Home » Modeling » M2T (model-to-text transformation) » [Xpand]duplication problem in html report
[Xpand]duplication problem in html report [message #540825] Thu, 17 June 2010 08:58 Go to next message
I am generating a html report using Xpand. I have defined different tables for package, Class and Interaction. The problem is that class table includes the value of Interaction too. here is my Xpand templates :
«IMPORT uml»
«DEFINE main FOR Model»
	«EXPAND templates::one::root»
«ENDDEFINE»
«DEFINE root FOR Model»
«FILE "test.html"»
 <H2> Table 1</H2>
  	<TABLE BORDER="1">
  		<tr>
  			<th rowspan="2" >Name</th>
  			<th>C1</th>
	      	<th >C2</th>
	     </tr><tr>
	      	«EXPAND test FOREACH eAllContents.typeSelect(Package)»
 </tr>
 </TABLE>
 <H2> Table 2</H2>
<TABLE BORDER="1">
  		<tr>
	        <th >C1</th>
	      	<th >C2</th>
	    </tr><tr>
	      	«EXPAND test FOREACH eAllContents.typeSelect(uml::Class)»
	</tr>
	</table>
	<H1>Table 3</H1>
<TABLE BORDER="1">
  		<tr>
	        <th >C1</th>
	      	<th >C2</th>
	     </tr><tr>
			«EXPAND test FOREACH eAllContents.typeSelect(Interaction)»
	</tr>
 </table>
</body>
</html>
«ENDFILE»
«ENDDEFINE»
«DEFINE test FOR uml::Package »
	    <tr>
	     	  	<td>«qualifiedName»</td>
	     	  	<td>pkg value 1</td>
     			<td>pakg value 2</td>
	    </tr>
«ENDDEFINE»
«DEFINE test FOR uml::Class»
     	 <tr>
     			<td>Class value 1</td>
     			<td>Class value 2</td>
	    </tr>
«ENDDEFINE»
«DEFINE test FOR uml::Interaction»
     	 <tr>
  			<td>SD value 1</td>
     		<td>SD value 2</td>
	     </tr>
«ENDDEFINE»
result shows SD value 1 and SD Value 2 in Interaction table as well as in Class table. My question is How can I avoid Interaction values from class table.
regards,
Akhtar
Re: [Xpand]duplication problem in html report [message #540845 is a reply to message #540825] Thu, 17 June 2010 09:32 Go to previous messageGo to next message
uml:: Interaction inherits from uml::Class so you get the interactions with
so you have to aditionally filter out the Interactions
e.g. like
eAllContents.typeSelect(uml::Class).reject(e|Interation.isInstance(e))
Re: [Xpand]duplication problem in html report [message #540867 is a reply to message #540845] Thu, 17 June 2010 09:57 Go to previous message
Thanks for the reply. It works fine with your solution.
I tried with anotherway and it works too.
eAllContents.typeSelect(uml::Class).reject(e|e.metaType == uml::Interaction)
regards,
Akhtar
Previous Topic:Accessing a set that's actually a sequence
Next Topic:In my model, Class not found or is abstract
Current Time: Mon Nov 03 19:40:10 EST 2025
Powered by FUDForum. Page generated in 0.04840 seconds
