Re: In my model, Class not found or is abstract [message #540814] |
Thu, 17 June 2010 08:33  |
--------------000605090900040001000302
Hi Maxime,
If I understand correctly, this is more of an EMF question than it is an
M2T question, I added the emf newsgroup to the to: list of this answer.
Laurent Goubet
Obeo
Maxime Lecourt wrote:
> I made a metamodel, where Items is my container EClass.
> part of the metamodel :
> <ecore:EPackage xmi:version="2.0"
> xmlns:xmi="http://www.omg.org/XMI"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="hla"
> nsURI="http://hla/1.0" nsPrefix="hla">
> <eClassifiers xsi:type="ecore:EClass" name="Items">
> <eStructuralFeatures xsi:type="ecore:EReference" name="entities"
> upperBound="-1"
> eType="#//HEntity" derived="true" containment="true"/>
> </eClassifiers>
> So after that I wanted to define a model
> <hla:Items xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
> xmlns:metamodel="http://www.example.org/metamodel"
> xsi:schemaLocation="http://www.example.org/metamodel metamodel/hla.ecore">
> </hla:Items>
> But I get "Class 'Items' is not found or is abstract". The most
> surprising is that it worked for a while.
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------000605090900040001000302--
Re: In my model, Class not found or is abstract [message #541086 is a reply to message #540814] |
Fri, 18 June 2010 05:45   |
From the EMF documentation, there is a tutorial, that would generate a .genmodel file, java files, and finally a library file.
Isn't there a way to generate an empty model file directly from an ecore metamodel, that I can fill with my instances ?
The EMF 2003 book seem's JAVA oriented mostly, there are examples about how to generate JAVA code, it states you can use a XMI serializer, but not how to use it.
Re: In my model, Class not found or is abstract [message #541179 is a reply to message #541086] |
Fri, 18 June 2010 10:31  |
Maxime,
From the context menu of an EClass you can invoke Create Dynamic
Instance... Both versions of the book talk about the resource framework
and how to use it; the 2nd edition has twice as much content and hence a
lot more detail.
FUDForum. Page generated in 0.43205 seconds
