Home » Modeling » M2T (model-to-text transformation) » [Xpand] Optimize succeeding workflow calls
[Xpand] Optimize succeeding workflow calls [message #540774] Thu, 17 June 2010 06:54 Go to next message
I am using the org.eclipse.emf.mwe.core.WorkflowRunner class to execute a workflow and generate text via Xpand.
This class offers two methods:
* prepare
* executeWorkflow
In my situation, I want to execute the same workflow multiple times.
In order to gain performance, I intend to call "prepare" only once and then call "executeWorkflow" multiple times.
(But this seems not possible out of the box. Should it?)
As input I pass the same EMF model instance (created via Xtext) via slot. The model contents however changes from call to call, as the user enters new data in the Xtext-Editor.
In order to achieve this, I have to clear/reset the internal memory (hashtable?) where data is stored concerning the results of Xtend-methods marked with the keywords "create" or "cached".
Is there a way to reset this storage manually or perhaps a flag you can set before calling executeWorkflow?
Any help is appreciated Smile
Note:
I came across another problem but was able to avoid it:
The Xpand-Component throws exceptions as it tries to register the same outlets again and again each call of "invoke".
Kind regards
Ludwig
Re: [Xpand] Optimize succeeding workflow calls [message #540823 is a reply to message #540774] Thu, 17 June 2010 08:56 Go to previous messageGo to next message
I think it would be best not to use the old mwe in this case, but
directly call Xpand (through XpandFacade).
If you release the ExecutionContext, i.e. create a new one on each
invocation the caches will be empty.
Sven
Ludwig Straub schrieb:
> Hello,
> * prepare
> * executeWorkflow
> Any help is appreciated :)
> Note:
> Kind regards
> Ludwig
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: [Xpand] Optimize succeeding workflow calls [message #540846 is a reply to message #540774] Thu, 17 June 2010 09:39 Go to previous messageGo to next message
Thank you for the quick answer and the hint.
The old mwe workflow contains quite a few other components beside the Xpand-Component.
Also ist should be callable via command line.
Therefore a drawback to use the XpandFacade is not ideal for the situation.
An upgrade to mwe2 however would be possible.
I will use your input to continue my investigation on this topic and will post the result.
Thanks again.
Kind regards
Ludwig
Re: [Xpand] Optimize succeeding workflow calls [message #541047 is a reply to message #540846] Fri, 18 June 2010 03:31 Go to previous messageGo to next message
> Xpand-Component.
MWE2 won't solve the problem, since it is not related to mwe but to Xpand.
Xpand uses a so called ExecutionContext and the Workflow component
written for Xpand creates one once and not on each call a new one,
you'll have to patch that.
Can be done by creating a subclass and overrideing the respective methods.
Sven
Re: [Xpand] Optimize succeeding workflow calls [message #541191 is a reply to message #540774] Fri, 18 June 2010 11:28 Go to previous message
Hi Sven,
ok, thank you.
I will do it this way.
Kind regards
Ludwig
Previous Topic:[Acceleo] Launching a module from Java
Next Topic:[Xpand] typesystem.uml2 confuses xpand editor
Current Time: Sat Jul 26 19:08:09 EDT 2025
Powered by FUDForum. Page generated in 0.06601 seconds
