Home » Archived » M2M (model-to-model transformation) » Does ecore only supports .xmi models?
Does ecore only supports .xmi models? [message #541972] Wed, 23 June 2010 08:28 Go to next message
Hi all,
I have source and target meta models and now I want to input my model as say "buildToBuilder.xml" as
Source Model IN:
           buildToBuilder.xml
and
Target modle OUT:
      test.xml
Now I am wondering if the buildToBuilder.xml file should be in xmi format? otherwise I am getting errors like
Error loading platform:/resource/WSCDL2SWBPEL/BuildToOrder.xml: org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'package' is not found or is abstract. (platform:/resource/WSCDL2SWBPEL/BuildToOrder.xml, 2, 400)
Re: Does ecore only supports .xmi models? [message #542020 is a reply to message #541972] Wed, 23 June 2010 10:39 Go to previous messageGo to next message
--------------070004000509050100000102
No, you should be able to read pretty much any XML format.
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .emf.doc/tutorials/xlibmod/xlibmod.html
Registering an appropriate factory is often important though.
Transformed wrote:
> Hi all,
> Source Model IN:
> buildToBuilder.xml
> and
> Target modle OUT:
> test.xml
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
No, you should be able to read pretty much any XML format. <br>
<blockquote><a
href=" http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .emf.doc/tutorials/xlibmod/xlibmod.html"> http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .emf.doc/tutorials/xlibmod/xlibmod.html</a><br>
</blockquote>
 Registering an appropriate factory is often important though.<br>
<br>
<br>
<br>
Transformed wrote:
<blockquote cite="mid:hvsukq$gdj$1@build.eclipse.org" type="cite">Hi
all,
<br>
<br>
as say "buildToBuilder.xml"  as <br>
Source Model IN:
<br>
          buildToBuilder.xml
<br>
<br>
and <br>
Target modle OUT:
<br>
     test.xml
<br>
<br>
<br>
format? otherwise I am  getting errors like <br>
<br>
<br>
</blockquote>
</body>
</html>
--------------070004000509050100000102--
Re: Does ecore only supports .xmi models? [message #542454 is a reply to message #542020] Thu, 24 June 2010 17:47 Go to previous messageGo to next message
Hi Hitindeep
Alternatively if you use a schema location to refer to your meta-model,
you may find that reflective/dynamic EMF works for you without needing
to generate Java models.
e.g. in buildToBuilder.xml
<mine:Ccc xmi:version="2.0"
xmlns:mine="mine" xsi:schemaLocation="mine My.ecore"/>
Ed Willink
> Transformed wrote:
>> Hi all,
>> Source Model IN:
>> buildToBuilder.xml
>> and
>> Target modle OUT:
>> test.xml
Re: Does ecore only supports .xmi models? [message #542682 is a reply to message #542454] Fri, 25 June 2010 11:37 Go to previous messageGo to next message
I tried the ways and some of the other issues appeared.
I derived the metamodels from respective xsd file and I added
When I try to open the xml file using the reflective ecore editor then again same error appeared as:
PackageNotFoundException: package with uri "null" not found.
PackageNotFoundException: Class "Package" is not found of is abstract.
Does it make difference if I have Package in wscdl.ecore file and package in xml file?
Like in ecore file I have this.
<eClassifiers xsi:type="ecore:EClass" name="Package" eSuperTypes="#//ExtensibleElements">
<eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="tPackage"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
and in input model I have
<package xmlns:xsi = "http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation = "http://www.w3.org/2005/10/cdl CDL.ecore" xmlns:cdl="http://www.w3.org/2005/10/cdl" author="Ravi Khadka" name="BuildToOrderCDL" targetNamespace="http://example.org/build2order" version="x">
</package>
Re: Does ecore only supports .xmi models? [message #542701 is a reply to message #542682] Fri, 25 June 2010 12:24 Go to previous message
You need to define the namespace for "package", either by perhaps
<cdl:package xmlns:cdl="http://www.w3.org/2005/10/cdl"
or
<package xmlns="http://www.w3.org/2005/10/cdl"
Ed Willink
> I derived the metamodels from respective xsd file and I added Quote:
>> xmlns:xmi="http://www.omg.org/XMI"
> Quote:
> Quote:
>> <eAnnotations
>> </eAnnotations>
> Quote:
>> </package>
Previous Topic:[ATL] problem with am3 and using ant
Next Topic:[QVT-R] public2private example ?
Current Time: Sun Jul 20 23:44:01 EDT 2025
Powered by FUDForum. Page generated in 0.07369 seconds
