Home » Modeling » M2T (model-to-text transformation) » How to create an static function with an annotation in Model?
How to create an static function with an annotation in Model? [message #541144] Fri, 18 June 2010 09:12 Go to next message
I would like to use the XTEXT Postprocessor to create a static function on an Object, which I can use later in xtend.
At the moment I'm using the following code to create the method.
private create EOperation createToStringOperation():
setName("getName") ->
setEType(mapTypeName("String")) ->
setEParameters( { createFieldParameter() } ) ->
setEAnnotations( { createToStringAnnotation() })
private create EParameter createFieldParameter():
setName("field") ->
setEType(mapTypeName("JavaObject"))
private create EAnnotation createToStringAnnotation():
setSource("http://www.eclipse.org/emf/2002/GenModel") ->
setDetails( { createToStringAnnDetail() } )
private create EStringToStringMapEntry createToStringAnnDetail():
setKey("body") ->
setValue('
String name = null;
if (this instanceof com.bttg.meta_model.btc.btc.LocalField) {
name = ((com.bttg.meta_model.btc.btc.LocalField) this).getName();
} else if (this instanceof com.bttg.meta_model.btc.btc.OverrideField) {
name = ((com.bttg.meta_model.btc.btc.OverrideField) this).getField().getName();
} else if (this instanceof com.bttg.meta_model.btc.btc.VirtualField) {
name = ((com.bttg.meta_model.btc.btc.VirtualField) this).getName();
} else
throw new IllegalArgumentException("Not a known field type");
return name;
This works almost fine. The only problem is that the method created is not static, and therefore not usable as XTEND extension.
Any Idea how can I make the method static?
Re: How to create an static function with an annotation in Model? [message #541416 is a reply to message #541144] Mon, 21 June 2010 00:59 Go to previous message
It's a member of one of your EClasses. If you have an instance of that
class you can call the EOperation. I think that's even better than
having it static.
Sven
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Previous Topic:[Xpand] typesystem.uml2 confuses xpand editor
Next Topic:[Acceleo] Debugging an acceleo module
Current Time: Mon Jul 21 06:06:06 EDT 2025
Powered by FUDForum. Page generated in 0.27133 seconds
