade has not an access to the extensions. Has anyone here an idea how can I do that? Thanks for your comments!
Regards, Nadya
Re: Iterating over extensions [message #545575 is a reply to message #541996] Thu, 08 July 2010 06:02 Go to previous message
Hi, it is right that the extension facade hides this but a look into its code shows that something like this can done:
import org.eclipse.internal.xtend.xtend.ast.Extension;
import org.eclipse.xtend.expression.ExecutionContext;
import org.eclipse.xtend.expression.ExecutionContextImpl;
import org.eclipse.xtend.expression.Resource;
import org.eclipse.xtend.expression.TypeSystemImpl;
import org.eclipse.xtend.type.impl.java.JavaBeansMetaModel;
public class Main {
		ExecutionContext executionContext = createExecutionContext("template::test");
		((ExecutionContextImpl)executionContext).registerMetaModel(new JavaBeansMetaModel());
		for (Extension e : executionContext.getAllExtensions()) {
			System.out.println(e);
	private static ExecutionContext createExecutionContext(final String... extensions) {
		ExecutionContext executionContext = new ExecutionContextImpl(new TypeSystemImpl());
		executionContext = executionContext.cloneWithResource(new Resource() {
			public String getFullyQualifiedName() {
				return null;
			public void setFullyQualifiedName(final String fqn) {
			public String[] getImportedNamespaces() {
				return null;
			public String[] getImportedExtensions() {
				return extensions;
		return executionContext;
This prints all extensions in the given extension file.
This might solve your problem although i do not understand your usecase.
Christian
[Updated on: Thu, 08 July 2010 06:21] by Moderator
Previous Topic:[XPAND] WorkflowInterruptedException: EvaluationException : Nullevaluation
Next Topic:[xpand] fixed indentation
Current Time: Sat Jul 26 12:00:18 EDT 2025
Powered by FUDForum. Page generated in 0.06748 seconds
