Home » Eclipse Projects » Eclipse Platform » Excluded files from build path get exported to jar(When creating jar file with the Export to runnable jar file wizard, the excluded files are placed in a "src" directory inside the jar)
Excluded files from build path get exported to jar [message #540937] Thu, 17 June 2010 12:51 Go to next message
Hello all.
I've been searching the web (eclipse bugs and forums) but haven't been able to find a solution.
In my souce tree I have some files that I use to generate some java classes during development. I don't want these files to get into the jar file.
Normally, those files get copied into to the "bin" directory tree everytime the project gets built.
I found a way to prevent this by adding some exclusion patterns:
...go to the project->Properties->Java Build Path. Select Source tab, expand the source folder, you will see (Exclusion filters), click on it and then the "Edit" button.
Now, imagine I have a folder with some source files
src/com/mitalteli/cfd/extracted/
    somethinig.bat
    class1.java
    class2.java
If I don't put any exclusions, and run the "Export to runnable jar file wizard", the generated jar contets are:
com
    |->mitalteli
        |->cfd
            |->extracted
                something.bat
                class1.class
                class2.class
META-INF
    |->MANIFEST.MF
Ofcourse I don't want the "something.bat" there.
So I added the following exclusions:
**/*.bat
**/*.swp
**/*.xjb
Now, when I export it again, the jar contets are:
com
    |->mitalteli
        |->cfd
            |->extracted
                class1.class
                class2.class
META-INF
    |->MANIFEST.MF
src
    |->com
        |->mitalteli
            |->cfd
                |->extracted
                    something.bat
It's very wierd. As you can see, the "excluded" file is taken off the main file structure, but is then placed in a "src" direcotry.
Is this a bug? I mean. If some files are excluded from the build path, they shouldn't be added to the jar file. Am I right?
Does anybody has any pointers in order to fix this?
Any help would be very appreciated.
Ely.
[Updated on: Thu, 17 June 2010 12:54] by Moderator
Re: Excluded files from build path get exported to jar [message #541129 is a reply to message #540937] Fri, 18 June 2010 08:42 Go to previous messageGo to next message
My guess is that's deliberate, if you are generating source. What if
you don't generate source into your jar?
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Excluded files from build path get exported to jar [message #541174 is a reply to message #540937] Fri, 18 June 2010 10:30 Go to previous messageGo to next message
Ely wrote:
> Hello all.
> jar file.
> Quote:
> somethinig.bat
> class1.java
> class2.java
> com
> |->mitalteli
> |->cfd
> |->extracted
> something.bat
> class1.class
> class2.class
> META-INF
> |->MANIFEST.MF
> So I added this:
> **/*.bat
> **/*.swp
> **/*.xjb
> Now, when I add the exclusions and export it again, the jar contets are:
> com
> |->mitalteli
> |->cfd
> |->extracted
> class1.class
> class2.class
> META-INF
> |->MANIFEST.MF
> src
> |->com
> |->mitalteli
> |->cfd
> |->extracted
> something.bat
No, you are wrong. Build path means it's used to to execute but
'something.bat' might be a simple file that's read by your code. The
exporter cannot have any clue about this. If you want to control this
then you'd better use the 'JAR file' exporter where you can select the
individual resources.
Dani
> Ely.
Re: Excluded files from build path get exported to jar [message #541509 is a reply to message #541129] Mon, 21 June 2010 08:30 Go to previous messageGo to next message
PW
Paul Webster
Thank you for answering Paul.
Well... There is no "src" directory unles I add the exclusion rules. I was searching for an option to disable source inclusion in the jar, but couldn't find it.
Do you happen to know where is it if it exists?
Thanks in advance.
Ely.
EDIT: I've just found the eclipse 3.1 has a checkbox for including the source in the jar. Bit I'm Using the Eclipse IDE for Java EE Developers version 1.2.1 and that's why it doesn't have one. (I guess)
[Updated on: Mon, 21 June 2010 09:28] by Moderator
Re: Excluded files from build path get exported to jar [message #541514 is a reply to message #541174] Mon, 21 June 2010 08:41 Go to previous message
Hello Dani.
Thank you for taking the time to answering my questions.
Dani
Hmmm....
I'm not sure I agree. I don't understand why you say the "build" path has any thing to do with the application execution.
As far as I can tell, the "build path" is used to find all the resources needed to complile-link-pack a project wen converting it to executable. Isn't it right? Not the execution itself.
For instance, if you see the eclipse's help, you will find:
Java Build Path
The options in this page indicate the build path settings for a Java project.
The build class path is a list of paths visible to the compiler when building the project.
That's exactly why I was thinking that if I make an exclusion there, those files shouldn't be added to the final jar, as they shouldn't be used when building it.
If there is no other way, I'll find a way to build my jar manually. But I hope there is a better way.
Any other ideas?
Ely.
EDIT: No, I wasn't entirely right. You are right when you say that those files could be used by the application while running, and that's why the jar creation couldn't know if it had to include them or not.
But I still don't know why it creates a src directory when those files are excluded from the building process.
[Updated on: Mon, 21 June 2010 09:00] by Moderator
Previous Topic:change locale at runtime
Next Topic:ActionDelegateHandlerProxy and isEnabled
Current Time: Sat Jul 26 23:35:41 EDT 2025
Powered by FUDForum. Page generated in 0.25286 seconds
