Home » Language IDEs » Java Development Tools (JDT) » NullPointerException at JavaCore.getOptions(JavaCore.java:1248)
NullPointerException at JavaCore.getOptions(JavaCore.java:1248) [message #54015] Tue, 10 June 2003 21:05 Go to next message
Originally posted by: dbexternal.comcast.net
Just started playing with the JDT Core, writing a real simple program to
parse an AST, and I'm getting a NullPointerException at
JavaCore.getOptions(JavaCore.java:1248).
I must be doing something wrong. Any help would be greatly appreciated....
My code goes down on the AST.parseCompilationUnit() operation:
if (args.length < 1) {
System.out.println("Usage: TestAST <JavaFile.java>");
System.exit(1);
String contents;
if ((contents = getSource(args[0])) == null)
System.exit(1);
CompilationUnit cu = AST.parseCompilationUnit(
contents.toCharArray() );
Thanks, Dennis
Re: NullPointerException at JavaCore.getOptions(JavaCore.java:1248) [message #54248 is a reply to message #54015] Wed, 11 June 2003 05:00 Go to previous messageGo to next message
Dennis,
Functionalities in JDT/Core can work only if the Platform is running. You
cannot invoke JDT/Core from a main(String[]) method. You will need to write
a plugin that requires org.eclipse.jdt.core.
Jerome
"Dennis" <dbexternal@comcast.net> wrote in message
news:bc5v9h$l6u$1@rogue.oti.com...
appreciated....
> public static void main(String[] args) {
> System.exit(1);
> String contents;
> System.exit(1);
> Thanks, Dennis
Re: NullPointerException at JavaCore.getOptions(JavaCore.java:1248) [message #54274 is a reply to message #54248] Wed, 11 June 2003 05:07 Go to previous messageGo to next message
Thanks Jerome, I heading down that path now. Having read the PlugIn
JavaDoc, I'm assuming I just need to extend PlugIn, but I wasn't sure how
to gain access to the plugin from a main(String[]) method?
Thanks, Dennis
Jerome Lanneluc wrote:
> Dennis,
> Jerome
> appreciated....
> > System.exit(1);
> > String contents;
> > System.exit(1);
> > Thanks, Dennis
Re: NullPointerException at JavaCore.getOptions(JavaCore.java:1248) [message #54512 is a reply to message #54274] Wed, 11 June 2003 09:20 Go to previous message
Just to clarify: a plugin cannot be invoked from a main(String[]) method.
You need to use the Platform launcher to launch the Eclipse Platform (see
org.eclipse.core.launcher.Main in startup.jar).
For further questions about plugin and the Eclipse Platform, you should ask
on the eclipse.platform newsgroup.
Jerome
news:bc6rh8$8mb$1@rogue.oti.com...
> Thanks, Dennis
> > Dennis,
You
write
> > Jerome
to
> > appreciated....
> > > System.exit(1);
> > > String contents;
> > > System.exit(1);
> > > Thanks, Dennis
Previous Topic:Q: Can JDT API be used headless?
Next Topic:Where can I find headless jdt.core sample code?
Current Time: Wed Nov 12 08:51:15 EST 2025
Powered by FUDForum. Page generated in 0.05192 seconds
