Home » Eclipse Projects » Remote Application Platform (RAP) » Setting vm-arugements or properties for a tomcat deploy(arguments or properties cannot be set for the deployed application)
Setting vm-arugements or properties for a tomcat deploy [message #540455] Wed, 16 June 2010 04:40 Go to next message
Hi!
I am trying to deploy my RAP application on a tomcat 6 webserver.
I followed the instructions of the RAP Online Help but I have still a problem with the properties.
The properties I put into vm-arguments in the Launch-Config when launching in Eclipse (e.g. com.xyz.abc.rmi.host=localhost)
cannot be found when I deploy it on the webserver. I already tried to add them to the launch.ini and also to the web.xml but nothing worked so far.
Does somebody know how to solve this issue?
Thanks in advance!
Re: Setting vm-arugements or properties for a tomcat deploy [message #540505 is a reply to message #540455] Wed, 16 June 2010 08:05 Go to previous messageGo to next message
Hi Kerstin,
you can pass the properties when starting tomcat (if you're on Linux,
look at /etc/default/tomcat).
Here are some alternatives:
http://www.velocityreviews.com/forums/t144344-tomcat-5-0-set ting-system-properties-for-an-application.html
Stefan.
Kerstin schrieb:
> Hi!
> problem with the properties. The properties I put into vm-arguments in
> far.
> Thanks in advance!
Re: Setting vm-arugements or properties for a tomcat deploy [message #540546 is a reply to message #540505] Wed, 16 June 2010 09:46 Go to previous messageGo to next message
Stefan Röck wrote on Wed, 16 June 2010 08:05
Hi Kerstin,
Stefan.
Hi Stefan, thanks for your advice.
I am not on linux and we also don´t want to use CATALINA_OPTS because more applications should run on that server.
Is there another opportunity for setting the properties so that they are accessible with System.getProperty()?
Using <env-entry> makes a lot of re-implementation necessary.
Re: Setting vm-arugements or properties for a tomcat deploy [message #540980 is a reply to message #540546] Thu, 17 June 2010 16:48 Go to previous messageGo to next message
Hi Kerstin,
you can add system properties in your web.xml like this:
<init-param>
<param-name>commandline</param-name>
<param-value>-Dyour.parameter=value</param-value>
</init-param>
HTH, Ralf
>> Hi Kerstin,
>> Regards,
>> Stefan.
Re: Setting vm-arugements or properties for a tomcat deploy [message #541061 is a reply to message #540980] Fri, 18 June 2010 04:12 Go to previous message
Thank you Ralf,
that´s exactly what I was looking for!!
Solved my problem Smile
Previous Topic:UICallback broken in RAP 1.3 ?
Next Topic:User-based workbench save
Current Time: Sun Jul 27 09:56:21 EDT 2025
Powered by FUDForum. Page generated in 0.04151 seconds
