Re: Start Tomcat within eclipse from ANT task [message #545094 is a reply to message #544019] |
Tue, 06 July 2010 10:59  |
On 7/1/2010 7:32 AM, Sharon Whipple wrote:
> Thank you Larry,
> I was able to find the command :
> "C:\Program Files\Java\jdk1.5.0_13\bin\java.exe"
> agentlib:jdwp=transport=dt_socket,suspend=y,address=localhos t:2468
> "-Dcatalina.base=C:\Documents and
> Settings\sharonw\workspace\.metadata\.plugins\org.eclipse.ws
> t.server.core\tmp1 " "-Dcatalina.home=c:\Program Files\Apache Software
> Foundation\Tomcat 5.5" "-Dwtp.deploy=C:\Documents and
> Settings\sharonw\workspace" "-Djava.endorsed.dirs=c:\Program
> Files\Apache Software Foundation\Tomcat 5.5\common\endorsed" -Xms256m
> -Xmx1024m -XX:PermSize=-XX:MaxPermSize=256m -Dfile.encoding=Cp1255
> "-Xbootclasspath:C:\PATH..." org.apache.catalina.startup.Bootstrap start
> :blush:
> But it fail to run:
> ERROR: transport error 202: connect failed: Connection refused
> ["transport.c",L41]
> ERROR: JDWP Transport dt_socket failed to initialize,
> TRANSPORT_INIT(510) ["debugInit.c",L500]
> JDWP exit error JVMTI_ERROR_INTERNAL(113): No transports
> initializedFATAL ERROR in native method: JDWP No transports initialized,
> jvmtiError=JVMTI_ERROR_INTERNAL(113)
The fact that you get this outside of Eclipse indicates it's a problem
between Java and your system. Google may be able to provide an answer.
You might start with this one:
http://wiki.eclipse.org/Debug_FAQ#I_can_run_a_program_but_no t_debug_it.3F.3F.3F
Larry
FUDForum. Page generated in 0.08259 seconds
