Problem with Eclipse BPEL plugin and org.eclipse.jface [message #511507] |
Mon, 01 February 2010 14:37  |
Hello
Im working with Eclipse and Apache ODE (HelloWorld example). Im trying to set up de deploy params to the binding port in my ODE deploy descriptor with the Eclipse plug in and I got this error:
Problems occurred when invoking code from plug-in: "org.eclipse.jface".
stacktrace:
java.lang.LinkageError: javax/wsdl/Binding
at org.eclipse.bpel.apache.ode.deploy.ui.pages.ProcessPage$Port TypeLabelProvider.getColumnText(ProcessPage.java:648)
at org.eclipse.jface.viewers.TableColumnViewerLabelProvider.upd ate(TableColumnViewerLabelProvider.java:70)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn. java:145)
at org.eclipse.jface.viewers.AbstractTableViewer.doUpdateItem(A bstractTableViewer.java:399)
at org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:481)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:2111)
at org.eclipse.jface.viewers.AbstractTableViewer.internalRefres hAll(AbstractTableViewer.java:711)
at org.eclipse.jface.viewers.AbstractTableViewer.internalRefres h(AbstractTableViewer.java:649)
at org.eclipse.jface.viewers.AbstractTableViewer.internalRefres h(AbstractTableViewer.java:636)
at org.eclipse.jface.viewers.StructuredViewer$7.run(StructuredV iewer.java:1457)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1392)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1353)
at org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1455)
at org.eclipse.jface.viewers.ColumnViewer.refresh(ColumnViewer. java:537)
at org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1414)
at org.eclipse.bpel.apache.ode.deploy.ui.pages.ProcessPage$Inte rfaceWidgetCellModifier.modify(ProcessPage.java:444)
at org.eclipse.jface.viewers.ColumnViewer$2.setValue(ColumnView er.java:274)
at org.eclipse.jface.viewers.EditingSupport.saveCellEditorValue (EditingSupport.java:113)
at org.eclipse.jface.viewers.ColumnViewerEditor.saveEditorValue (ColumnViewerEditor.java:455)
at org.eclipse.jface.viewers.ColumnViewerEditor.applyEditorValu e(ColumnViewerEditor.java:311)
at org.eclipse.jface.viewers.ColumnViewerEditor$2.applyEditorVa lue(ColumnViewerEditor.java:153)
at org.eclipse.jface.viewers.CellEditor$1.run(CellEditor.java:3 33)
at org.eclipse.jface.viewers.CellEditor.fireApplyEditorValue(Ce llEditor.java:331)
at org.eclipse.jface.viewers.ComboBoxCellEditor.applyEditorValu eAndDeactivate(ComboBoxCellEditor.java:273)
at org.eclipse.jface.viewers.ComboBoxCellEditor.focusLost(Combo BoxCellEditor.java:284)
at org.eclipse.jface.viewers.ComboBoxCellEditor$4.focusLost(Com boBoxCellEditor.java:170)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:137)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:7 70)
at org.eclipse.swt.custom.CCombo.handleFocus(CCombo.java:844)
at org.eclipse.swt.custom.CCombo$3.handleEvent(CCombo.java:141)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:119 1)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1002)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1008)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java: 2583)
at org.eclipse.swt.widgets.Widget.wmSetFocus(Widget.java:2282)
at org.eclipse.swt.widgets.Control.WM_SETFOCUS(Control.java:457 3)
at org.eclipse.swt.widgets.Table.WM_SETFOCUS(Table.java:5898)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4014 )
at org.eclipse.swt.widgets.Table.windowProc(Table.java:5521)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4589 )
at org.eclipse.swt.internal.win32.OS.SetFocus(Native Method)
at org.eclipse.swt.widgets.Table.sendMouseDownEvent(Table.java: 3574)
at org.eclipse.swt.widgets.Table.WM_LBUTTONDOWN(Table.java:5745 )
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3981 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4602 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:24 10)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3471)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
Im thinking that's a version problem but I dont know which plugin (or jars) replace in order to fix it
Help will be awesome =D
FUDForum. Page generated in 0.07811 seconds
