Home » Eclipse Projects » Eclipse Platform » Dynamically expanding sub-menu on right click(or similar solutions to my problem :))
Dynamically expanding sub-menu on right click [message #541348] Sun, 20 June 2010 07:14 Go to next message
Hi everyone!
First of all, let me explain what I try to do, then how I think it could be done and what my problems are.
So, what I want to do is have a possibility to group files for later use. So we might have file a and b in group 1, file c, f and h in group 2 etc. There is no fixed number of groups, so I need to be able to expand the number of groups dynamically
Now I imagined I could have a sub-menu on the right click in the project explorer with initially just 2 entries "1" and "2" for the group number. The user can then start to add files to those groups, but when group 2 has more than 0 members, a third entry appears in the menu and so on.
So, first of all, how would I go about adding such a sub-menu to the right-click? I know can add an entry by extending org.eclipse.ui.menus and adding a menucontribution to URI popup:org.eclipse.ui.navigator.ProjectExplorer#PopupMenu , but then I am stumped.
Another problem I see is adding menu items during runtime. Is that possible and if yes, how would it be done?
Thanks in advance for any help you can offer,
Martin
Re: Dynamically expanding sub-menu on right click [message #541520 is a reply to message #541348] Mon, 21 June 2010 09:08 Go to previous messageGo to next message
first place a submenu in the menu you want, and then you would use
<dynamic/> and provide a subclass of CompoundContributionItem. Then you
can return multiple IContributionItems (Separator for separators and
CommandContributionItems to access different files).
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Dynamically expanding sub-menu on right click [message #541927 is a reply to message #541520] Wed, 23 June 2010 05:01 Go to previous messageGo to next message
Thanks for the reply!
Paul Webster wrote on Mon, 21 June 2010 09:08
Well, that is kinda one of my problems Smile Could you please elaborate on how I would do that a little?
Re: Dynamically expanding sub-menu on right click [message #541970 is a reply to message #541927] Wed, 23 June 2010 08:26 Go to previous messageGo to next message
> Well, that is kinda one of my problems :) Could you please elaborate on
you add a menu using the <menu/> element in a menuContribution. You
need to get the locationURI correct, but I thought that was what you
provided in your first post:
Use the org.eclipse.ui.menus extension point ... please read the
Extension Point Description
PW
Paul Webster
Re: Dynamically expanding sub-menu on right click [message #542059 is a reply to message #541348] Wed, 23 June 2010 12:35 Go to previous message
Okay, I was able to do what I had in mind using your tips.
Thanks a lot!
Previous Topic:RCP applications without org.eclipse.ui.workbench
Next Topic:Problem updating to final helios release from RC6
Current Time: Sat Jul 26 06:17:48 EDT 2025
Powered by FUDForum. Page generated in 0.07857 seconds
