Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Modules recompilation(How to recompile acceleo modules outside Eclipse)
| Re: [Acceleo] Modules recompilation [message #542198 is a reply to message #542176] |
Thu, 24 June 2010 04:37   |
--------------000101040409050406080701
This error is due to missing URI mappings and package registrations (all
of these are normally taken care of by Eclipse, yet you are in standalone).
Namely, you need to add the URI mappings for our libraries (this is the
source of the exception you copy/pasted here) :
URIConverter.URI_MAP.put("http://www.eclipse.org/acceleo/mtl/3.0/mtlstdlib.ecore",
" platform:/plugin/org.eclipse.acceleo.model/model/mtlstdlib.e core ");
URIConverter.URI_MAP.put("http://www.eclipse.org/acceleo/mtl/3.0/mtlnonstdlib.ecore",
" platform:/plugin/org.eclipse.acceleo.model/model/mtlnonstdli b.ecore ");
and afterwards, you'll most likely have exceptions of type "package with
URI '*' not found. Take a look at
http://eclipsemde.blogspot.com/2010/06/package-with-uri-not- found.html
for explanations on the source and solution of these if you encounter them.
Laurent Goubet
Obeo
koïta Aboubakar wrote:
> Thank you for your answers.
> Laurent, I get dirty hands, for sure :), but my goal is to make the
> whole process of generation outside Eclipse.
> On this point precisely, I have a problem compiling modules. I get the
> following error by launching AcceleoCompiler (with ant and standalone
> execution):
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException:
> java.net.UnknownHostException: www.eclipse.org
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
> at
> org.eclipse.acceleo.common.utils.ModelUtils.load(ModelUtils. java:346)
> at
> org.eclipse.acceleo.common.utils.AcceleoStandardLibrary.<init >(AcceleoStandardLibrary.java:194)
> at
> org.eclipse.acceleo.internal.parser.ast.ocl.environment.Acce leoEnvironment.getAcceleoStandardLibrary(AcceleoEnvironment. java:252)
> at
> org.eclipse.acceleo.internal.parser.ast.ocl.environment.Acce leoEnvironment.addAdditionalOperations(AcceleoEnvironment.ja va:386)
> at
> org.eclipse.acceleo.internal.parser.ast.ocl.environment.Acce leoEnvironment. <init>(AcceleoEnvironment.java:101)
> at
> org.eclipse.acceleo.internal.compatibility.parser.ast.ocl.en vironment.AcceleoEnvironmentGalileo. <init>(AcceleoEnvironmentGalileo.java:85)
> at
> org.eclipse.acceleo.internal.parser.ast.ocl.environment.Acce leoEnvironmentFactory.loadEnvironment(AcceleoEnvironmentFact ory.java:61)
> at org.eclipse.ocl.OCL.<init>(OCL.java:127)
> at org.eclipse.ocl.ecore.OCL.<init>(OCL.java:90)
> at org.eclipse.ocl.ecore.OCL.newInstance(OCL.java:151)
> at
> org.eclipse.acceleo.internal.parser.ast.ocl.OCLParser.init(O CLParser.java:132)
> at
> org.eclipse.acceleo.internal.parser.ast.ocl.OCLParser.<init >(OCLParser.java:122)
> at
> org.eclipse.acceleo.internal.parser.ast.ASTFactory.initOCL(A STFactory.java:133)
> at
> org.eclipse.acceleo.internal.parser.ast.CST2ASTConverter.cre ateAST(CST2ASTConverter.java:127)
> at
> org.eclipse.acceleo.parser.AcceleoSourceBuffer.createAST(Acc eleoSourceBuffer.java:298)
> at
> org.eclipse.acceleo.parser.AcceleoParser.parse(AcceleoParser .java:159)
> at
> north.eqdml.dependencies.AcceleoCompiler.execute(AcceleoComp iler.java:191)
> at
> north.eqdml.AcceleoCompilerTest.executeTest(AcceleoCompilerT est.java:22)
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------000101040409050406080701--
| Re: [Acceleo] Modules recompilation [message #542201 is a reply to message #542198] |
Thu, 24 June 2010 04:50   |
--------------070304020004080203090204
Sorry, my bad. The URI Mappings to register of course aren't
"platform:/plugin" as those URIs are eclipse specific and absolutely not
standalone.
Sebastien Roy faced the same problems as you, and managed to single out
the URI mappings and diverse registrations to the following few (Java
code) :
-----8<-----
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "ecore",
new EcoreResourceFactoryImpl());
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "emtl",
new EMtlResourceFactoryImpl());
// Uncomment if you need to use UML
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "uml",
UMLResource.Factory.INSTANCE);
// EPackage.Registry.INSTANCE.put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
// Uncomment if you need to use an UML model created with an old version
of MDT/UML
EPackage.Registry.INSTANCE.put("http://www.eclipse.org/uml2/2.1.0/UML",
CodeSource acceleoModel =
MtlPackage.class.getProtectionDomain().getCodeSource();
if (acceleoModel != null) {
String libraryLocation = acceleoModel.getLocation().toString();
if (libraryLocation.endsWith(".jar")) {
libraryLocation = "jar:" + libraryLocation + '!';
URIConverter.URI_MAP.put(URI.createURI("http://www.eclipse.org/acceleo/mtl/3.0/mtlstdlib.ecore"),
URI.createURI(libraryLocation + "/model/mtlstdlib.ecore"));
URIConverter.URI_MAP.put(URI.createURI("http://www.eclipse.org/acceleo/mtl/3.0/mtlnonstdlib.ecore"),
URI.createURI(libraryLocation + "/model/mtlnonstdlib.ecore"));
} else {
System.err.println("Coudln't retrieve location of plugin
'org.eclipse.acceleo.model'.");
----->8-----
Thanks to Sebastien Roy for sharing his solution :).
Laurent Goubet
Obeo
Laurent Goubet wrote:
> Laurent Goubet
> Obeo
>> Hi,
>> execution):
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
--------------070304020004080203090204--
| Re: [Acceleo] Modules recompilation [message #548558 is a reply to message #548537] |
Thu, 22 July 2010 06:57  |
Hello Aboubakar,
The exec-maven-plugin works perfectly : I can use it to launch the MtlCompiler with all project dependencies present in the classpath.
However, when I remove the copy of my dependencies, the AcceleoCompiler is not able to find them into the classpath.
I am very disapointed !!!
Now the answer to the problem has to be brought by Acceleo team...
Current Time: Tue Nov 04 17:48:27 EST 2025
Powered by FUDForum. Page generated in 0.07556 seconds
