Home » Language IDEs » ServerTools (WTP) » Open Declaration editor settings(Can the editor opened by Open Declaration be modified)
Open Declaration editor settings [message #540568] Wed, 16 June 2010 10:29 Go to next message
When I use the Open Declaration menu function for a JavaScript function, the library is opened in a different editor than the standard JavaScript editor. Its also opened as Read-Only. Is there a way to configure this so that I can open the declaration of a function and modify it within the standard JavaScript editor?
Arin
Re: Open Declaration editor settings [message #541881 is a reply to message #540568] Tue, 22 June 2010 17:50 Go to previous messageGo to next message
I don't think this occurs in Helios. I've tried on a few files, and it always seems to open the actual source file when I open the declaration. Can you let us know if you're still seeing it in Helios?
Re: Open Declaration editor settings [message #542011 is a reply to message #540568] Wed, 23 June 2010 10:15 Go to previous messageGo to next message
I tested in Helios and this is working. I had to recreate my project as a JavaScript project (not a Static Web Project) and then it worked.
Arin
Re: Open Declaration editor settings [message #542029 is a reply to message #540568] Wed, 23 June 2010 11:03 Go to previous message
Ok. Found an interesting issue. I had to install Eclipse Classic, and then installed the WTP package ontop, and now, there is no context menu enter for 'Open Selection.' Pressing F3 does open the selection function, in the proper editor, and the Navigate menu contains the entry, but its not on the context menu.
Arin
Previous Topic:fcrec files in org.eclipse.wst.javascript.ui
Next Topic:Open Declaration/Selection (F3) Doesn't Work on JSPs
Current Time: Fri Jul 25 23:08:27 EDT 2025
Powered by FUDForum. Page generated in 0.06901 seconds
