Home » Modeling » EMF » [Databinding] is grouping of children possible?
[Databinding] is grouping of children possible? [message #540076] |
Mon, 14 June 2010 15:14  |
I show my model in a TreeView.
I am using the known incantation:
public class WorldObservableProvider implements IObservableFactory {
private IEMFListProperty wMulti = EMFProperties.multiList(WorldPackage.Literals.WORLD__BOOK, WorldPackage.Literals.WORLD__ACTOR, WorldPackage.Literals.WORLD__LOCATION);
private IEMFListProperty bMulti = EMFProperties.multiList(WorldPackage.Literals.BOOK__CHAPTER, WorldPackage.Literals.BOOK__ACTOR, WorldPackage.Literals.BOOK__LOCATION, WorldPackage.Literals.BOOK__ITEM);
private IEMFListProperty cMulti = EMFProperties.multiList(WorldPackage.Literals.CHAPTER__SCENE , WorldPackage.Literals.CHAPTER__ACTOR);
public IObservable createObservable(Object target) {
if (target instanceof IObservableList) {
return (IObservable) target;
} else if (target instanceof World) {
return wMulti.observe(target);
} else if (target instanceof Book) {
return bMulti.observe(target);
} else if (target instanceof Chapter) {
return cMulti.observe(target);
return null;
This works ok, but puts all the childen (actually all the contents of the various ELists) side by side under the parent.
I would like to have, under the parent, a few nodes representing the whole ELists, opening those nodes I would like to see the content of the corresponding EList.
I.E.: instead of:
world
+-book1
+-book2
+-actor1
+-actor2
+-location1
+-location2
I want:
world
+-books
| +-book1
| +-book2
+-actors
| +-actor1
| +-actor2
+-locations
+-location1
+-location2
What is the right incantation to achieve that? (possibly without changing the model)
Thanks in Advance
Mauro
Re: [Databinding] is grouping of children possible? [message #540815 is a reply to message #540076] |
Thu, 17 June 2010 08:36   |
No takers?
I will rephrase completely:
I don't fully understand databinding and the javadoc code is not very
helpful.
I followed Tom Schindl's tutorial and that clarified a lot of things,
but seems just to scratch the surface of the subject.
As soon as I try to do something a bit different I feel lost.
Is there any other place where I can find in-depth info? (I already have
"Eclipse Rich Client Platform" (Second Edition) and "Professional
Eclipse 3 for Java Developers")
Current problem is:
How do I construct an observable composed by tree Objects?
These Object should represent three ELists, but I do not want them
flattened out, so I cannot use EMFProperties.multiList(...).
What should I use? EMFProperties.values? or IObservableSet? or something
else?
As said the real problem is I don't fully understand Properties and I
can't find the right place to learn.
Please Advise
Mauro
> @Override
> return null;
> I.E.: instead of:
> world
> +-book1
> +-book2
> +-actor1
> +-actor2
> +-location1
> +-location2
> I want:
> world
> +-books
> | +-book1
> | +-book2
> +-actors
> | +-actor1
> | +-actor2
> +-locations
> +-location1
> +-location2
> Thanks in Advance
> Mauro
Re: [Databinding] is grouping of children possible? [message #540834 is a reply to message #540815] |
Thu, 17 June 2010 09:02   |
I've implemented this in lately in my e4-Model-Editor where I'm adding
virtual elements within the TreeStructure.
Here is how it is done:
public class VirtualEntry {
private IObservableList list;
private String label;
public VirtualEntry(String label, IObservableList list) {
this.list = list;
this.label = label;
public IObservableList getList() {
return this.list;
public String getLabel() {
return this.label;
private class ObservableFactoryImpl implements IObservableFactory {
private IEMFListProperty wB =
EMFProperties.list(WorldPackage.Literals.WORLD__BOOK);
if( target instanceof IObservableList ) {
return target;
} else if( target instanceof World ) {
WritableList list = new WritableList();
list.add(new VirtualEntry("books",wB.observe(target)));
list.add(....)
} else if( target instanceof VirtualEntry ) {
return ((VirtualEntry)target).getList();
Now you tree has additional virtual sub structures :-) but there's still
something you need to adjust because VirtualEntry is not an EMF-Object
and when creating IObservableMap you'd fail with an exception.
So you need to adjust the observable-set you retrieve from the content
provider like this:
> final WritableSet clearedSet = new WritableSet();
> contentProvider.getKnownElements().addSetChangeListener(new ISetChangeListener() {
> public void handleSetChange(SetChangeEvent event) {
> for (Object o : event.diff.getAdditions()) {
> if (o instanceof EObject) {
> clearedSet.add(o);
> for (Object o : event.diff.getRemovals()) {
> clearedSet.remove(o);
And finally you need to adjust your LabelProvider to deal with the
VirtualEntry but i think this should be straight forward.
If you'd like to see the full implementation you can find it in e4-CVS
(e4/org.eclipse.e4.tools/bundles/org.eclipse.e4.tools.emf.ui ).
Tom
Am 17.06.10 14:36, schrieb Mauro Condarelli:
> No takers?
> helpful.
> Current problem is:
> else?
> Please Advise
> Mauro
>> @Override
>> return null;
>> I.E.: instead of:
>> world
>> +-book1
>> +-book2
>> +-actor1
>> +-actor2
>> +-location1
>> +-location2
>> I want:
>> world
>> +-books
>> | +-book1
>> | +-book2
>> +-actors
>> | +-actor1
>> | +-actor2
>> +-locations
>> +-location1
>> +-location2
>> changing the model)
>> Thanks in Advance
>> Mauro
Re: [Databinding] is grouping of children possible? [message #541269 is a reply to message #540834] |
Sat, 19 June 2010 04:43   |
On 17/06/2010 15.02, Tom Schindl wrote:
I am not sure I fully understand You, especially in the last part.
I mean: I understand the problem, but I do not understand Your solution (and blindly implementing it didn't work for me).
The following (sorry for the long listing, but I don't want to leave out something that could be relevant) works for me.
*ANY* comment would be welcome, especially on the usage of EObjectImpl for VirtualEntry. I suspect I could use the facilities built in it (eContainer, eProperties) to hold list, label and possibly other info.
Mauro
package it.condarelli.writer.editors;
import it.condarelli.writer.model.world.Actor;
import it.condarelli.writer.model.world.Book;
import it.condarelli.writer.model.world.Chapter;
import it.condarelli.writer.model.world.IBase;
import it.condarelli.writer.model.world.Item;
import it.condarelli.writer.model.world.Location;
import it.condarelli.writer.model.world.Scene;
import it.condarelli.writer.model.world.World;
import it.condarelli.writer.model.world.WorldPackage;
import it.condarelli.writer.model.world.WorldPackage.Literals;
import it.condarelli.writer.util.IconProvider;
import org.eclipse.core.databinding.observable.IObservable;
import org.eclipse.core.databinding.observable.list.IObservableList ;
import org.eclipse.core.databinding.observable.list.WritableList;
import org.eclipse.core.databinding.observable.map.IObservableMap;
import org.eclipse.core.databinding.observable.masterdetail.IObserv ableFactory;
import org.eclipse.core.databinding.observable.set.IObservableSet;
import org.eclipse.emf.databinding.EMFProperties;
import org.eclipse.emf.databinding.IEMFListProperty;
import org.eclipse.emf.ecore.impl.EObjectImpl;
import org.eclipse.jface.databinding.viewers.ObservableListTreeCont entProvider;
import org.eclipse.jface.databinding.viewers.ObservableMapLabelProv ider;
import org.eclipse.jface.databinding.viewers.TreeStructureAdvisor;
import org.eclipse.jface.viewers.IContentProvider;
import org.eclipse.jface.viewers.ILabelProvider;
import org.eclipse.swt.graphics.Image;
public class WorldObservableProvider2 implements IObservableFactory {
private ObservableMapLabelProvider omlp = null;
private ObservableListTreeContentProvider oltcp = null;
private TreeStructureAdvisor tsa = null;
private IObservableMap[] maps;
public WorldObservableProvider2() {
tsa = new TreeStructureAdvisor() {
public Object getParent(Object element) {
if (element instanceof World) {
return null;
} else if (element instanceof VirtualEntry) {
return null;
} else if (element instanceof Actor) {
return null;
} else if (element instanceof Book) {
return null;
} else if (element instanceof Chapter) {
return null;
} else if (element instanceof Location) {
return null;
} else if (element instanceof Item) {
return null;
} else if (element instanceof Scene) {
return null;
return null;
public Boolean hasChildren(Object element) {
return true;
return true;
return false;
return true;
return true;
return false;
return false;
return false;
return super.hasChildren(element);
oltcp = new ObservableListTreeContentProvider(this, tsa);
IObservableSet set = oltcp.getKnownElements();
maps = new IObservableMap[2];
maps[0] = EMFProperties.value(Literals.IBASE__TITLE).observeDetail(set );
maps[1] = EMFProperties.value(Literals.ACTOR__NAME).observeDetail(set) ;
omlp = new ObservableMapLabelProvider(maps) {
public Image getImage(Object element) {
return IconProvider.getIconSmall(element);
public String getColumnText(Object element, int columnIndex) {
if (columnIndex == 0) {
if (element instanceof IBase) {
Object o = maps[0].get(element);
return (o != null) ? o.toString() : "(null)";
return ((VirtualEntry) element).label;
Object o = maps[1].get(element);
return super.getColumnText(element, columnIndex);
public class VirtualEntry extends EObjectImpl {
this.list = list;
this.label = label;
return this.list;
return this.label;
IEMFListProperty wActor = EMFProperties.list(WorldPackage.Literals.WORLD__ACTOR);
IEMFListProperty wLocation = EMFProperties.list(WorldPackage.Literals.WORLD__LOCATION);
IEMFListProperty wBook = EMFProperties.list(WorldPackage.Literals.WORLD__BOOK);
IEMFListProperty bActor = EMFProperties.list(WorldPackage.Literals.BOOK__ACTOR);
IEMFListProperty bLocation = EMFProperties.list(WorldPackage.Literals.BOOK__LOCATION);
IEMFListProperty bItem = EMFProperties.list(WorldPackage.Literals.BOOK__ITEM);
IEMFListProperty bChapter = EMFProperties.list(WorldPackage.Literals.BOOK__CHAPTER);
IEMFListProperty cActor = EMFProperties.list(WorldPackage.Literals.CHAPTER__ACTOR);
IEMFListProperty cScene = EMFProperties.list(WorldPackage.Literals.CHAPTER__SCENE);
list.add(new VirtualEntry("books", wBook.observe(target)));
list.add(new VirtualEntry("actors", wActor.observe(target)));
list.add(new VirtualEntry("locations", wLocation.observe(target)));
return list;
list.add(new VirtualEntry("chapters", bChapter.observe(target)));
list.add(new VirtualEntry("actors", bActor.observe(target)));
list.add(new VirtualEntry("locations", bLocation.observe(target)));
list.add(new VirtualEntry("items", bItem.observe(target)));
return list;
list.add(new VirtualEntry("scenes", cScene.observe(target)));
list.add(new VirtualEntry("actors", cActor.observe(target)));
return list;
} else if (target instanceof VirtualEntry) {
return ((VirtualEntry) target).getList();
return null;
public ILabelProvider getLabelProvider() {
return omlp;
public IContentProvider getContentProvider() {
return oltcp;
> this.list = list;
> this.label = label;
> return this.list;
> return this.label;
> return target;
> list.add(....)
> provider like this:
>> clearedSet.add(o);
> Tom
>> No takers?
>> helpful.
>> Current problem is:
>> else?
>> Please Advise
>> Mauro
>>> @Override
>>> return null;
>>> I.E.: instead of:
>>> world
>>> +-book1
>>> +-book2
>>> +-actor1
>>> +-actor2
>>> +-location1
>>> +-location2
>>> I want:
>>> world
>>> +-books
>>> | +-book1
>>> | +-book2
>>> +-actors
>>> | +-actor1
>>> | +-actor2
>>> +-locations
>>> +-location1
>>> +-location2
>>> changing the model)
>>> Thanks in Advance
>>> Mauro
Re: [Databinding] is grouping of children possible? [message #541272 is a reply to message #541269] |
Sat, 19 June 2010 06:22   |
>> Hi,
UPDATE:
with this implementation the following code does not work anymore:
Scene s = c.getScene().get(idx);
tv.setSelection(new StructuredSelection(s), true);
or, to be more precise:
it works if and only if the target (Scene s) is visible in the
TreeViewer (tv) i.e.: if the Chapter (or some other parent) containing
this scene is not collapsed.
I tracked the error to internalFindItem() and further down to
getChildren() that returns zero children if the parent node is
collapsed. This uses some native code, so I'm stumped.
What am I doing wrong??
TiA
Mauro
> Thanks
> Mauro
> @Override
> return null;
> return null;
> return null;
> return null;
> return null;
> return null;
> return null;
> return null;
> return null;
> @Override
> return true;
> return true;
> return false;
> return true;
> return true;
> return false;
> return false;
> return false;
> @Override
> @Override
> this.list = list;
> this.label = label;
> return this.list;
> return this.label;
> @Override
> return list;
> return list;
> return list;
> return null;
> return omlp;
> return oltcp;
>> this.list = list;
>> this.label = label;
>> return this.list;
>> return this.label;
>> return target;
>> list.add(....)
>> provider like this:
>>> clearedSet.add(o);
>> Tom
>>> No takers?
>>> helpful.
>>> Current problem is:
>>> else?
>>> Please Advise
>>> Mauro
>>>> @Override
>>>> return null;
>>>> I.E.: instead of:
>>>> world
>>>> +-book1
>>>> +-book2
>>>> +-actor1
>>>> +-actor2
>>>> +-location1
>>>> +-location2
>>>> I want:
>>>> world
>>>> +-books
>>>> | +-book1
>>>> | +-book2
>>>> +-actors
>>>> | +-actor1
>>>> | +-actor2
>>>> +-locations
>>>> +-location1
>>>> +-location2
>>>> changing the model)
>>>> Thanks in Advance
>>>> Mauro
Re: [Databinding] is grouping of children possible? [message #541278 is a reply to message #541272] |
Sat, 19 June 2010 07:21   |
You need to use a TreeSelection if you want the system to expand the
parent-nodes.
Tom
Am 19.06.10 12:22, schrieb Mauro Condarelli:
>>> Hi,
> UPDATE:
> TiA
> Mauro
>> Thanks
>> Mauro
>> import
>> import
>> @Override
>> return null;
>> return null;
>> return null;
>> return null;
>> return null;
>> return null;
>> return null;
>> return null;
>> return null;
>> @Override
>> return true;
>> return true;
>> return false;
>> return true;
>> return true;
>> return false;
>> return false;
>> return false;
>> maps[0] =
>> maps[1] =
>> @Override
>> @Override
>> columnIndex) {
>> this.list = list;
>> this.label = label;
>> return this.list;
>> return this.label;
>> @Override
>> return list;
>> return list;
>> return list;
>> return null;
>> return omlp;
>> return oltcp;
>>> this.list = list;
>>> this.label = label;
>>> return this.list;
>>> return this.label;
>>> return target;
>>> list.add(....)
>>> provider like this:
>>>> clearedSet.add(o);
>>> Tom
>>>> No takers?
>>>> helpful.
>>>> have
>>>> Current problem is:
>>>> something
>>>> else?
>>>> Please Advise
>>>> Mauro
>>>>> @Override
>>>>> return null;
>>>>> I.E.: instead of:
>>>>> world
>>>>> +-book1
>>>>> +-book2
>>>>> +-actor1
>>>>> +-actor2
>>>>> +-location1
>>>>> +-location2
>>>>> I want:
>>>>> world
>>>>> +-books
>>>>> | +-book1
>>>>> | +-book2
>>>>> +-actors
>>>>> | +-actor1
>>>>> | +-actor2
>>>>> +-locations
>>>>> +-location1
>>>>> +-location2
>>>>> changing the model)
>>>>> Thanks in Advance
>>>>> Mauro
Re: [Databinding] is grouping of children possible? [message #541282 is a reply to message #541278] |
Sat, 19 June 2010 09:13   |
> parent-nodes.
> Tom
Uh?
This was working before the VirtualNode mod.
I will revert and check again.
Anyways: if I use TreeSelection I need to give a TreePath leading to my
Scene; is there an easy way to construct it?
TiA
Mauro
>>>> Hi,
>> UPDATE:
>> TiA
>> Mauro
Re: [Databinding] is grouping of children possible? [message #544594 is a reply to message #541269] |
Sun, 04 July 2010 12:12   |
In order to further improve the appearance of my master tree I did the following change (see below) and it works... almost.
>> Hi,
> Thanks
> Mauro
> @Override
> return null;
> return null;
> return null;
> return null;
> return null;
> return null;
> return null;
> return null;
> return null;
> @Override
> return true;
> return true;
> return false;
> return true;
> return true;
> return false;
> return false;
> return false;
> @Override
> @Override
> this.list = list;
> this.label = label;
> return this.list;
> return this.label;
> @Override
> return list;
> return list;
> return list;
> return null;
This becomes:
//list.add(new VirtualEntry("books", wBook.observe(target)));
list.add(new VirtualEntry("Actors", wActor.observe(target)));
list.add(new VirtualEntry("Places", wLocation.observe(target)));
list.addAll(wBook.observe(target));
return list;
//list.add(new VirtualEntry("chapters", bChapter.observe(target)));
list.add(new VirtualEntry("Actors", bActor.observe(target)));
list.add(new VirtualEntry("Places", bLocation.observe(target)));
list.add(new VirtualEntry("Items", bItem.observe(target)));
list.addAll(bChapter.observe(target));
return list;
//list.add(new VirtualEntry("scenes", cScene.observe(target)));
list.add(new VirtualEntry("Actors", cActor.observe(target)));
list.addAll(cScene.observe(target));
return list;
return null;
This SEEMS to work, but fails as soon as one of cScene, bChapter or wBook gets a new entry because the list is not updated.
How can I force the TreeViewer to completely rebuild the Observable list?
I tried using tViewer.update(), but that is not enough.
Thanks in Advance
Mauro
> return omlp;
> return oltcp;
>> this.list = list;
>> this.label = label;
>> return this.list;
>> return this.label;
>> return target;
>> list.add(....)
>> provider like this:
>>> clearedSet.add(o);
>> Tom
>>> No takers?
>>> helpful.
>>> Current problem is:
>>> else?
>>> Please Advise
>>> Mauro
>>>> @Override
>>>> return null;
>>>> I.E.: instead of:
>>>> world
>>>> +-book1
>>>> +-book2
>>>> +-actor1
>>>> +-actor2
>>>> +-location1
>>>> +-location2
>>>> I want:
>>>> world
>>>> +-books
>>>> | +-book1
>>>> | +-book2
>>>> +-actors
>>>> | +-actor1
>>>> | +-actor2
>>>> +-locations
>>>> +-location1
>>>> +-location2
>>>> changing the model)
>>>> Thanks in Advance
>>>> Mauro
Re: [Databinding] is grouping of children possible? [message #544699 is a reply to message #544603] |
Mon, 05 July 2010 05:50   |
> refresh() but I don't understand why the Tree is not updating itself in
> this case.
> The original code I've copied out the stuff is working and updating
> itself on structural changes perfectly.
> Tom
Hi Tom,
I was not clear enough.
You original code works perfectly.
I was trying to obtain something like this:
world
+-actors
| +-actor1
| +-actor2
+-locations
| +-location1
| +-location2
+-book1
| +-actors
| | +-actor11
| | +-actor12
| +-chapter11
| | +-actors
| | | +-actor111
| | +-scene111
| | +-scene112
| +-chapter12
| | +-actors
| | | +-actor121
| | | +-actor122
| | +-scene121
| | +-scene122
| +-chapter13
| | +-actors
| | +-scene131
| | +-scene132
| +-chapter14
| | +-actors
| | | +-actor141
| | +-scene141
| | +-scene142
+-book2
This means I would like to insert virtual nodes to group actors, location and items, but I do not want to group books chapters and scenes.
To obtain this I modified Your code this way:
remove-> //list.add(new VirtualEntry("scenes", cScene.observe(target)));
insert-> list.addAll(cScene.observe(target));
return list;
but, since list is not an observable it will *not* let the TreeViewer to follow the structural changes.
Your code works because the structure of the virtual node do not change.
Unfortunately doing a tView.refresh() does not solve the problem.
Is there some way to work around the problem?
TiA
Mauro
Re: [Databinding] is grouping of children possible? [message #544701 is a reply to message #544699] |
Mon, 05 July 2010 06:03   |
Am 05.07.10 11:50, schrieb Mauro Condarelli:
>> this case.
>> Tom
> Hi Tom,
> world
> +-actors
> | +-actor1
> | +-actor2
> +-locations
> | +-location1
> | +-location2
> +-book1
> | +-actors
> | | +-actor11
> | | +-actor12
> | +-chapter11
> | | +-actors
> | | | +-actor111
> | | +-scene111
> | | +-scene112
> | +-chapter12
> | | +-actors
> | | | +-actor121
> | | | +-actor122
> | | +-scene121
> | | +-scene122
> | +-chapter13
> | | +-actors
> | | +-scene131
> | | +-scene132
> | +-chapter14
> | | +-actors
> | | | +-actor141
> | | +-scene141
> | | +-scene142
> +-book2
> return list;
This is obviously not what you should do here. You need to create the
list and add a listener:
--------8<--------
final WritableList list = new WritableList();
IObservableList l = cScene.observe(target);
> final IListChangeListener listener = new IListChangeListener() {
> public void handleListChange(ListChangeEvent event) {
> if (! list.isDisposed()) {
> ListDiff diff = Diffs.computeListDiff(list, event.getObservableList());
> diff.applyTo(list);
l.addListChangeListener(listener);
--------8<--------
Tom
Re: [Databinding] is grouping of children possible? [message #544727 is a reply to message #544701] |
Mon, 05 July 2010 07:21   |
>>> this case.
>>> Tom
>> Hi Tom,
>> world
>> +-actors
>> | +-actor1
>> | +-actor2
>> +-locations
>> | +-location1
>> | +-location2
>> +-book1
>> | +-actors
>> | | +-actor11
>> | | +-actor12
>> | +-chapter11
>> | | +-actors
>> | | | +-actor111
>> | | +-scene111
>> | | +-scene112
>> | +-chapter12
>> | | +-actors
>> | | | +-actor121
>> | | | +-actor122
>> | | +-scene121
>> | | +-scene122
>> | +-chapter13
>> | | +-actors
>> | | +-scene131
>> | | +-scene132
>> | +-chapter14
>> | | +-actors
>> | | | +-actor141
>> | | +-scene141
>> | | +-scene142
>> +-book2
>> return list;
> --------8<--------
>> diff.applyTo(list);
> --------8<--------
> Tom
Thanks.
The following code seems to work right, but I didn't really test all cases.
It includes the virtual nodes that are not in Your example code.
Is this You meant?
Another little question: I *still* do not really understand databinding and thus I'm monkeying around with these sad results.
I already *did* read Your articles on the subject; is there any other source of information I can use? ... aside from pestering You on this list, I mean ;)
IObservableList l = wBook.observe(target);
if (!list.isDisposed()) {
diff.applyTo(list);
return list;
IObservableList l = bChapter.observe(target);
diff.applyTo(list);
return list;
diff.applyTo(list);
return list;
return null;
Regards (and many THANKS again!)
Mauro
Re: [Databinding] is grouping of children possible? [message #544986 is a reply to message #544858] |
Tue, 06 July 2010 05:26  |
> Well I was told the new RCP-book holds a chapter about databinding but I
> don't think this would have helped you here. There's a series of Lars
> Vogel about databinding but it's also not going into this detail level.
I can confirm: I have that book and it is very useful, but it just skims
on the surface of Databinding. That chapter gives just a 2000ft overview
of the subject. It's a good introduction but you can't really do
anything non-trivial with that information.
> I had to invent this virtual structure stuff my own when I faced the
> problem.
I see.
> Now that it looks like we found a somehow generic solution to bring in
> virtual nodes into the system we could start creating API for it, so
> that others won't have to struggle themselves :-)
From my (the user) point of view I would like this integrated in the
model itself: any EList property could have a "flatten" attribute.
Flatten="true" would be the current behavior where all children taken
out of their container and shown at the same level as non-list children.
Flatten="false" would insert a virtual node (or rather: inhibit the
flattening out of the container!) representing the EList itself.
This would obviously mean to modify the code-generation templates I know
nothing about, so I cannot tell how difficult it would be to implement
such a thing (or if it is feasible at all!).
I would be glad to help, if deemed useful, given my currently lacking
understanding of the whole matter.
Regards and Thanks
Mauro
Current Time: Fri Jul 18 21:00:12 EDT 2025
Powered by FUDForum. Page generated in 0.05685 seconds
