Home » Eclipse Projects » Eclipse Platform » empty run menu visible after disabling all related actions
empty run menu visible after disabling all related actions [message #540884] Thu, 17 June 2010 10:24 Go to next message
I've used an activity that is always disabled in my product to make sure
that none of the available Run options is visible to the user. Unfortunately
this leaves an empty "Run" menu in the menu bar and so far I haven't found a
a way of removing it using the activity.
Did somebody else ever run into this and/or knows a solution (that doesn't
involve removing the menucontribution programmatically)?
Andreas
Re: empty run menu visible after disabling all related actions [message #541002 is a reply to message #540884] Thu, 17 June 2010 20:00 Go to previous messageGo to next message
Check out the "org.eclipse.ui.perspectiveExtensions" extension point's
"hiddenMenuItem" element. Specify a perspective id (or * for all) and a
command id to hide that command's associated menu item in that
perspective. Use Menu Spy, ALT+SHIFT+F2 to find the command id.
Craig
On Thu, 17 Jun 2010 16:24:21 +0200, Andreas Pakulat wrote:
> Unfortunately this leaves an empty "Run" menu in the menu bar and so far
> I haven't found a a way of removing it using the activity.
> doesn't involve removing the menucontribution programmatically)?
> Andreas
Re: empty run menu visible after disabling all related actions [message #541545 is a reply to message #541002] Mon, 21 June 2010 09:15 Go to previous message
Well, the problem is that I can't seem to find any command that contributes
the entry "Run" in the menubar of Eclipse. The spy doesn't seem to work for
these menubar entries, only in submenus and using the menu-id I gathered
from org.eclipse.debug.ui/plugin.xml doesn't have any effect.
Andreas
Previous Topic:ActionDelegateHandlerProxy and isEnabled
Next Topic:API to create a plug-in programmatically
Current Time: Sat Jul 26 13:21:07 EDT 2025
Powered by FUDForum. Page generated in 0.06455 seconds
