Re: SOS advise from EMF specialist [message #539382] |
Thu, 10 June 2010 11:00  |
--------------050607080507010004060506
Randi,
Yes, the UML2 project provides all you need. I've added its
newsgroup/forum to the"to" list of the reply. Have a look the
documentation first:
<http://wiki.eclipse.org/index.php/MDT-UML2>
Randi wrote:
> I need to read UML diagrams that are serialized into XMI. Is there any
> library that would allow me to conveniently read UML XMI - by
> conveniently I mean having some methods to iterate over
> classes/packages/methods/attributest etc. in model.
> I tried EMF, but I am unable to find any tutorial that would show how
> to import XMI containing UML and iterate through those elements.
> Where can I find more information about this ?
> Als I try to investigate the emfdiff from EMF compare ,and how I can
> iterate easily through those elements so I can write this eg in a
> textfile where I can gather the elements which are the
> deleted/modified /added
> Many thanks
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Randi,<br>
<br>
documentation first:<a href="http://wiki.eclipse.org/index.php/MDT-UML2"><br>
</a>
<blockquote><a href="http://wiki.eclipse.org/index.php/MDT-UML2">http://wiki.eclipse.org/index.php/MDT-UML2</a><br>
</blockquote>
<br>
Randi wrote:
<blockquote cite="mid:huqhh3$dsf$1@build.eclipse.org" type="cite">I
<br>
<br>
<br>
<br>
<br>
<br>
deleted/modified /added <br>
Many thanks
<br>
</blockquote>
</body>
</html>
--------------050607080507010004060506--
Re: SOS advise from EMF specialist [message #628510 is a reply to message #539382] |
Fri, 11 June 2010 09:27  |
Did you try to load your model inside the Eclipse Model Editor which is one of the MDT component.
If the model could loaded then it will work with any compatible tool, if not then you are in trouble and need transformation.
Good luck :roll:
FUDForum. Page generated in 1.19055 seconds
