Home » Eclipse Projects » Rich Client Platform (RCP) » Translations work well in IDE but are missing after export
Translations work well in IDE but are missing after export [message #541338] Sun, 20 June 2010 06:15 Go to next message
I had previously posted this question in the Babel forum ( http://www.eclipse.org/forums/index.php?t=msg&th=170247& amp;start=0&) but perhaps this is the appropriate place.
I've created a plug-in using Eclipse RCP 3.5 but needed to translate those English labels like Yes/No/Cancel/etc to my own language. In order to do that, I've downloaded the appropriate Babel language pack in
http://download.eclipse.org/technology/babel/babel_language_ packs/galileo.php
namely BabelLanguagePack-eclipse-....zip and unzipped the content to my eclipse/dropins folder. I launched the application again in Eclipse IDE and it worked, pratically all labels were translated to my language. However, when I exported my application using the export wizard and then launched it, the labels were in English again. I've tried copy/paste the content of the zip file into the directory where the application had been exported (although I wasn't sure if I was inserting exactly in the correct place) and I've tried adding the .jars as dependencies of my project but it didn't work.
Any help is appreciated. Thanks.
Ricardo Almeida
Re: Translations work well in IDE but are missing after export [message #541349 is a reply to message #541338] Sun, 20 June 2010 06:59 Go to previous messageGo to next message
Hi Ricardo,
It seems like the babel plugins are not included in your product export. If
you look in your final product plugins directory, are they included?
Best Regards,
Wim Jongman
-- As a computer, I find your faith in technology amusing.
(Eclipse Old
Skool Quote Service)
packs/galileo.php
> Ricardo Almeida
Re: Translations work well in IDE but are missing after export [message #541395 is a reply to message #541338] Sun, 20 June 2010 16:29 Go to previous messageGo to next message
Did you include the new stuff in your build.properties or .product file?
http://blog.eclipse-tips.com/2009/01/top-10-mistakes-in-ecli pse-plug-in.html
Under #5
Maarten
Ricardo schreef:
> packs/galileo.php
> Ricardo Almeida
Re: Translations work well in IDE but are missing after export [message #541463 is a reply to message #541349] Mon, 21 June 2010 05:34 Go to previous messageGo to next message
Hi Wim,
Wim Jongman wrote on Sun, 20 June 2010 06:59
No, they are not, but I just copied them into that directory but it still doesn't work. Since the .zip contained the features folder as well, I copied this one too, next to the plugins folder in my final product directory but it didn't help either.
Kind regards,
Ricardo
Re: Translations work well in IDE but are missing after export [message #541472 is a reply to message #541395] Mon, 21 June 2010 05:53 Go to previous messageGo to next message
Hi Maarten,
maarten meijer wrote on Sun, 20 June 2010 16:29
Yes, I think I did what I was supposed to do:
- in build.properties, I included the line "lib/eclipse/" under "bin.includes = ..." (because the content of .zip was extracted to a folder called lib, which is inside my project's folder)
- in .product file and under the Dependencies tab, I clicked "Add necessary plugins" and some (but only 20 of a total of 215 that came in the .zip) of the babel language plugins were automatically added.
Best
Ricardo
Re: Translations work well in IDE but are missing after export [message #541477 is a reply to message #541472] Mon, 21 June 2010 06:11 Go to previous message
Problem solved!
I appears that I also had to add "lib/eclipse/plugins" (the folder where the babel plugins are) to the classpath, in the Runtime tab. I don't understand why Eclipse can't have 1 place where we list all the dependencies of the application and that's it..
Thanks!
Ricardo
Previous Topic:Tableviewer hide lines at empty rows
Next Topic:IObjectActionDelegate + ISelction filtering
Current Time: Sun Jul 27 12:00:02 EDT 2025
Powered by FUDForum. Page generated in 0.03291 seconds
