Home » Modeling » GMF (Graphical Modeling Framework) » Migration to GMF 2.3: issue with Editpolicy and move/reparent
Migration to GMF 2.3: issue with Editpolicy and move/reparent [message #536916] Mon, 31 May 2010 09:44 Go to next message
I'm trying to move from GMF 2.2 to GMF 2.3.
I encounter some issue with EditPolicy on move/reparent.
By now, I don't understand what it exactly happen... :s
Sometimes, the move/reparent (seems to) work(s) fine. But other times there are unexpected behavior:
- the EditPart is duplicated
- the Editpart is deleted
- sometimes it seems that only the refresh doesn't work.
- after a deletion of the child, sometimes the parent is filled with image of the child...
That is really weird. There is nothing in log. I don't know where to begin to search.
I noticed in the bug comment that there was modifcations in EditPolicy.
Is someone can explain in what consists these modifications more precisely?
Thanks by advance for any hints
Re: Migration to GMF 2.3: issue with Editpolicy and move/reparent [message #539942 is a reply to message #536916] Mon, 14 June 2010 07:08 Go to previous messageGo to next message
I'm looking closely to this issue and in fact on a reparent the old graphical definition is kept in diagram definition even if th enew one is created. Some changes are done in the model too and they work perfectly.
How the old graphic definition can be kept although the new one is correctly created?
Re: Migration to GMF 2.3: issue with Editpolicy and move/reparent [message #540007 is a reply to message #536916] Mon, 14 June 2010 11:00 Go to previous message
Ok I found a workaround.
There is a modification between 2.2 and 2.3 in template for CanonicalEditpolicy (diagram::editpolicies::ChildContainerCanonicalEditPolicy)
Now it overrides the refreshSemantic method from CanonicalEditPolicy class. I commented this method and all works fine for me.
By now, I don't know exactly why it doesn't work. So if someone have ideas on the question, his comments are welcome Smile
Previous Topic:Problems on using GMF generated Editor
Next Topic:how to make an element undeletable
Current Time: Mon Sep 22 23:32:43 EDT 2025
Powered by FUDForum. Page generated in 0.12906 seconds
