Home » Eclipse Projects » Buckminster dev » Building macosx .zip's for an RCP app fails
Building macosx .zip's for an RCP app fails [message #533965] Mon, 17 May 2010 11:06 Go to next message
When trying to build macosx .zip's for my rcp product Buckminster fails at creating a proper site.p2:
INFO:  [start com.froglogic.squish.ide.bucky:eclipse.feature$1.0.0.qualifier#site.p2]
java.io.FileNotFoundException: /tmp/p2.brandingIron5125420708367173975/squishide.app/Contents/MacOS/squishide.ini (No such file or directory)
	at java.io.FileInputStream.open(Native Method)
	at java.io.FileInputStream.<init>(FileInputStream.java:106)
	at org.eclipse.equinox.internal.p2.core.helpers.FileUtils.zipFile(FileUtils.java:357)
	at org.eclipse.equinox.internal.p2.core.helpers.FileUtils.zip(FileUtils.java:286)
	at org.eclipse.equinox.internal.p2.core.helpers.FileUtils.zip(FileUtils.java:251)
	at org.eclipse.equinox.p2.publisher.AbstractPublisherAction.publishArtifact(AbstractPublisherAction.java:469)
	at org.eclipse.equinox.p2.publisher.eclipse.EquinoxExecutableAction.publishExecutableIU(EquinoxExecutableAction.java:129)
	at org.eclipse.equinox.p2.publisher.eclipse.EquinoxExecutableAction.perform(EquinoxExecutableAction.java:66)
	at org.eclipse.equinox.p2.publisher.eclipse.ApplicationLauncherAction.perform(ApplicationLauncherAction.java:68)
	at org.eclipse.equinox.p2.publisher.eclipse.ProductAction.perform(ProductAction.java:91)
	at org.eclipse.buckminster.pde.tasks.ProductAction.perform(ProductAction.java:122)
	at org.eclipse.equinox.p2.publisher.Publisher$ArtifactProcess.run(Publisher.java:207)
	at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.executeBatch(SimpleArtifactRepository.java:1044)
	at org.eclipse.equinox.p2.publisher.Publisher.publish(Publisher.java:231)
	at org.eclipse.buckminster.pde.internal.actor.P2SiteGenerator.run(P2SiteGenerator.java:329)
	at org.eclipse.buckminster.pde.internal.actor.P2SiteGenerator.internalPerform(P2SiteGenerator.java:426)
	at org.eclipse.buckminster.core.actor.AbstractActor.perform(AbstractActor.java:186)
	at org.eclipse.buckminster.core.internal.actor.PerformManager$DirectActionInvocation.execute(PerformManager.java:143)
	at org.eclipse.buckminster.core.internal.actor.PerformManager.internalPerform(PerformManager.java:454)
	at org.eclipse.buckminster.core.internal.actor.PerformManager.perform(PerformManager.java:293)
	at org.eclipse.buckminster.core.internal.actor.PerformManager.perform(PerformManager.java:305)
	at org.eclipse.buckminster.core.commands.Perform.internalRun(Perform.java:108)
	at org.eclipse.buckminster.core.commands.WorkspaceCommand.run(WorkspaceCommand.java:91)
	at org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(AbstractCommand.java:194)
	at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:317)
	at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:136)
	at org.eclipse.buckminster.cmdline.Headless.start(Headless.java:156)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
INFO:  [end com.froglogic.squish.ide.bucky:eclipse.feature$1.0.0.qualifier#site.p2]
This is with a fresh buckminster 3.6 in hudson. I can reproduce it running buckminster from Eclipse too, though I don't get such an extensive error
message there.
Re: Building macosx .zip's for an RCP app fails [message #540611 is a reply to message #533965] Wed, 16 June 2010 12:43 Go to previous message
Hi Andreas,
the reason for that is a problem in the p2 publisher.
Please vote for the following bugs:
* https://bugs.eclipse.org/bugs/show_bug.cgi?id=315962
* https://bugs.eclipse.org/bugs/show_bug.cgi?id=278909
* https://bugs.eclipse.org/bugs/show_bug.cgi?id=291045
* https://bugs.eclipse.org/bugs/show_bug.cgi?id=305143
* https://bugs.eclipse.org/bugs/show_bug.cgi?id=300382
Axel
> INFO: [start
> com.froglogic.squish.ide.bucky:eclipse.feature$1.0.0.qualifi er#site.p2]
/tmp/p2.brandingIron5125420708367173975/squishide.app/Conten ts/MacOS/squishide.ini
> (No such file or directory) at java.io.FileInputStream.open(Native Method)
> at java.io.FileInputStream.<init>(FileInputStream.java:106) at
org.eclipse.equinox.internal.p2.core.helpers.FileUtils.zipFi le(FileUtils.java:357)
> at
org.eclipse.equinox.internal.p2.core.helpers.FileUtils.zip(F ileUtils.java:286)
> at
org.eclipse.equinox.internal.p2.core.helpers.FileUtils.zip(F ileUtils.java:251)
> at
org.eclipse.equinox.p2.publisher.AbstractPublisherAction.pub lishArtifact(AbstractPublisherAction.java:469)
> at
org.eclipse.equinox.p2.publisher.eclipse.EquinoxExecutableAc tion.publishExecutableIU(EquinoxExecutableAction.java:129)
> at
org.eclipse.equinox.p2.publisher.eclipse.EquinoxExecutableAc tion.perform(EquinoxExecutableAction.java:66)
> at
org.eclipse.equinox.p2.publisher.eclipse.ApplicationLauncher Action.perform(ApplicationLauncherAction.java:68)
> at
org.eclipse.equinox.p2.publisher.eclipse.ProductAction.perfo rm(ProductAction.java:91)
> at
org.eclipse.buckminster.pde.tasks.ProductAction.perform(Prod uctAction.java:122)
> at
org.eclipse.equinox.p2.publisher.Publisher$ArtifactProcess.r un(Publisher.java:207)
> at
org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.executeBatch(SimpleArtifactRepositor y.java:1044)
> at org.eclipse.equinox.p2.publisher.Publisher.publish(Publisher .java:231)
> at
org.eclipse.buckminster.pde.internal.actor.P2SiteGenerator.r un(P2SiteGenerator.java:329)
> at
org.eclipse.buckminster.pde.internal.actor.P2SiteGenerator.i nternalPerform(P2SiteGenerator.java:426)
> at
org.eclipse.buckminster.core.actor.AbstractActor.perform(Abs tractActor.java:186)
> at
org.eclipse.buckminster.core.internal.actor.PerformManager$D irectActionInvocation.execute(PerformManager.java:143)
> at
org.eclipse.buckminster.core.internal.actor.PerformManager.i nternalPerform(PerformManager.java:454)
> at
org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:293)
> at
org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:305)
> at
org.eclipse.buckminster.core.commands.Perform.internalRun(Pe rform.java:108)
> at
org.eclipse.buckminster.core.commands.WorkspaceCommand.run(W orkspaceCommand.java:91)
> at
org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(Abs tractCommand.java:194)
> at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:3 17) at
> org.eclipse.buckminster.cmdline.Headless.run(Headless.java:1 36) at
> org.eclipse.buckminster.cmdline.Headless.start(Headless.java :156) at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
> at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
> at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at
> at
> at java.lang.reflect.Method.invoke(Method.java:597) at
> org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619) at
> org.eclipse.equinox.launcher.Main.basicRun(Main.java:574) at
> org.eclipse.equinox.launcher.Main.run(Main.java:1407) at
> INFO: [end
> message there.
Previous Topic:RE: [buckminster-dev] create.eclipse.jnlp.product issues
Next Topic:[buckminster-dev] Project meta data is out of date for tools.buckminster
Current Time: Sat Aug 30 23:09:40 EDT 2025
Powered by FUDForum. Page generated in 0.03985 seconds
