Home » Eclipse Projects » Rich Client Platform (RCP) » How to trim down application size?
How to trim down application size? [message #504052] |
Wed, 16 December 2009 17:55  |
Today I deployed for the first time my application.
It is far from complete, even though is not exactly trivial.
The size of the resulting directory (*excluding* the repository subdir) is well above 27MB.
It seems a bit steep for an application with one Perspective, two EditParts and one handful of ViewParts.
Am I linking in the whole universe or these numbers are normal?
How can I reduce (if possible at all) the size of this beast?
The heavyweights are, as expected, in the plugins subdir:
$ ls -lS
total 27521
-rw-r--r-- 1 mauro Administrators 5787493 Dec 16 22:15 com.ibm.icu_4.0.1.v20090822.jar
-rw-r--r-- 1 mauro Administrators 4070677 Dec 16 22:15 org.eclipse.ui.workbench_3.5.1.M20090826-0800a.jar
-rw-r--r-- 1 mauro Administrators 3003725 Dec 16 22:15 ag.ion.noa_2.2.1.jar
-rw-r--r-- 1 mauro Administrators 2256700 Dec 16 22:15 org.eclipse.swt.win32.win32.x86_3.5.1.v3555a.jar
-rw-r--r-- 1 mauro Administrators 2068344 Dec 16 22:15 org.eclipse.ui.ide_3.5.1.M20090826-0800.jar
-rw-r--r-- 1 mauro Administrators 1438886 Dec 16 22:15 it.condarelli.rcp.yw_1.0.0.200912162314.jar
-rw-r--r-- 1 mauro Administrators 1300581 Dec 16 22:15 org.apache.xerces_2.9.0.v200909240008.jar
-rw-r--r-- 1 mauro Administrators 1125860 Dec 16 22:15 org.eclipse.osgi_3.5.1.R35x_v20090827.jar
-rw-r--r-- 1 mauro Administrators 1057998 Dec 16 22:15 org.eclipse.jface_3.5.1.M20090826-0800.jar
-rw-r--r-- 1 mauro Administrators 970384 Dec 16 22:15 org.eclipse.jface.text_3.5.1.r351_v20090708-0800.jar
-rw-r--r-- 1 mauro Administrators 296330 Dec 16 22:15 org.eclipse.ui.forms_3.4.1.v20090714_35x.jar
-rw-r--r-- 1 mauro Administrators 292012 Dec 16 22:15 org.apache.xml.serializer_2.7.1.v200902170519.jar
-rw-r--r-- 1 mauro Administrators 283349 Dec 16 22:15 org.eclipse.core.databinding.observable_1.2.0.M20090902-0800.jar
-rw-r--r-- 1 mauro Administrators 263837 Dec 16 22:15 org.eclipse.jface.databinding_1.3.1.M20090826-0800.jar
-rw-r--r-- 1 mauro Administrators 245732 Dec 16 22:15 org.eclipse.text_3.5.0.v20090513-2000.jar
-rw-r--r-- 1 mauro Administrators 236808 Dec 16 22:15 javax.xml_1.3.4.v200902170245.jar
-rw-r--r-- 1 mauro Administrators 218339 Dec 16 22:15 org.eclipse.help_3.4.1.v20090805_35x.jar
-rw-r--r-- 1 mauro Administrators 203095 Dec 16 22:15 org.eclipse.core.databinding_1.2.0.M20090819-0800.jar
-rw-r--r-- 1 mauro Administrators 176643 Dec 16 22:15 org.eclipse.core.databinding.property_1.2.0.M20090819-0800.jar
My application is "it.condarelli.rcp.yw".
I tried searching, but I didn't find anything relevant.
OTOH several applications advertised as based on eclipse RCP have a much smaller footprint, so I suspect I'm doing something not quite right.
In particular the topmost item suggests I might be pulling in even Klingon and Sindarin codepages.
Thanks in Advance
Mauro
Re: How to trim down application size? [message #539799 is a reply to message #505910] |
Sun, 13 June 2010 08:44   |
On 05/01/2010 15.53, Paul Webster wrote:
> Are you using org.eclipse.ui.ide? If not, get rid of it (it contains
> mostly code to work with core.resources, which you haven't included).
> Are you using org.eclipse.help? And org.eclipse.text, that's the text
> editor support.
> As for com.ibm.icu, if you don't need the i18n support you can replace
> it with com.ibm.icu.base (a plugin listed on the
> http://download.eclipse.org/eclipse/downloads/drops/R-3.5.1- 200909170800/index.php
> page, for example).
> PW
I have an EMF model. Does it count as Resource?
I do *not* have a workspace, just I just open a model file in the filesystem.
I tried getting rid of help, but I got the error:
Cannot complete the install because one or more required items could not be found.
Software being installed: Writer Application 1.0.0 (it.condarelli.writer 1.0.0)
Missing requirement: Workbench 3.5.2.M20100113-0800 (org.eclipse.ui.workbench 3.5.2.M20100113-0800) requires 'bundle org.eclipse.help [3.2.0,4.0.0)' but it could not be found
Cannot satisfy dependency:
From: Writer Application 1.0.0 (it.condarelli.writer 1.0.0)
To: org.eclipse.ui.workbench [3.5.2.M20100113-0800]
Is there an "approved Way" to find out what can be deleted from dependencies?
The automated Writer.product->Dependencies->Add Required Plug-ins pulls in a lot of things obviously not needed.
Is there something better available?
TiA
Mauro
Re: How to trim down application size? [message #540159 is a reply to message #540102] |
Tue, 15 June 2010 03:48   |
>> filesystem.
> No, I'm just curious why you have org.eclipse.ui.ide in there. Remove it
> if you can, it's for providing workbench services that deal with
> IResources (the org.eclipse.core.resources plugin). That's for
> workspaces, which you don't have.
The culprit was usage of FileStoreEditorInput which is in
org.eclipse.ui.ide. (why????)
I wrote my own LocalEditorInput/LocalEditorInputFactory and I managed to
get rid of ide (almost).
> A quick glance through the original list and it looks like the only
> other thing you can do is to replace com.ibm.icu with com.ibm.icu.base
> (so it is significantly smaller).
My current dependencies for my plugin is:
it.condarelli.writer.model,
org.eclipse.core.runtime,
org.eclipse.ui,
org.eclipse.jface.databinding,
org.eclipse.emf.databinding,
org.eclipse.ui.forms,
org.eclipse.core.filesystem,
org.eclipse.core.databinding.property,
org.eclipse.jface.text,
org.eclipse.ui.editors,
org.eclipse.nebula.widgets.ganttchart
Unfortunately the dependencies for the whole product (trimmed down by
hand, the automated dependency generator produces a *much* larger set) is:
<plugin id="com.ibm.icu"/>
<plugin id="it.condarelli.writer.model"/>
<plugin id="org.eclipse.compare"/>
<plugin id="org.eclipse.compare.core"/>
<plugin id="org.eclipse.core.commands"/>
<plugin id="org.eclipse.core.contenttype"/>
<plugin id="org.eclipse.core.databinding"/>
<plugin id="org.eclipse.core.databinding.observable"/>
<plugin id="org.eclipse.core.databinding.property"/>
<plugin id="org.eclipse.core.expressions"/>
<plugin id="org.eclipse.core.filebuffers"/>
<plugin id="org.eclipse.core.filesystem"/>
<plugin id="org.eclipse.core.filesystem.win32.x86" fragment="true"/>
<plugin id="org.eclipse.core.jobs"/>
<plugin id="org.eclipse.core.resources"/>
<plugin id="org.eclipse.core.resources.compatibility" fragment="true"/>
<plugin id="org.eclipse.core.resources.win32.x86" fragment="true"/>
<plugin id="org.eclipse.core.runtime"/>
<plugin id="org.eclipse.core.runtime.compatibility.registry"
fragment="true"/>
<plugin id="org.eclipse.core.variables"/>
<plugin id="org.eclipse.ecf"/>
<plugin id="org.eclipse.ecf.filetransfer"/>
<plugin id="org.eclipse.ecf.identity"/>
<plugin id="org.eclipse.ecf.provider.filetransfer"/>
<plugin id="org.eclipse.ecf.provider.filetransfer.ssl" fragment="true"/>
<plugin id="org.eclipse.ecf.ssl" fragment="true"/>
<plugin id="org.eclipse.emf.common"/>
<plugin id="org.eclipse.emf.databinding"/>
<plugin id="org.eclipse.emf.ecore"/>
<plugin id="org.eclipse.emf.ecore.xmi"/>
<plugin id="org.eclipse.equinox.app"/>
<plugin id="org.eclipse.equinox.common"/>
<plugin id="org.eclipse.equinox.p2.artifact.repository"/>
<plugin id="org.eclipse.equinox.p2.core"/>
<plugin id="org.eclipse.equinox.p2.engine"/>
<plugin id="org.eclipse.equinox.p2.jarprocessor"/>
<plugin id="org.eclipse.equinox.p2.metadata"/>
<plugin id="org.eclipse.equinox.p2.metadata.repository"/>
<plugin id="org.eclipse.equinox.p2.repository"/>
<plugin id="org.eclipse.equinox.preferences"/>
<plugin id="org.eclipse.equinox.registry"/>
<plugin id="org.eclipse.equinox.security"/>
<plugin id="org.eclipse.equinox.security.win32.x86" fragment="true"/>
<plugin id="org.eclipse.help"/>
<plugin id="org.eclipse.jface"/>
<plugin id="org.eclipse.jface.databinding"/>
<plugin id="org.eclipse.jface.text"/>
<plugin id="org.eclipse.nebula.widgets.ganttchart"/>
<plugin id="org.eclipse.osgi"/>
<plugin id="org.eclipse.osgi.services"/>
<plugin id="org.eclipse.swt"/>
<plugin id="org.eclipse.swt.win32.win32.x86" fragment="true"/>
<plugin id="org.eclipse.text"/>
<plugin id="org.eclipse.ui"/>
<plugin id="org.eclipse.ui.editors"/>
<plugin id="org.eclipse.ui.forms"/>
<plugin id="org.eclipse.ui.ide"/>
<plugin id="org.eclipse.ui.views"/>
<plugin id="org.eclipse.ui.win32" fragment="true"/>
<plugin id="org.eclipse.ui.workbench"/>
<plugin id="org.eclipse.ui.workbench.texteditor"/>
<plugin id="Writer"/>
where org.eclipse.ui.ide is back with some strange friends
(org.eclipse.ecf.*).
Two questions:
Is there any way to trim down this beast? It seems to me a refactoring
of some classes (e.g.: FileStoreEditorInput) would be beneficial for all
of us wanting to use RCP "just" as an Application Framework.
You said I should "replace com.ibm.icu with com.ibm.icu.base", but I
didn't find a way to do that. Can You tell me how to achieve that?
Many Thanks.
Mauro
> You might be right, as long as you use org.eclipse.ui.workbench you
> can't get rid of help.
> Later,
> PW
Current Time: Sun Jul 27 02:22:04 EDT 2025
Powered by FUDForum. Page generated in 0.05394 seconds
