Home » Modeling » GMF (Graphical Modeling Framework) » Link constraints aren't evaluated for non-model figures
Link constraints aren't evaluated for non-model figures [message #540488] Wed, 16 June 2010 07:11 Go to next message
can anyone tell me how I can hook into higher level link ReorientCommand?
The following steps lead to an invalid state on about every diagram:
1) draw two figures of your model and a connection between them
2) from the diagram's context menu choose Add | Note
3) drag your connection's source or target (doesn't matter) to the "Note" figure
4) try to drag it back, it won't work
If you specify link constraints in gmfmap, they are not evaluated when reorienting to "Note" figures. If you set a break point in generated XXXReorientCommand's canReorientSource() or canReorientTarget() you'll find, these are never called when reorienting to "Note" figures.
In fact, this "bug" (is it one?) applies to any figure from the "Add" context menu.
So my question is: How can I prevent connection endpoints from being attached to such ("Note") figures at all?
At least I managed to being able to reattach them to my model elements by changing two methods in XXXReorientCommand(). But that's no good solution as users still can drag connection somewhere they're not supposed to.
Cheers
Rob
Re: Link constraints aren't evaluated for non-model figures [message #1009665 is a reply to message #540488] Fri, 15 February 2013 08:45 Go to previous messageGo to next message
Hello!
Are there any updates on this?
I'm currently having the same issue.
Thanks!
Daniel
Re: Link constraints aren't evaluated for non-model figures [message #1009701 is a reply to message #1009665] Fri, 15 February 2013 09:50 Go to previous messageGo to next message
opened bug 400933 at bugzilla.
Ralph
Re: Link constraints aren't evaluated for non-model figures [message #1009709 is a reply to message #1009701] Fri, 15 February 2013 10:03 Go to previous message
Thank you very much!
I wasn't sure if this was still an issue.
Previous Topic:How to customize the appearance of an XML object
Next Topic:impl cannot be resolved or is not a field
Current Time: Wed Jul 23 09:27:03 EDT 2025
Powered by FUDForum. Page generated in 0.11208 seconds
