Home » Archived » Riena » TreeTableRidget: Bind model to modifiable value
TreeTableRidget: Bind model to modifiable value [message #538670] Tue, 08 June 2010 07:40 Go to next message
i need to bind a TreeTableRidget to a global modifiable value. So far changes on that value doesn't force a change in the TreeTable automatically. Only if reassign the binding after the value has changed, the TreeTable displays the new value.
Isn't there a way to bind the TreeTableRidget to an modifiable value like e.g. ITableRidget.bindToModel(IObservableList, ...)?
thanks, matthias
Re: TreeTableRidget: Bind model to modifiable value [message #538683 is a reply to message #538670] Tue, 08 June 2010 08:14 Go to previous messageGo to next message
Am 08.06.10 13:40, schrieb Matthias:
> thanks, matthias
In general in Riena changes in the model are only promoted to the widget either when you bind or by invoking the method
updateFromModel on the ridget. Its the same for all ridgets and its also true for the TreeTableRidget.
So when you finished updating the model, call updateFromModel on the ridget and that should be it.
christian
Re: TreeTableRidget: Bind model to modifiable value [message #538707 is a reply to message #538683] Tue, 08 June 2010 09:11 Go to previous messageGo to next message
then i did something wrong with the binding:
input = createInput();
tree.bindToModel(input, MyTreeNode.class, MyTreeNode.PROPERTY_CHILDREN, MyTreeNode.PROPERTY_PARENT, columnPropertyNames, columnHeaders);
The thing is that createInput() creates a new array of TreeNodes out of my model structure. And because this new array has another id, it can't be bound. Am i right?
Re: TreeTableRidget: Bind model to modifiable value [message #538877 is a reply to message #538707] Tue, 08 June 2010 17:01 Go to previous messageGo to next message
Hi Matthias,
I don't really understand your question... I think it would be best to post a standalone snippet showing your problem. Or at least an exception or error message.
Elias.
Re: TreeTableRidget: Bind model to modifiable value [message #538935 is a reply to message #538877] Wed, 09 June 2010 03:15 Go to previous messageGo to next message
ok, i extended the SnippetTreeTableRidget001
with the function
private WordNode[] createTreeInput2() {
	WordNode root = new WordNode("Words");
	WordNode aTowns = new WordNode(root, "Z");
	new WordNode(aTowns, "Zurich"); //$NON-NLS-1$
	return new WordNode[] { root };
and the possibility to update the model
Button button = new Button(shell, SWT.PUSH);
button.setText("Update Value");
IActionRidget actionRidget = (IActionRidget) SwtRidgetFactory.createRidget(button);
actionRidget.addListener(new IActionListener() {
	public void callback() {
		roots = createTreeInput2();
If i press the button, the TableTree doesn't change, even when i call updateFromModel() manually.
In my understanding it doesn't work since the model isn't modified but recreated.
I don't know how to update the model (Object[]) without recreating it.
I hope that was clear Wink
Re: TreeTableRidget: Bind model to modifiable value [message #539663 is a reply to message #538935] Fri, 11 June 2010 14:16 Go to previous messageGo to next message
Hi Matthias,
sorry, you can't to that this way... The ridget does not keep the array reference (bad style - breaks encapsulation) only the values in the array. So changing the array after you invoke bindToModel(...) has no effect.
You can either invoke r.bindToModel(...); r.updateFromModel() or better:
1. Invoke ridget.setRootsVisible(false)
2. The root you bind to should be a dummy node that returns the real roots as it's children
3. Change the values returned by the getChildren method of the root >> children are updated. No re-binding or update needed.
Hope this helps. If you need a snippet let me know.
Elias.
Re: TreeTableRidget: Bind model to modifiable value [message #539952 is a reply to message #539663] Mon, 14 June 2010 07:40 Go to previous message
Meanwhile i came to the same solution. I work with ExtendedTreeNodes which holds a reference to my value object. In a PropertyChangeListener i call:
public void propertyChange(PropertyChangeEvent evt) {
		updateRoot((ExtendedTreeNode) input[0]);
		tree.updateFromModel();
private void updateRoot(ExtendedTreeNode rootNode){
		MyVal mv = ValueManager.getInstance().getValue();
		rootNode.setReference(mv);
this works, thanks
Re: TreeTableRidget: Bind model to modifiable value [message #585739 is a reply to message #538683] Tue, 08 June 2010 09:11 Go to previous message
Re: TreeTableRidget: Bind model to modifiable value [message #585745 is a reply to message #538707] Tue, 08 June 2010 17:01 Go to previous message
Hi Matthias,
Elias.
Elias Volanakis | http://eclipsesource.com
elias (AT) eclipsesource.com | @evolanakis
Re: TreeTableRidget: Bind model to modifiable value [message #585753 is a reply to message #585745] Wed, 09 June 2010 03:15 Go to previous message
ok, i extended the http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.riena/o rg.eclipse.riena.sample.snippets/src/org/eclipse/riena/sampl e/snippets/SnippetTreeTableRidget001.java?root=RT_Project&am p;view=co
with the function
I hope that was clear ;)
Re: TreeTableRidget: Bind model to modifiable value [message #585808 is a reply to message #585753] Fri, 11 June 2010 14:16 Go to previous message
Hi Matthias,
Elias.
Re: TreeTableRidget: Bind model to modifiable value [message #585835 is a reply to message #585808] Mon, 14 June 2010 07:40 Go to previous message
this works, thanks
Previous Topic:Data Communication failes - sometimes
Next Topic:Possible problem on MacOSX Cocoa
Current Time: Fri Jul 18 13:50:50 EDT 2025
Powered by FUDForum. Page generated in 0.12041 seconds
