Home » Archived » Buckminster » Eclipse 3.5 build with 3.4 plugins
Eclipse 3.5 build with 3.4 plugins [message #541871] Tue, 22 June 2010 16:53 Go to next message
The plugins I am trying to build in buckminster 3.5 were developed in eclipse 3.4. During materialization I see this error:
ERROR [0000] : No suitable provider for component com.ibm.icu:osgi.bundle/[3.4.0,4.0.0) was found in resourceMap file:/home/akravets2/.hudson/jobs/buckminster/workspace/iit. features/com.iwaysoftware.integration.tools.site/trunk.local .ak.rmap
ERROR [0000] : No suitable provider for component com.ibm.icu:osgi.bundle/[3.4.0,4.0.0) was found in searchPath galileo
ERROR [0000] : Rejecting provider eclipse.import( http://download.eclipse.org/releases/galileo?importType=bina ry): No component match was found
WARNING [0000] : Component request com.ibm.icu:osgi.bundle/[3.4.0,4.0.0) is inconflict with request com.ibm.icu:osgi.bundle/[4.0.1.v20090822,4.0.1.v20090822]
ERROR [0000] : No suitable provider for component com.ibm.icu:osgi.bundle/[3.4.3,4.0.0) was found in resourceMap file:/home/akravets2/.hudson/jobs/buckminster/workspace/iit. features/com.iwaysoftware.integration.tools.site/trunk.local .ak.rmap
ERROR [0000] : No suitable provider for component com.ibm.icu:osgi.bundle/[3.4.3,4.0.0) was found in searchPath galileo
Finished: FAILURE
And this line in particular:
I tried to put com.ibm.icu 3.8 into buckminster headless but have the same error. Is it not possible have two versions of com.ibm.icu in buckminster (I see two different junit jars versions), and if not is the solution to change my plugin dependencies (not directly, but via other plugins: gef) to use 4.0.1 version?
thanks for your help,
Alex
Re: Eclipse 3.5 build with 3.4 plugins [message #541882 is a reply to message #541871] Tue, 22 June 2010 17:36 Go to previous messageGo to next message
just to make sure some basic things are clear:
- The Buckminster version that builds something does not have to be
based on the same Eclipse release as what is being built.
- When building, things in the workspace are built against each other
and what is specified in the Target Platform (TP).
- Buckminster can materialize a TP based on the dependencies of what is
being built (in Buckminster 3.5 a MSPEC is always required to direct
materialization of some material to a TP, in Buckminster 3.6 there are
defaults that may be sufficient).
So:
- You would never need to install anything from Eclipse 3.4 (Europa)
into a 3.5 based Buckminster in order to build for 3.4. (Or using
Buckminster 3.6 to build against 3.5 or 3.4 etc.). So, there is no need
to "put anything into Buckminster headless" that is supposed to be in
the TP you are building against.
- You seem to be saying that you are building something against 3.4, yet
using the Galileo repository (which is 3.5). The 3.4 release was called
Europa. So, what are you trying to do? Is it building components against
Eclipse 3.5 that were originally created for Eclipse 3.4? If so, there
may be API changes and incompatibilities and you need to change both the
dependencies in source of your components as well as the code itself to
make it work.
- henrik
On 6/22/10 10:53 PM, Alex wrote:
> Hello,
> Quote:
>> Finished: FAILURE
> Quote:
> Alex
Re: Eclipse 3.5 build with 3.4 plugins [message #541888 is a reply to message #541882] Tue, 22 June 2010 19:33 Go to previous message
Thanks Henrik,
Yes, that's exactly what I am trying to do, I was thrown off by this error because when I materialize my plugins into workspace in 3.5 there were no conflicts with different version of com.ibm.icu, which is 4.0.1.
Previous Topic:product.ant where can I find example ?
Next Topic:Convert target platform to p2 update site
Current Time: Thu Jun 05 01:53:55 EDT 2025
Powered by FUDForum. Page generated in 0.04097 seconds
