Home » Eclipse Projects » Rich Client Platform (RCP) » My AbstractDecoratedTextEditor doesn't respond to forward delete
My AbstractDecoratedTextEditor doesn't respond to forward delete [message #536964] Mon, 31 May 2010 13:20 Go to next message
I discovered today my TextEditor (public class SceneEditor extends AbstractDecoratedTextEditor {... ) does not respond to the DEL key and to several other related commands (e.g.: CTRL+D).
I did not change anything from defaults (willingly, I mean!).
Nearest thing (copied from somewhere) is:
public SceneEditor(World world) {
super();
// make sure we inherit all the text editing commands (delete line etc).
setKeyBindingScopes(new String[] { "org.eclipse.ui.textEditorScope" }); //$NON-NLS-1$
configureInsertMode(SMART_INSERT, false);
setSourceViewerConfiguration(new SceneConfiguration(world, getPreferenceStore()));
setDocumentProvider(new SceneDocumentProvider());
but that's not the problem since removing *all* customization I still have the same behavior.
I tried Snipped25 and Snippet165 and they both perform as expected (forward delete works).
Where should I look?
I have no idea how these things are implemented.
Mauro
Re: My AbstractDecoratedTextEditor doesn't respond to forward delete [message #539949 is a reply to message #536964] Mon, 14 June 2010 07:20 Go to previous messageGo to next message
I can understand that Ctrl+D is not working but Delete should always
work. Maybe you forgot to provide a correct action contributor class
when defining your editor in the plugin.xml, e.g.
contributorClass="org.eclipse.ui.editors.text.TextEditorActionContributor "
Dani
> super();
> Thanks
> Mauro
Re: My AbstractDecoratedTextEditor doesn't respond to forward delete [message #539998 is a reply to message #539949] Mon, 14 June 2010 10:14 Go to previous messageGo to next message
I had a problem in that department.
Unfortunately adding:
<editor
class="it.condarelli.writer.editors.SceneEditor"
icon="icons/16/EditPages.png"
id="it.condarelli.writer.editors.SceneEditor"
name="Scene Editor">
</editor>
Does *not* change the behavior.
DEL key is not recognized.
I put a breakpoint at org.eclipse.ui.editors.text.TextEditorActionContributor()
This constructor is *not* called.
Any idea about what I can/should check?
I should note This is a rather peculiar TextEditor (public class SceneEditor extends AbstractDecoratedTextEditor) having a custom DocumentProvider (public class SceneDocumentProvider extends AbstractDocumentProvider) and a custom EditorInput (public class SceneEditorInput implements IEditorInput) because I'm editing a (possibly very long) String contained in my EMF Model.
Can this be related? (I could have forgotten something).
TiA
Mauro
> Dani
>> super();
>> }); //$NON-NLS-1$
>> Thanks
>> Mauro
Re: My AbstractDecoratedTextEditor doesn't respond to forward delete [message #540009 is a reply to message #539998] Mon, 14 June 2010 10:47 Go to previous messageGo to next message
> <editor
> </editor>
If that's the case then something is badly broken. Are you sure the
latest code is used when you try it out? However, pressing 'Delete'
should even work without that contributor.
Dani
> TiA
> Mauro
>> Dani
>>> super();
>>> }); //$NON-NLS-1$
>>> Thanks
>>> Mauro
Re: My AbstractDecoratedTextEditor doesn't respond to forward delete [message #540020 is a reply to message #540009] Mon, 14 June 2010 11:22 Go to previous messageGo to next message
>> Thanks,
>> <editor
>> </editor>
> Dani
One thing that *might* be relevant:
As said I use this TextEditor as a sub-editor to edit a String.
Thus it is never instantiated from the normal workbench machinery.
I instantiate it explicitly while building a custom FormPage:
editor = new SceneEditor(world);
try {
IEditorSite site = new MultiPageEditorSite(getEditor(), editor);
editor.init(site, editorInput);
editor.createPartControl(scrolledForm.getBody());
Object o = editor.getAdapter(StyledText.class);
styledText = (StyledText) o;
managedForm.getToolkit().paintBordersFor(styledText);
} catch (PartInitException e) {
Text txt = managedForm.getToolkit().createText(composite, "chapter", SWT.MULTI);
txt.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true, 1, 1));
StringBuilder sb = new StringBuilder();
sb.append(e.getMessage());
sb.append("\n\n");
StringWriter w = new StringWriter();
PrintWriter pw = new PrintWriter(w);
e.printStackTrace(pw);
sb.append(w.getBuffer());
txt.setText(sb.toString());
public static final String ID = "it.condarelli.writer.editors.SceneEditor"; //$NON-NLS-1$
super();
I cleaned all the involved projects, deleted the run configurations and the runtime directories.
The behavior remains.
I have a rather cryptic .log file:
!SESSION 2010-06-14 17:15:35.275 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_20
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
Framework arguments: -product Writer.product
Command-line arguments: -product Writer.product -data C:\Users\mauro\workspace/../runtime-Writer.product -dev file:C:/Users/mauro/workspace/.metadata/.plugins/org.eclipse .pde.core/Writer.product/dev.properties -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 4 4 2010-06-14 17:15:51.276
!MESSAGE Reference item additions not found for action null
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
I' rather desperate by now.
This is my first non-token RCP project, so I might heve done *BIG* mistakes.
Thanks for Your patience.
Mauro
>> TiA
>> Mauro
>>> Dani
>>>> super();
>>>> etc).
>>>> }); //$NON-NLS-1$
>>>> Thanks
>>>> Mauro
Re: My AbstractDecoratedTextEditor doesn't respond to forward delete [message #540044 is a reply to message #540020] Mon, 14 June 2010 12:33 Go to previous messageGo to next message
>>> Thanks,
>>> <editor
>>> </editor>
>> Dani
But it's in a multi-page editor, right? In that case you need to make
sure that the correct contributor is uses when that page is active, see
MultiPageEditorActionBarContributor.
Dani
> try {
> sb.append("\n\n");
> super();
> Regards
> Mauro
>>> TiA
>>> Mauro
>>>> Dani
>>>>> super();
>>>>> etc).
>>>>> }); //$NON-NLS-1$
>>>>> Thanks
>>>>> Mauro
Re: My AbstractDecoratedTextEditor doesn't respond to forward delete [message #540195 is a reply to message #540044] Tue, 15 June 2010 06:44 Go to previous messageGo to next message
>>>>> always work. Maybe you forgot to provide a correct action
>>>>> contributor class when defining your editor in the plugin.xml, e.g.
>>>> Thanks,
>>>> <editor
>>>> </editor>
>>> Dani
Uhm...
I begin to see my (probably huge) problem.
Please confirm:
I am using a whole editor (SceneEditor extends
AbstractDecoratedTextEditor) as a Composite in a FormPage among other
(simpler) widgets.
This apparently works (the page is displayed exactly as I need it and
the editor is mostly working, including partitioning, syntax
highlighting, content assistance, ...), but I fear I'm missing some
initialization.
For sure I do not do anything like a custom
Is there a way to make it work or should I change everything? (I hope not!)
Mauro
> Dani
>> try {
>> SWT.MULTI);
>> sb.append("\n\n");
>> super();
>> }); //$NON-NLS-1$
>> mistakes.
>> Regards
>> Mauro
>>>> TiA
>>>> Mauro
>>>>> Dani
>>>>>> super();
>>>>>> etc).
>>>>>> Thanks
>>>>>> Mauro
Re: My AbstractDecoratedTextEditor doesn't respond to forward delete [message #540206 is a reply to message #540195] Tue, 15 June 2010 07:09 Go to previous messageGo to next message
>>>>> Thanks,
>>>>> <editor
>>>>> </editor>
>>>> Dani
> Uhm...
> Please confirm:
> (simpler) widgets.
> initialization.
> not!)
Sure you can make it work: the PDE editors (e.g.
'org.eclipse.pde.internal.ui.editor.schema.SchemaEditor') also work that
way. The first thing you need to do is to read the Javadoc of
'org.eclipse.ui.part.MultiPageEditorPart' and understand how it works. ;-)
Dani
> Regards
> Mauro
>> Dani
>>> try {
>>> SWT.MULTI);
>>> sb.append("\n\n");
>>> super();
>>> etc).
>>> }); //$NON-NLS-1$
>>> mistakes.
>>> Regards
>>> Mauro
>>>>> TiA
>>>>> Mauro
>>>>>> Dani
>>>>>>> super();
>>>>>>> etc).
>>>>>>> Thanks
>>>>>>> Mauro
Re: My AbstractDecoratedTextEditor doesn't respond to forward delete [message #541345 is a reply to message #540206] Sun, 20 June 2010 06:24 Go to previous messageGo to next message
>>>>>> Thanks,
>>>>>> <editor
>>>>>> </editor>
>>>>> Dani
>> Uhm...
>> Please confirm:
>> (simpler) widgets.
>> initialization.
>> not!)
Sorry, I failed (to understand how I can make it work for me).
I think the root of my problem is (WorldEditorContributor extends
MultiPageEditorActionBarContributor).setActivePage(IEditorPa rt part) is
always called with part == null.
This is consistent with the way part is built:
protected IEditorPart getEditor(int pageIndex) {
Item item = getItem(pageIndex);
if (item != null) {
Object data = item.getData();
if (data instanceof IEditorPart) {
return (IEditorPart) data;
return null;
Problem is my page (class SceneEditPage2 extends FormPage implements
ISelectionListener) is not an instanceof IEditorPart but it includes,
deep inside, as a normal widget, an instance of (class SceneEditor
extends AbstractDecoratedTextEditor).
This editor is orphan of an ActionBarContributor end hence malfunctioning.
I tried following
org.eclipse.pde.internal.ui.editor.schema.SchemaEditor, but I got lost.
Can You be a bit more explicit?
I'm currently trying to refactor my code so that SceneEditPage is an
IEditorPart. I am unsure if this is necessary and/or advisable, but I
see no other way.
Thanks in Advance
Mauro
> Dani
>> Regards
>> Mauro
>>> Dani
>>>> try {
>>>> SWT.MULTI);
>>>> sb.append("\n\n");
>>>> super();
>>>> etc).
>>>> }); //$NON-NLS-1$
>>>> mistakes.
>>>> Regards
>>>> Mauro
>>>>>> TiA
>>>>>> Mauro
>>>>>>> Dani
>>>>>>>> super();
>>>>>>>> etc).
>>>>>>>> Thanks
>>>>>>>> Mauro
Re: My AbstractDecoratedTextEditor doesn't respond to forward delete [message #541347 is a reply to message #541345] Sun, 20 June 2010 06:46 Go to previous messageGo to next message
>>>>>>> Thanks,
>>>>>>> <editor
>>>>>>> </editor>
>>>>>> Dani
>>> Uhm...
>>> Please confirm:
>>> (simpler) widgets.
>>> initialization.
>>> not!)
> if (item != null) {
> return null;
UPDATE:
In the above code:
item is a CTabItem
data is null
I see nowhere a SceneEditPage2.
I am *very* confused: shouldn't the data field be handled automatically?
Should I do something about that??
TiA
Mauro
> I tried following
> see no other way.
> Thanks in Advance
> Mauro
>> Dani
>>> Regards
>>> Mauro
>>>> Dani
>>>>> try {
>>>>> SWT.MULTI);
>>>>> sb.append("\n\n");
>>>>> super();
>>>>> etc).
>>>>> }); //$NON-NLS-1$
>>>>> mistakes.
>>>>> Regards
>>>>> Mauro
>>>>>>> TiA
>>>>>>> Mauro
>>>>>>>> Dani
>>>>>>>>> super();
>>>>>>>>> etc).
>>>>>>>>> Thanks
>>>>>>>>> Mauro
Re: My AbstractDecoratedTextEditor doesn't respond to forward delete [message #541368 is a reply to message #541347] Sun, 20 June 2010 09:39 Go to previous messageGo to next message
>>>>>>>>>> extends
>>>>>>>>>> key
>>>>>>>>> e.g.
>>>>>>>> Thanks,
>>>>>>>> <editor
>>>>>>>> </editor>
>>>>>>> Dani
>>>>> see
>>>> Uhm...
>>>> Please confirm:
>>>> (simpler) widgets.
>>>> initialization.
>>>> not!)
>> if (item != null) {
>> return null;
> UPDATE:
> In the above code:
> item is a CTabItem
> data is null
> TiA
> Mauro
UPDATE2:
I managed to have this work (at least the forward-delete) by adding the
following code in my MultiPageEditorActionBarContributor:
public void setActivePage(IEditorPart part) {
if (part == null) {
IWorkbench wb = PlatformUI.getWorkbench();
IWorkbenchWindow ww = wb.getActiveWorkbenchWindow();
IWorkbenchPage wp = ww.getActivePage();
if (wp != null) {
IEditorPart ep = wp.getActiveEditor();
if (ep instanceof WorldEditor) {
WorldEditor we = (WorldEditor) ep;
IFormPage fp = we.getActivePageInstance();
if (fp instanceof SceneEditPage2) {
SceneEditPage2 sep = (SceneEditPage2) fp;
ITextEditor te = (ITextEditor)
sep.getAdapter(ITextEditor.class);
ep = te;
part = ep;
if (activeEditorPart == part)
return;
activeEditorPart = part;
But I do not understand if this is really necessary or if I'm trying to
twist the framework to do things in a wrong way (and thus asking for
trouble in the near future).
Can someone enlighten me, please
Mauro
>> malfunctioning.
>> I tried following
>> see no other way.
>> Thanks in Advance
>> Mauro
>>> Dani
>>>> Regards
>>>> Mauro
>>>>> Dani
>>>>>> try {
>>>>>> SWT.MULTI);
>>>>>> 1));
>>>>>> sb.append("\n\n");
>>>>>> super();
>>>>>> etc).
>>>>>> }); //$NON-NLS-1$
>>>>>> mistakes.
>>>>>> Regards
>>>>>> Mauro
>>>>>>>> TiA
>>>>>>>> Mauro
>>>>>>>>> Dani
>>>>>>>>>> super();
>>>>>>>>>> line
>>>>>>>>>> etc).
>>>>>>>>>> expected
>>>>>>>>>> Thanks
>>>>>>>>>> Mauro
Re: My AbstractDecoratedTextEditor doesn't respond to forward delete [message #653881 is a reply to message #541368] Fri, 11 February 2011 12:28 Go to previous message
I had the same problem and when I let the method in documentProvider return true, it works.
public boolean isModifiable(Object element) {
if (element instanceof IPathEditorInput) {
return true; // Allow to edit new files
return false;
[Updated on: Fri, 11 February 2011 12:28] by Moderator
Previous Topic:Spelling correction in hover
Next Topic:eclipse source build problem
Current Time: Fri Jul 25 23:38:08 EDT 2025
Powered by FUDForum. Page generated in 0.59438 seconds
