Multi Editor [message #297713] |
Wed, 18 January 2006 13:15  |
Originally posted by: awm_abu.yahoo.com
Hey,
I am trying to create a MultiEditor and I am having some difficulties.
I created an editor extension in my plugin.xml and assoicated it with the
"multi" extension name.
However when I create Test.multi and try to open it I am getting the error
listed below.
It seems that it expects an IEditorInput of type MultiEditorInput.
The question is how do I give it such an input type ?
I could try to do this programmatically and in that way create the
MultiEditorInput
but that is not what I want.
Any help would be great.
Also I have not been able to find any good documentation on how to use a
MultiEditor so if anyone
could point me in the right direction it would be great.
Cheers.
!MESSAGE Unable to create editor ID Multi: An exception was thrown during
initialization
!STACK 0
java.lang.ClassCastException: org.eclipse.ui.part.FileEditorInput
at org.eclipse.ui.part.MultiEditor.init(MultiEditor.java:107)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:773)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:572)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:365)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
at
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:214)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2325)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2258)
at org.eclipse.ui.internal.WorkbenchPage.access$9(WorkbenchPage .java:2250)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2236)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2231)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2212)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:371)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:334)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:251)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:131)
at
org.eclipse.jdt.internal.ui.actions.OpenActionUtil.open(Open ActionUtil.java:49)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:16 9)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:15 3)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:222)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:198)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:296)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 4.open(PackageExplorerPart.java:869)
at
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:741)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
at
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:739)
at
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:968)
at
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1067)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:243)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:238)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:277)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
FUDForum. Page generated in 0.04581 seconds
