string filter for TreeViewer [message #541445] |
Mon, 21 June 2010 04:41  |
I use treeviewer to manager a series of filenames and directories,
the tree may be as follows:
root
xyz.dir
abc.file
axy.file
bb.file
xzf.dir
bc.file
yz.file
now, I have a string from a Text, and I want to filter the treeviewer nodes according to this string. For example,
if the string is "x", then the treeviewer should be as follows:
root
xyz.dir
axy.file
xzf.dir
if the string is "xy", then
root
xyz.dir
axy.file
this is the function that I want to realize, and I try to use ViewFilter, but I failed.
Can anyone provide some suggestions?
coly.
Re: string filter for TreeViewer [message #541549 is a reply to message #541445] |
Mon, 21 June 2010 09:13  |
Originally posted by: gemaspecial.yahoo.com.hk
Try FilteredTreeViewer
On 6/21/2010 4:41 PM, coly wrote:
> Hi, I use treeviewer to manager a series of filenames and directories,
> root
> xyz.dir
> abc.file
> axy.file
> bb.file
> xzf.dir
> bc.file
> yz.file
> root
> xyz.dir
> axy.file
> xzf.dir
> if the string is "xy", then root
> xyz.dir
> axy.file
> coly.
FUDForum. Page generated in 0.04149 seconds
