Home » Archived » Buckminster » site.p2 for product configuration always creates and includes source feature
site.p2 for product configuration always creates and includes source feature [message #541737] Tue, 22 June 2010 08:02 Go to next message
Hi!
Following the examples from
http:// wiki.eclipse.org/Building_an_RCP_application_with_hudson_%28 Buckminster%29
http://www.ralfebert.de/blog/eclipsercp/rcp_builds/
and the BuckyBook I was able to successfully build my product configuration with Buckminster on Helios RC4 (doing directly from eclipse, not on a Hudson built server).
Though I realized that the created update site always contains an item "Source for Productname feature ". This only gets visible if you point the eclipse installer to the created site.p2 directory and uncheck the "Group items by category" option.
Following the tutorial I get the same effect, so it seems to be either a common setting in the examples and my configuration or a buckminster bug.
For the records, my properties file already contains the
cbi.include.source=false
setting.
There has been a similar bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=292968. Maybe the problem is alike?
Can someone give me a hint for a configuration setting to prevent the source feature from being created or at least not being included in the update site? Or at least indicate that this is an unwanted behavior worth opening a bugreport.
Frank
Re: site.p2 for product configuration always creates and includes source feature [message #541834 is a reply to message #541737] Tue, 22 June 2010 12:35 Go to previous messageGo to next message
Hi Frank,
If you have this behavior with our 3.6 version, then this sounds like a regression of some sort. It's worth a bug report.
Thomas Hallgren
On 06/22/2010 02:02 PM, Frank Hoellering wrote:
> Hi!
> http://wiki.eclipse.org/Building_an_RCP_application_with_hud son_%28Buckminster%29
> setting.
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=292968 Maybe the problem
> is alike?
> Best regards,
> Frank
Re: site.p2 for product configuration always creates and includes source feature [message #541964 is a reply to message #541737] Wed, 23 June 2010 08:02 Go to previous messageGo to next message
Hi Thomas!
Thank you for your reply.
I'll test again with the final version of Helios (just to make sure) and open a bug report afterwards.
Frank
Re: site.p2 for product configuration always creates and includes source feature [message #542027 is a reply to message #541737] Wed, 23 June 2010 10:55 Go to previous message
reproducible in 3.6 final
https://bugs.eclipse.org/bugs/show_bug.cgi?id=317709
Frank
Previous Topic:The way fragments are treated
Next Topic:importtargetdefinition errors silently ignored
Current Time: Wed Jul 23 12:24:49 EDT 2025
Powered by FUDForum. Page generated in 1.21274 seconds
