Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » JRuby debugging and debug gems
JRuby debugging and debug gems [message #536790] Sun, 30 May 2010 21:17 Go to next message
JRuby has a nice debug gem
(http://kenai.com/projects/jruby/pages/UsingTheJRubyDebugger) that is
used by intellij and netbeans for debug support in the IDE.
I'm looking to enhance dltk to use this debugger, and realized that dltk
uses a ruby based debugger that works with jruby as well (slow as hell,
but works).
Would the DLTK team be interested in using a standard gem that other
IDEs use for debugging instead of home grown debugging scripts?
Also is there any code I could look at to implement this kind of
functionality ?
Thanks!
-- Ketan
http://ketan.padegaonkar.name | http://eclipse.org/swtbot
Re: JRuby debugging and debug gems [message #539808 is a reply to message #536790] Sun, 13 June 2010 10:09 Go to previous message
Hi Ketan,
DLTK already uses that gem for ruby debugging, but it was not available for jruby when ruby debug was initially implemented.
That's why there is a test in org.eclipse.dltk.ruby.fastdebugger.FastDebuggerRunner.addEng ineConfig() to stop if running under jruby.
You can try to remove it and see if it works.
Probably it requires some changes for jruby and ruby 1.9 as well.
It would be great if you can help with it.
Thank you,
Alex
Previous Topic:[BUILD] S-2.0RC4-201006121203
Next Topic:jruby, gems and java autocompletes
Current Time: Sat Jul 26 08:42:18 EDT 2025
Powered by FUDForum. Page generated in 0.03874 seconds
