problem with embedded jar [message #540295] |
Tue, 15 June 2010 10:40  |
I write a plugin A that has an import-package dependency.
The needed package comes from an other plugin B, which uses a third
embedded .jar C. C is referenced in the MANIFEST.MF of B using
Bundle-ClassPath: C.jar
My target platform is defined through a platform definition file and
references a galileo mirror containing B.
This way the eclipse-ide is not able to resolve the needed package. I
see B as entry in the Plug-in Dependencies of A, but there is also an
error: "The import org.eclipse... cannot be resolved".
My workaround is to import B as binary project into my workspace. Now
the package could be resolved. But I don't want to import all plugins
with embedded jars into the workspace.
Where is my mistake? Is there an other way to resolve such packages?
I tested it with 3.5.2 and 3.6.0.RC4
An example for this behavior is the org.eclipse.equinox.servletbridge
bundle.
Lars
Re: problem with embedded jar [message #540442 is a reply to message #540356] |
Wed, 16 June 2010 03:34  |
Hello Andrew,
On 15.06.2010 21:06, Andrew Niefer wrote:
> The problem is likely that the compiler doesn't support having nested jars
> on its classpath. At runtime OSGi will take care of the nested jar
> automatically, but at development time you need the nested jar extracted to
> disk.
> I don't think there is any better workaround than the one you have.
Thank you for the information.
Lars
Re: problem with embedded jar [message #606066 is a reply to message #540295] |
Tue, 15 June 2010 15:06  |
disk.
-Andrew
Lars Fischer wrote:
> Hello,
> bundle.
> Regards,
> Lars
Re: problem with embedded jar [message #606072 is a reply to message #540356] |
Hello Andrew,
> disk.
Lars
FUDForum. Page generated in 0.05094 seconds
