Home » Eclipse Projects » Plugin Development Environment (PDE) » Extracting plug-in jar in exported product
Extracting plug-in jar in exported product [message #540510] Wed, 16 June 2010 08:37 Go to next message
I have several plug-ins I want to export as a Product and run headless on the command line. This all works well, but then I have a problems during runtime: some of my plug-ins get extracted in the product's plugin folder while some remain inside JARs. How can I control this behavior? When exporting features, I can select which plug-ins get extracted within the feature.xml, but I didn't find a similar mechanism for Products.
If you wonder why I need the plug-in archive to be extracted, here's the reason:
org.eclipse.core.runtime.CoreException: Problems encountered while setting project description.
        at org.eclipse.core.internal.resources.Project.setDescription(Project.java:1056)
        at org.eclipse.core.internal.resources.Project.setDescription(Project.java:1082)
        at de.fb12.gdt2.core.gt4.gt40.GT40Nature.addNature(GT40Nature.java:65)
        at de.fb12.gdt2.core.gt4.gt40.AddServiceToProject.addServiceToProject(AddServiceToProject.java:146)
        at de.fb12.gdt2.core.gt4.gt40.AddServiceToProject.addServiceToProject(AddServiceToProject.java:92)
        at de.fb12.gdt2.headless.gt4.gt40.GT40HeadlessRunner.generate(GT40HeadlessRunner.java:291)
        at de.fb12.gdt2.headless.gt4.gt40.GT40HeadlessRunner.run(GT40HeadlessRunner.java:231)
        at de.fb12.gdt2.headless.HeadlessRunner.start(HeadlessRunner.java:98)
        at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
        at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
        at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Contains: Error configuring nature 'de.fb12.gdt2.core.gt4.gt40.GT40Nature'.
org.eclipse.jdt.internal.core.ClasspathEntry$AssertionFailedException: Path for IClasspathEntry must be absolute: file:/srv/www/MAGE/gdt/iHeadless/eclipse/plugins/de.fb12.gdt2.core.gt4_1.0.0.201006161359.jar!/annotations/gt4_annotations.jar
        at org.eclipse.jdt.core.JavaCore.newLibraryEntry(JavaCore.java:4042)
        at org.eclipse.jdt.core.JavaCore.newLibraryEntry(JavaCore.java:3917)
        at de.fb12.gdt2.core.gt4.nature.AnnotationClasspathContainerInitializer$1.getClasspathEntries(AnnotationClasspathContainerInitializer.java:74)
        at org.eclipse.jdt.internal.core.JavaModelManager.containerPutIfInitializingWithSameEntries(JavaModelManager.java:630)
        at org.eclipse.jdt.internal.core.SetContainerOperation.executeOperation(SetContainerOperation.java:49)
        at org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaModelOperation.java:728)
        at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1800)
        at org.eclipse.jdt.internal.core.JavaModelOperation.runOperation(JavaModelOperation.java:793)
        at org.eclipse.jdt.internal.core.JavaModelManager.getClasspathContainer(JavaModelManager.java:1816)
        at org.eclipse.jdt.core.JavaCore.getClasspathContainer(JavaCore.java:2652)
        at org.eclipse.jdt.internal.core.JavaProject.resolveClasspath(JavaProject.java:2578)
        at org.eclipse.jdt.internal.core.ClasspathEntry.validateClasspath(ClasspathEntry.java:1528)
        at org.eclipse.jdt.internal.core.SetClasspathOperation.verify(SetClasspathOperation.java:105)
        at org.eclipse.jdt.internal.core.JavaModelOperation.runOperation(JavaModelOperation.java:782)
        at org.eclipse.jdt.internal.core.JavaProject.setRawClasspath(JavaProject.java:2890)
        at org.eclipse.jdt.internal.core.JavaProject.setRawClasspath(JavaProject.java:2921)
        at de.fb12.gdt2.core.gt4.gt40.GT40Nature.configure(GT40Nature.java:176)
        at org.eclipse.core.internal.resources.NatureManager$1.run(NatureManager.java:143)
        at org.eclipse.core.internal.resources.NatureManager.configureNature(NatureManager.java:158)
        at org.eclipse.core.internal.resources.NatureManager.configureNatures(NatureManager.java:203)
        at org.eclipse.core.internal.resources.Project.basicSetDescription(Project.java:84)
        at org.eclipse.core.internal.resources.Project.setDescription(Project.java:1054)
I need to add the annotations.jar to the runtime classpath inside my JDT instance (within the running headless product) to compile something... Or is there another way around this?
Cheers
Marian
Re: Extracting plug-in jar in exported product [message #540588 is a reply to message #540510] Wed, 16 June 2010 11:17 Go to previous message
Try adding
Eclipse-BundleShape: dir
to the manifest of any plug-in that you want to be a folder.
Marian Harbach wrote:
Previous Topic:How to extend Eclipse's compare context menu?
Next Topic:Extracting plug-in jar in exported product
Current Time: Sun Jul 27 01:53:53 EDT 2025
Powered by FUDForum. Page generated in 0.16060 seconds
