Riena and Spring [message #540387] |
Tue, 15 June 2010 20:13  |
I am evaluating using Riena (looking at 1.2) as an alternative to out existing RCP project. We only want to use the UI components of Riena, where we want to make use of the Navigation, MVC, and binding etc. I can get a demo application up and running no problem, but what I am trying to figure out now is how we can use Spring IOC to instantiate the controllers. What is the best way to go about doing that? In our RCP app we use a library that implements IExecutableExtensionFactory ( http://martinlippert.blogspot.com/2008/05/dependency-injecti on-for-extensions.html) to allow the use of Spring IOC to create views. Reading the Riena docs it looks like I should be able to inject this extension into the framework somehow, but I cant figure it out. Does anybody have any ideas?
Cheers
Stu.
[Updated on: Tue, 15 June 2010 20:13] by Moderator
Re: Riena and Spring [message #541492 is a reply to message #540790] |
Mon, 21 June 2010 07:11   |
Right, I have figured out how to make it work, this doesn't seem like the most elegant solution but it works..
In your spring context file you need to declare both the view and controller beans, and inject the controller into the view:
<beans:bean id="myview" class="org.ibboost.demo.tutorial.springintegration.views.T1_ErrorhandlingView">
<beans:property name="controller" ref="mycontroller"/>
</beans:bean>
<beans:bean id="mycontroller" class="org.ibboost.demo.tutorial.springintegration.controllers.T1_ErrorHandlingController"></beans:bean>
For this to work you will need to modify your view so that the controller can be injected, so add something like this:
private T1_ErrorHandlingController controller;
public void setController(T1_ErrorHandlingController controller) {
this.controller = controller;
public T1_ErrorHandlingController getController() {
return controller;
protected T1_ErrorHandlingController createController(ISubModuleNode subModuleNode) {
controller.setNavigationNode(subModuleNode);
return controller;
Then in your plugin.xml you define the view like this:
<view
allowMultiple="true"
class="org.eclipse.springframework.util.SpringExtensionFactory:myview"
id="org.ibboost.demo.tutorial.springintegration.views.T1_ErrorhandlingView"
name="T1">
</view>
And the submodule will look something like this, note that the controller does not need to be specified:
<submodule
label="T1 - Error Handling"
name="Tutorial.SI.Application.TutorialsModule.T1"
selectable="true"
shared="false"
typeId="Tutorial.SI.Application.TutorialsModule.T1"
view="org.ibboost.demo.tutorial.springintegration.views.T1_ErrorhandlingView">
</submodule>
This works fine, but my ideal solution would be to be able to only declare the Controller in Spring, as I shouldn't have a need to specify any dependencies other than the controller for the view, so ideally I would like to be able to do this, and leave the view initialization alone:
<submodule
controller="org.eclipse.springframework.util.SpringExtensionFactory:mycontroller"
selectable="true"
shared="false"
</submodule>
Re: Riena and Spring [message #541494 is a reply to message #541470] |
Mon, 21 June 2010 07:17   |
Hi Stuart,
Oh, ouch!
Yes, there is weakness here. I think what happens is that we do not
create the class with createExecutableExtension() instead we pick up the
class name and create the class from the class name.
Can you please open a bug report for this?
Tschüß,
Stefan
On 21.06.2010 11:52, Stu wrote:
> Hi Christian
> Sorry for not getting back to you sooner, I hadn't checked the "Post
> Notification" box.
> Yeah I tried that. So I created a bean called mycontroller of the
> appropriate type, and then in the plugin.xml I added:
> <submodule
> controller="
> org.eclipse.springframework.util.SpringExtensionFactory:myco ntroller "
> After doing that I get this exception when loading the view. Its trying
> to create the class
> org.eclipse.springframework.util.SpringExtensionFactory, rather than
> resolve the bean. This technique worked fine in a plain RCP app, so I
> guess I need to do some extra work to get this to hook up properly in
> Riena, but cant quite figure it out..
> java.lang.ClassCastException:
> at org.eclipse.riena.ui.workarea.WorkareaDefinition.createContr
> oller(WorkareaDefinition.java:54)
> at org.eclipse.riena.navigation.ui.swt.views.SubModuleView.crea
> teController(SubModuleView.java:314)
> tePartControl(SubModuleView.java:173)
> at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR
> eference.java:367)
> at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen
> ce.java:226)
> at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb
> enchPartReference.java:595)
> at org.eclipse.ui.internal.Perspective.showView(Perspective.jav a:2229)
> at org.eclipse.ui.internal.WorkbenchPage.busyShowView(Workbench
> Page.java:1067)
> at org.eclipse.ui.internal.WorkbenchPage$20.run(WorkbenchPage.j ava:3816)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
> at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3813)
> at org.eclipse.riena.navigation.ui.swt.views.SubApplicationView
> $MySubModuleNodeListener.showView(SubApplicationView.java:60 4)
> $MySubModuleNodeListener.showMultiView(SubApplicationView.ja va:589)
> $MySubModuleNodeListener.activated(SubApplicationView.java:5 14)
> $MySubModuleNodeListener.activated(SubApplicationView.java:1 )
> at org.eclipse.riena.navigation.listener.NavigationTreeObserver
> $MySubModuleNodeListener.activated(NavigationTreeObserver.ja va:1228)
> $MySubModuleNodeListener.activated(NavigationTreeObserver.ja va:1)
> at org.eclipse.riena.navigation.model.NavigationNode.notifyActi
> vated(NavigationNode.java:176)
> at org.eclipse.riena.navigation.model.NavigationNode.activate(N
> avigationNode.java:780)
> at org.eclipse.riena.navigation.model.NavigationProcessor.activ
> ate(NavigationProcessor.java:679)
> ate(NavigationProcessor.java:107)
> avigationNode.java:378)
> at org.eclipse.riena.navigation.ui.swt.views.ApplicationViewAdv
> isor.doInitialBinding(ApplicationViewAdvisor.java:262)
> isor.postWindowOpen(ApplicationViewAdvisor.java:183)
> at org.eclipse.ui.internal.WorkbenchWindow.fireWindowOpened(Wor
> kbenchWindow.java:1322)
> at org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow .java:788)
> at org.eclipse.ui.internal.Workbench$22.runWithException(Workbe
> nch.java:1059)
> at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run
> (StartupThreading.java:31)
> at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
> at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr
> onizer.java:134)
> at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3855)
Re: Riena and Spring [message #585911 is a reply to message #540790] |
Mon, 21 June 2010 05:52  |
Hi Christian
Sorry for not getting back to you sooner, I hadn't checked the "Post Notification" box.
Yeah I tried that. So I created a bean called mycontroller of the appropriate type, and then in the plugin.xml I added:
<submodule
controller=" org.eclipse.springframework.util.SpringExtensionFactory:myco ntroller "
After doing that I get this exception when loading the view. Its trying to create the class org.eclipse.springframework.util.SpringExtensionFactory, rather than resolve the bean. This technique worked fine in a plain RCP app, so I guess I need to do some extra work to get this to hook up properly in Riena, but cant quite figure it out..
java.lang.ClassCastException: org.eclipse.springframework.util.SpringExtensionFactory
at org.eclipse.riena.ui.workarea.WorkareaDefinition.createContr oller(WorkareaDefinition.java:54)
at org.eclipse.riena.navigation.ui.swt.views.SubModuleView.crea teController(SubModuleView.java:314)
at org.eclipse.riena.navigation.ui.swt.views.SubModuleView.crea tePartControl(SubModuleView.java:173)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:367)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:226)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.WorkbenchPage.busyShowView(Workbench Page.java:1067)
at org.eclipse.riena.navigation.ui.swt.views.SubApplicationView $MySubModuleNodeListener.showView(SubApplicationView.java:60 4)
at org.eclipse.riena.navigation.ui.swt.views.SubApplicationView $MySubModuleNodeListener.showMultiView(SubApplicationView.ja va:589)
at org.eclipse.riena.navigation.ui.swt.views.SubApplicationView $MySubModuleNodeListener.activated(SubApplicationView.java:5 14)
at org.eclipse.riena.navigation.ui.swt.views.SubApplicationView $MySubModuleNodeListener.activated(SubApplicationView.java:1 )
at org.eclipse.riena.navigation.listener.NavigationTreeObserver $MySubModuleNodeListener.activated(NavigationTreeObserver.ja va:1228)
at org.eclipse.riena.navigation.listener.NavigationTreeObserver $MySubModuleNodeListener.activated(NavigationTreeObserver.ja va:1)
at org.eclipse.riena.navigation.model.NavigationNode.notifyActi vated(NavigationNode.java:176)
at org.eclipse.riena.navigation.model.NavigationNode.activate(N avigationNode.java:780)
at org.eclipse.riena.navigation.model.NavigationProcessor.activ ate(NavigationProcessor.java:679)
at org.eclipse.riena.navigation.model.NavigationProcessor.activ ate(NavigationProcessor.java:107)
at org.eclipse.riena.navigation.model.NavigationNode.activate(N avigationNode.java:378)
at org.eclipse.riena.navigation.ui.swt.views.ApplicationViewAdv isor.doInitialBinding(ApplicationViewAdvisor.java:262)
at org.eclipse.riena.navigation.ui.swt.views.ApplicationViewAdv isor.postWindowOpen(ApplicationViewAdvisor.java:183)
at org.eclipse.ui.internal.WorkbenchWindow.fireWindowOpened(Wor kbenchWindow.java:1322)
at org.eclipse.ui.internal.Workbench$22.runWithException(Workbe nch.java:1059)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
Re: Riena and Spring [message #585923 is a reply to message #540790] |
<beans:bean id="myview" class=" org.ibboost.demo.tutorial.springintegration.views.T1_Errorha ndlingView ">
</beans:bean>
<beans:bean id="mycontroller" class=" org.ibboost.demo.tutorial.springintegration.controllers.T1_E rrorHandlingController "></beans:bean>
return controller;
return controller;
<view
class=" org.eclipse.springframework.util.SpringExtensionFactory:myvi ew "
id=" org.ibboost.demo.tutorial.springintegration.views.T1_Errorha ndlingView "
name="T1">
</view>
<submodule
selectable="true"
shared="false"
view=" org.ibboost.demo.tutorial.springintegration.views.T1_Errorha ndlingView ">
</submodule>
<submodule
selectable="true"
shared="false"
</submodule>
Re: Riena and Spring [message #585937 is a reply to message #541470] |
Hi Stuart,
Oh, ouch!
Tschüß,
Stefan
> Hi Christian
> Notification" box.
> <submodule
> controller="
> to create the class
> eference.java:367)
> ce.java:226)
> Page.java:1067)
> nch.java:1059)
> onizer.java:134)
FUDForum. Page generated in 0.07773 seconds
