Home » Eclipse Projects » Eclipse 4 » When are my (injected) POJO methods called?(dependency injection)
icon5.gif  When are my (injected) POJO methods called? [message #540492] Wed, 16 June 2010 07:50 Go to next message
Hello Everyone,
I am trying to write an RCP where I need to get the shell of the main application window AFTER it has been created. In 3.x I would override the WorkbenchWindowAdvisor .postWindowCreate() method, but as far as I could tell this is not used in e4.
I tried to write a class (which is not a part, since all parts already have been created and should be children of the shell I get from shellProvider....) like this:
public class MyClass {
@Inject
private IShellProvider shellProvider;
@PostConstruct
private Object myMethod() {
System.out.println("Do something using the shell! ");
return shellProvider.getShell();
but myMethod() does not get called. I also tried to use @Execute and @CanExecute but they don´t help. (Is there a good page that explains exactly what these annotations do, btw?)
Do I need to register MyClass through en extension point? Which one, and with what attributes?
I am using e4 M6.
Karin
Re: When are my (injected) POJO methods called? [message #540494 is a reply to message #540492] Wed, 16 June 2010 08:03 Go to previous messageGo to next message
1- how are you creating your "MyClass" object ?
If you are creating your object like this : new MyClass()
It won't work, because "the dependency injection engine won't be called". The @Inject means that the dependency injection engine should do the job so you should try :
IEclipseContext context = EclipseContextFactory.create();
MyClass myClass = ContextInjectionFactory.make(MyClass.class,context);
This time all your @Inject annotations should work. When the platform is creating your object (in the case of a part for example) I'm sure it's done this way.
2- Execute and CanExecute are annotations for Handlers only. For example, a "SaveHandler" class which save the content of the current active part could look like this :
@CanExecute
boolean canExecute(@Named(IServiceConstants.ACTIVE_PART) MPart part) {
return part.isDirty();
@Execute
void execute(EPartService partService, @Named(IServiceConstants.ACTIVE_PART) MPart part) {
partService.savePart(part, false);
Re: When are my (injected) POJO methods called? [message #540496 is a reply to message #540492] Wed, 16 June 2010 08:03 Go to previous messageGo to next message
I'm not sure what you are trying to do. What are you trying to display
when the window is opened? Do you contribute a Part? Do you open another
Window with informations?
e4 doesn't use extension points in the 3.x sense to contribute parts
(Views/Editors) but uses Model-Fragments to contribute to the
application which is backing the whole e4-Application-Instance.
My current guess is that you want to contribute to the addon-Feature of
the application model but I'm not sure yet.
Beside that: We've reworked the contribution system which was available
in M6 and you should use the latest I-Build.
Tom
Am 16.06.10 13:50, schrieb karins.spam@gmail.com:
> Hello Everyone,
> @Inject
> @PostConstruct
> I am using e4 M6.
> Karin
Re: When are my (injected) POJO methods called? [message #540521 is a reply to message #540492] Wed, 16 June 2010 08:52 Go to previous messageGo to next message
AFAIK you have 2 choices ... provide a class that will be called as part
of the model lifecycle, or listen for the SET event on
org.eclipse.e4.ui.workbench.UIEvents.UIElement.WIDGET
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: When are my (injected) POJO methods called? [message #540712 is a reply to message #540496] Thu, 17 June 2010 03:18 Go to previous messageGo to next message
Thanks for your answers. I guess I should explain my question better.
In eclipse 3.x I would have used the org.eclipse.core.runtime.applications extenstion point to register an Application class:
public class Application implements IApplication {
public Object start(IApplicationContext context) {
PlatformUI.createAndRunWorkbench(display, new ApplicationWorkbenchAdvisor());
And then define the ApplicationWorkbenchAdvisor, ApplicationWorkbenchWindowAdvisor classes as follows:
public class ApplicationWorkbenchAdvisor extends WorkbenchAdvisor {
public WorkbenchWindowAdvisor createWorkbenchWindowAdvisor(
IWorkbenchWindowConfigurer configurer) {
return new ApplicationWorkbenchWindowAdvisor(configurer);
public class ApplicationWorkbenchWindowAdvisor extends WorkbenchWindowAdvisor {
public void postWindowCreate() {
// Do what I want
In the postWindowCreate Method I could then do what I want. But how do I get to this point in the application lifecycle in eclipse e4?
(I have already defined my own renderers and registered parts using Application.e4.xmi and components.xmi, so the window exists. The application runs fine as it is - the window is created and displayed as it should. But I would prefer if I could do something else to it before it is displayed. In the renderer code it is too early 'cause ALL widgets have not been created yet... )
Many thanks,
Karin
Re: When are my (injected) POJO methods called? [message #540812 is a reply to message #540712] Thu, 17 June 2010 08:10 Go to previous messageGo to next message
You still didn't answer what you are trying to do in the "postWindowCreate".
I guess the main problem is that you are not able to plug yourself into
the EventBus without doing a contribution.
I guess the Application#addons could be used for this because they allow
you to register Contribution who are not creating UI-Structures.
You can take a look at the workbench.addons.swt who do exactly this kind
of thing to implement e.g. DnD, ... .
Tom
Am 17.06.10 09:18, schrieb karins.spam@gmail.com:
> Application class:
> @Override
> // Do what I want
> Many thanks,
> Karin
Re: When are my (injected) POJO methods called? [message #543077 is a reply to message #540812] Mon, 28 June 2010 07:03 Go to previous messageGo to next message
Hi Tom,
I am trying to do a similar thing and have problems with the Event bus:
I have a view that is created normally. I wrote this view so I can reuse the part by basically creating a new Instance of that view and using a different composite to be injected. This works so far.
I have the IEclipseContext injected to my second view and have The Factory create the first. It automatically injects the right composite into my first view so now both views are in the same view. (I hope this is understandable) Smile
Now view No. 1 subscribes to an event topic and if it is created by Eclipse at startup (it is registered with the application.e4xmi) then the events are send correctly to that view.
However, in my second view, where I added View No 1 manually, the events aren't beeing send to.
I looked into the bundle you suggested (workbench.addons.swt) and saw that you are having the EventBroker injected and manually register for Event Topics.
However my viewclass is not an instance of the EventHandler.
So my question is:
How to manually create a view, that gets events that are registered with the @EventTopic annotation?
Kind regards,
Artur
Re: When are my (injected) POJO methods called? [message #543194 is a reply to message #543077] Mon, 28 June 2010 12:24 Go to previous messageGo to next message
If I get you correct you are creating the instance your own which won't
work. You need to create your objects through DI
(ContextContributionFactory) but I've not used the event system my own
so I could be wrong.
Tom
Am 28.06.10 13:03, schrieb Artur Kronenberg:
> Hi Tom,
> is understandable) :)
> Event Topics.
> So my question is:
> Kind regards,
> Artur
Re: When are my (injected) POJO methods called? [message #543237 is a reply to message #543194] Mon, 28 June 2010 14:39 Go to previous messageGo to next message
Do you mean the ContextInjectionFactory? - Cause I can not find the ContextContributionFactory.
However, ContextInjectionFactory doesn't work in my case.
It injects all the values I need and my class get constructed the right way, but the methods that are supposed to listen to the eventbus using the @EventTopic annotation don't get registered with the EventBroker it seems.
This method isn't called after the initial injection anymore.
Tom Schindl wrote on Mon, 28 June 2010 12:24
Tom
Re: When are my (injected) POJO methods called? [message #543252 is a reply to message #543237] Mon, 28 June 2010 15:32 Go to previous messageGo to next message
Am 28.06.10 20:39, schrieb Artur Kronenberg:
Sure yes. Looking at the addon code it does exactly this (well it goes
through the reflection-factory which internally simply uses the
ContextInjectionFactory)
Tom
Re: When are my (injected) POJO methods called? [message #543548 is a reply to message #543252] Tue, 29 June 2010 14:02 Go to previous messageGo to next message
Tom Schindl wrote on Mon, 28 June 2010 15:32
Tom
Hey,
yep that was what I used. Injection is working, but the Annotations that are suppose to listen for the EventBus aren't called.
I was wondering if there was something else I have to do to maybe manually my annotations to the EventBus.
Sincerely,
-- artur
Re: When are my (injected) POJO methods called? [message #543561 is a reply to message #543548] Tue, 29 June 2010 14:48 Go to previous messageGo to next message
See InjectionEventTest in the "org.eclipse.e4.core.tests" bundles. One thing
to check is to make sure that the "org.eclipse.equinox.event" bundle is
started. (See InjectionEventTest#ensureEventAdminStarted())
Sincerely,
Oleg Besedin
"Artur Kronenberg" <addur737@yahoo.de> wrote in message
news:i0dcf1$qs$1@build.eclipse.org...
>> Tom
> Hey,
> Sincerely,
> -- artur
Re: When are my (injected) POJO methods called? [message #543666 is a reply to message #543561] Wed, 30 June 2010 05:01 Go to previous messageGo to next message
Also, that annotation is defined in org.eclipse.e4.core.di.extensions
(using declarative services), so you have to make sure this bundle and
equinox.ds / equinox.util are in your launch configuration (equinox.ds
must be @start with a runlevel lower than the default).
HTH,
Simon
Re: When are my (injected) POJO methods called? [message #547675 is a reply to message #543666] Mon, 19 July 2010 06:41 Go to previous messageGo to next message
I had a little more time to dig into the problem and the equinox (both util and event) are started. That still didn't solve my problem.
However there is an exception to my problem.
Currently I am using a stack view with two viewparts in it. Viewpart B uses ViewPart A within and I am creating it like that:
(This is create control from viewPart B):
  @Inject
  public void createControl( final Composite parent ) {
    Composite main = new Composite( parent, SWT.NONE );
    main.setLayout( new FormLayout() );
    canvas = new Canvas( main, SWT.BORDER | SWT.DOUBLE_BUFFERED);
    FormData data = new FormData( COMPASS_RADIUS, COMPASS_RADIUS );
    data.left = new FormAttachment( 0, 10 );
    data.top = new FormAttachment( 0, 10 );
    canvas.setLayoutData( data );
    canvas.addPaintListener( this );
    //Inserting the allready existing Robotview into this view to show additional information
    //Need to create class like that to let Eclipse Injection now where to inject values
    RobotView robotView = ContextInjectionFactory.make( RobotView.class, context );
As you can see the ContextInjectionFactory is used to create the seconds half of my view. The right composite gets injected in the RobotView so judging by the layout everything is fine (maybe at this point someone can explain to me how the InjectionFactory knows what composite to inject at what point - because I was expecting that the wrong Composite would have been injected there).
Now if I close my app and reopen it AND the ViewB was selected, so it's the one that is visible from the very beginning then everything works and the events in the injected RobotView that I created using the Factory get updated.
If however ViewA is visible and I switch tabs to ViewB in my stack the events don't get updated. However the initial event get injected ONCE when the Factory calls make and the Class gets created the first time.
It seems like the eventBus and and the Injection machanisms miss my created RobotView when I create it through the Factory.
I am sorry for the redundant information - I reread my earlier posts and realized that I did not really make myself too clear there. If there is any additional information needed I can provide it.
Sincerely,
Artur
Re: When are my (injected) POJO methods called? [message #547684 is a reply to message #547675] Mon, 19 July 2010 07:00 Go to previous messageGo to next message
Ideally you'd provide us a runnable snippet we can use to reproduce. If
you manage to get such a bundle, file a bugzilla so that we can take a look.
Am 19.07.10 12:41, schrieb Artur Kronenberg:
> @Inject
> to inject values
> context );
Where's the context variable defined? It it is declared by
--------8<--------
@Inject
private IEclipseContext content;
--------8<--------
Then what you'll get as the Composite is the same you get in
--------8<--------
@Inject
--------8<--------
All in all I really have problems understanding what you are doing. Why
does ViewPartA use ViewPartB?
So please file a bug and provide a runnable example.
> Sincerely,
> Artur
Re: When are my (injected) POJO methods called? [message #556235 is a reply to message #540492] Tue, 31 August 2010 08:26 Go to previous messageGo to next message
I have another questions concerning this topic. As you told, DI is only executed when the DI engine is called.
But when is the DI engine called? Only for classes that are defined within an e4 Application Model?
In my case, I have a Navigator View using the Common Navigation Framework, where I have to specify a custom ContentProvider. Within this ContentProvider, I need a service that I have declared within another plugin. But the instance of the ContentProvider is created by the Extension Registry. So the service is not injected. I can call the DI engine by myself by invoking
final IEclipseContext ctx = EclipseContextFactory.getServiceContext( FrameworkUtil.getBundle( getClass() ).getBundleContext() );
ContextInjectionFactory.inject( this, ctx );
But this context does not know any org.eclipse.e4.core.services.log.Logger, so I get the error when I do not declare this injected value as optional.
In summary, it is not possible to use DI for the whole application, right?
Re: When are my (injected) POJO methods called? [message #557665 is a reply to message #556235] Wed, 08 September 2010 08:25 Go to previous message
right, if you use this context you will simply have access to OSGi.
Ideally (presuming you want to expose e4 to your 3.x APIs) you would
track down your MPart so you could use that IEclipseContext. Other
parts of the model that could be used is your MWindow, or even the
MApplication (although you're responsible for managing your lifecycle,
since you don't want it to span the entire application).
PW
Paul Webster
Re: When are my (injected) POJO methods called? [message #577795 is a reply to message #540492] Wed, 16 June 2010 08:03 Go to previous message
@CanExecute
@Execute
Stephane Begaudeau @ Obeo
Re: When are my (injected) POJO methods called? [message #577807 is a reply to message #540492] Wed, 16 June 2010 08:03 Go to previous message
Tom
> Hello Everyone,
> @Inject
> @PostConstruct
> I am using e4 M6.
> Karin
Re: When are my (injected) POJO methods called? [message #577858 is a reply to message #540492] Wed, 16 June 2010 08:52 Go to previous message
PW
Paul Webster
Re: When are my (injected) POJO methods called? [message #577894 is a reply to message #540496] Thu, 17 June 2010 03:18 Go to previous message
// Do what I want
Many thanks,
Karin
Re: When are my (injected) POJO methods called? [message #577922 is a reply to message #540712] Thu, 17 June 2010 08:10 Go to previous message
Tom
> Application class:
> @Override
> // Do what I want
> Many thanks,
> Karin
Re: When are my (injected) POJO methods called? [message #578182 is a reply to message #540812] Mon, 28 June 2010 07:03 Go to previous message
Hi Tom,
I have the IEclipseContext injected to my second view and have The Factory create the first. It automatically injects the right composite into my first view so now both views are in the same view. (I hope this is understandable) :)
So my question is:
Kind regards,
Artur
Re: When are my (injected) POJO methods called? [message #578201 is a reply to message #578182] Mon, 28 June 2010 12:24 Go to previous message
Tom
> Hi Tom,
> Event Topics.
> So my question is:
> Kind regards,
> Artur
Re: When are my (injected) POJO methods called? [message #578225 is a reply to message #543194] Mon, 28 June 2010 14:39 Go to previous message
> Tom
Re: When are my (injected) POJO methods called? [message #578246 is a reply to message #543237] Mon, 28 June 2010 15:32 Go to previous message
Tom
Re: When are my (injected) POJO methods called? [message #578274 is a reply to message #543252] Tue, 29 June 2010 14:02 Go to previous message
> Tom
Hey,
Sincerely,
-- artur
Re: When are my (injected) POJO methods called? [message #578286 is a reply to message #543548] Tue, 29 June 2010 14:48 Go to previous message
Sincerely,
Oleg Besedin
>> Tom
> Hey,
> Sincerely,
> -- artur
Re: When are my (injected) POJO methods called? [message #578320 is a reply to message #543561] Wed, 30 June 2010 05:01 Go to previous message
HTH,
Simon
Re: When are my (injected) POJO methods called? [message #578854 is a reply to message #543666] Mon, 19 July 2010 06:41 Go to previous message
@Inject
Sincerely,
Artur
Re: When are my (injected) POJO methods called? [message #578863 is a reply to message #578854] Mon, 19 July 2010 07:00 Go to previous message
> @Inject
> to inject values
> context );
--------8<--------
@Inject
--------8<--------
--------8<--------
@Inject
--------8<--------
> Sincerely,
> Artur
Re: When are my (injected) POJO methods called? [message #581350 is a reply to message #540492] Tue, 31 August 2010 08:26 Go to previous message
Re: When are my (injected) POJO methods called? [message #581452 is a reply to message #581350] Wed, 08 September 2010 08:25 Go to previous message
PW
Paul Webster
Previous Topic:XWT + lazy content provider
Next Topic:Workbench Save Restore
Current Time: Wed Jul 23 20:32:49 EDT 2025
Powered by FUDForum. Page generated in 0.18628 seconds
