Home » Archived » Buckminster » ERROR [0000] : Resolution attempt ended with exception: Unauthorized
ERROR [0000] : Resolution attempt ended with exception: Unauthorized [message #540902] Thu, 17 June 2010 11:08 Go to next message
During materialization of the bundles I get error ERROR [0000] : Resolution attempt ended with exception: Unauthorized, I am not sure what is the nature of this error so I was hoping someone could help understanding this.
Also, as I was looking through the debug logs during materialization I see something that looks strange to me. I want get bundle com.iwaysoftware.logging into my workspace and this is what I see:
com.iwaysoftware.logging:osgi.bundle: Using resource map file:/home/akravets2/dev/workspaces/pluto.build/com.iwaysoft ware.integration.tools.site/site.local.rmap
com.iwaysoftware.logging:osgi.bundle: Using search path resources
com.iwaysoftware.logging:osgi.bundle: Trying provider local({0}/dependencies/trunk/{1})
com.iwaysoftware.logging:osgi.bundle: Found match
com.iwaysoftware.logging:osgi.bundle: Using provider local({0}/dependencies/trunk/{1})
This is fine, but then later on I see this:
com.iwaysoftware.logging:osgi.bundle: Resolution attempt ended with exception: Unauthorized
com.iwaysoftware.logging:osgi.bundle: Trying provider local({0}/Explorer/trunk/plugins/{1})
com.iwaysoftware.logging:osgi.bundle: Using provider local({0}/Explorer/trunk/plugins/{1})
Which I find weird because this plugin is not in directory where I see message 'Found Match', unless I don't fully understand meaning of this message.
Lastly, this is the Unauthorized message that I interested in:
com.iwaysoftware.logging:osgi.bundle: No provider was found that could resolve the request
ERROR [0000] : No suitable provider for component com.iwaysoftware.logging:osgi.bundle was found in resourceMap file:/home/akravets2/dev/workspaces/pluto.build/com.iwaysoft ware.integration.tools.site/site.local.rmap
ERROR [0000] : No suitable provider for component com.iwaysoftware.logging:osgi.bundle was found in searchPath resources
ERROR Unauthorized
ERROR Unauthorized
ERROR Unauthorized
ERROR Unauthorized
thanks for your help,
Alex
Re: ERROR [0000] : Resolution attempt ended with exception: Unauthorized [message #540935 is a reply to message #540902] Thu, 17 June 2010 12:44 Go to previous message
I asked folks on IRC channel about this, the suggestion was that it's likely an svn authentication issue which it turns out it was.
Re: ERROR [0000] : Resolution attempt ended with exception: Unauthorized [message #540943 is a reply to message #540902] Thu, 17 June 2010 12:26 Go to previous message
Turned out that the issue (most likely) was caused by local SVN issues.
The error message has been improved in 3.6.
- henrik
On 6/17/10 5:08 PM, Alex wrote:
> Hello,
> understanding this.
> Quote:
> Quote:
> message.
> Quote:
>> resolve the request
>> ERROR Unauthorized
>> ERROR Unauthorized
>> ERROR Unauthorized
>> ERROR Unauthorized
> Alex
Previous Topic:Property buckminster.build.timestamp no longer ISO-8601?
Next Topic:Generating feature version suffixes
Current Time: Sat Jul 26 14:52:21 EDT 2025
Powered by FUDForum. Page generated in 0.24904 seconds
