Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Backgorund mdoe inherit doesn't work with windoes theme classic
Backgorund mdoe inherit doesn't work with windoes theme classic [message #541149] Fri, 18 June 2010 08:58 Go to next message
Hi all,
We have a composite with an background image and place widgetes like
labels and checkboxes on that composite. With the command:
cmp.setBackgroundMode(SWT.INHERIT_DEFAULT);
the widgets use the background from the composite.
This works on windows xp machines with an windows xp theme goood. If the
user switches to the windows classic theme buttons like checkboxes and
radiobuttens have grey background.
Has somebody any idea to fix this problem?
tanks
karsten
Re: Backgorund mdoe inherit doesn't work with windoes theme classic [message #541536 is a reply to message #541149] Mon, 21 June 2010 09:36 Go to previous messageGo to next message
You can set the background mode to SWT.INHERIT_FORCE and see if works for you.
I would suggest logging a bug report under SWT for the behavior you are seeing. You can do it here --> https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=SWT
Re: Backgorund mdoe inherit doesn't work with windoes theme classic [message #541633 is a reply to message #541536] Mon, 21 June 2010 16:52 Go to previous messageGo to next message
On 06/21/2010 03:36 PM, Lakshmi Shanmugam wrote:
> for you.
thanks it works with INHERIT_FORCE.
I'll create a bug report, thanks
karsten
Re: Backgorund mdoe inherit doesn't work with windoes theme classic [message #541659 is a reply to message #541633] Tue, 22 June 2010 01:33 Go to previous messageGo to next message
>> Hi,
>> for you.
>> Thanks,
Please don't forget to announce the corresponding bug id, such that
others can contribute or vote for it!
Greetings from Bremen,
Daniel Krügler
Re: Backgorund mdoe inherit doesn't work with windoes theme classic [message #541956 is a reply to message #541659] Wed, 23 June 2010 07:19 Go to previous message
>>> Hi,
>>> for you.
>>> Thanks,
>> Hi,
> Daniel Krügler
The bug id is: Bug 317681
greetings from Hamburg,
karsten
Previous Topic:Missing imported package
Next Topic:Mousewheel scrolling with "autofocus"
Current Time: Sat Jul 26 03:31:42 EDT 2025
Powered by FUDForum. Page generated in 0.05176 seconds
