Home » Eclipse Projects » Eclipse 4 » XWT on Eclipse 3.5.2(AbstractDataProvider featuring observeList on Eclipse 3.5.2)
XWT on Eclipse 3.5.2 [message #539274] |
Thu, 10 June 2010 04:53  |
we are trying to create xwt files where properties are bound to an EMF model using a custom path grammar. For that, we attached an IDataProviderFactory implementation to XWT. But we soon found out that AbstractDataProvider in xwt 0.9 only provides support for observable values, while we would also need observable lists and sets/map.
Newer versions of xwt already have this, but we are bound on using Eclipse 3.5.2 and we could not assemble an xwt installation that is compatible with that.
Can anyone help, please?
Re: XWT on Eclipse 3.5.2 [message #539911 is a reply to message #539758] |
Mon, 14 June 2010 05:28  |
thank you for the answer.
I realize now that my description of the problem was incomplete: we want to provide xwt-editing to the customer, which means we have to incorporate the designer/editor. Unfortunately, the xwt designer in 1.0M6 requires several Eclipse 3.6.0 plugins, (e.g. org.eclipse.pde.ui;bundle-version="3.6.0", org.eclipse.jdt;bundle-version="3.6.0", a.o.); also, indirectly, via required wst plugins, it points to swt and jface from 3.6.0.
Therefore we tried to use the only available alternative to version 1.0M6, which is version 0.9. And here is where we discovered we do not have support for observable lists, master-detail, and other nice features of newer xwt versions.
I mention that we do not make use of the css support in xwt.
Perhaps there is an intermediate version that would fit our needs? If so, could you, please, provide a download link?Or what else would you recommed we do?
Thanks a lot for your time.
[Updated on: Mon, 14 June 2010 07:06] by Moderator
Re: XWT on Eclipse 3.5.2 [message #577582 is a reply to message #539274] |
Sat, 12 June 2010 12:27  |
From the point of the soruce codes, XWT should support 3.5.2. But we have
noticed some limitations with JFace data binding. Some properties are not
supported such as enabled of menu item.
Best regards
Yves YANG
"Tiziana Brinzas" <briziana@gmail.com> wrote in message
news:huq96e$ae6$1@build.eclipse.org...
> with that.
Re: XWT on Eclipse 3.5.2 [message #577635 is a reply to message #539758] |
Current Time: Sun Jul 27 13:59:38 EDT 2025
Powered by FUDForum. Page generated in 0.05170 seconds
