Home » Archived » Buckminster » Property buckminster.build.timestamp no longer ISO-8601?
Property buckminster.build.timestamp no longer ISO-8601? [message #540851] Thu, 17 June 2010 09:27 Go to next message
prior to r11456, the buckminster.build.timestamp was supposed to be in
ISO-8601 format (as documented). However, now the format needs to be one
of the common formats:
public static final String[] commonFormats = new String[] {
"yyyy-MM-dd_HH-mm-ss", "yyyyMMddHHmm", "yyyyMMdd-HHmm", "yyyyMMdd" };
//$NON-NLS-1$ //$NON-NLS-2$ //$NON-NLS-3$ //$NON-NLS-4$
Is this intentional, or accidental and will it at some point be reverted
to ISO-8601 (or will ISO-8601 be added to those "common formats")? Note
the difference is in one line -- the new code calls timestamp =
DateAndTimeUtils.fromString((String) isoTS); while the old code called
timestamp = DateAndTimeUtils.fromISOFormat((String) isoTS);
Thanks.
--Peter
Re: Property buckminster.build.timestamp no longer ISO-8601? [message #540868 is a reply to message #540851] Thu, 17 June 2010 09:47 Go to previous messageGo to next message
Hi Peter,
That's a regression. The ISO-8601 format should still be one of the supported formats. Can you please enter a bugzilla
for this?
- thomas
On 06/17/2010 03:27 PM, Peter Nehrer wrote:
> Thanks.
> --Peter
Re: Property buckminster.build.timestamp no longer ISO-8601? [message #540942 is a reply to message #540868] Thu, 17 June 2010 12:21 Go to previous message
Ok :-)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=317211
Previous Topic:create.product failing on target platform dependency
Next Topic: ERROR [0000] : Resolution attempt ended with exception: Unauthorized
Current Time: Mon Jun 09 00:15:37 EDT 2025
Powered by FUDForum. Page generated in 0.02613 seconds
