Home » Eclipse Projects » Plugin Development Environment (PDE) » How to create new project for OSGi jar
How to create new project for OSGi jar [message #541249] Fri, 18 June 2010 18:31 Go to next message
I use the Eclipse for RCP/Plug-in Developers.
How to create new project for OSGi jar?
Re: How to create new project for OSGi jar [message #541255 is a reply to message #541249] Fri, 18 June 2010 20:14 Go to previous messageGo to next message
A plug-in project is an OSGi project... plug-ins are the same as OSGi
bundles. What are you looking to try to do?
Chris Aniszczyk
http://aniszczyk.org
+1 860 839 2465
Re: How to create new project for OSGi jar [message #541259 is a reply to message #541255] Fri, 18 June 2010 21:27 Go to previous messageGo to next message
I want to create a new project for a OSGi jar downloaded from the internet so that it can be used by other OSGi projects.
I use Spring 2.5.6 to develop my application.
Is this correct?
Use Eclipse, New Project, Plug-in Development, Plug-in from Existing JAR Archives, OSGi framework (Equinox),
Select "Analyze library contents and add dependencies".
Execution Environment: OSGi/Minimum-1.0.
run with: an OSGi framework: standard.
Select "Unzip the JAR archives into the project".
Re: How to create new project for OSGi jar [message #606123 is a reply to message #541255] Fri, 18 June 2010 21:27 Go to previous message
Is this correct?
Previous Topic:How to create new project for OSGi jar
Next Topic:how to modify existing plugin
Current Time: Sun Jul 27 13:51:57 EDT 2025
Powered by FUDForum. Page generated in 0.03445 seconds
