Home » Eclipse Projects » Rich Client Platform (RCP) » TreeViewer with TableLayout(Add an icon for each scond-level item and implement the logic of clicking it.)
TreeViewer with TableLayout [message #539549] Fri, 11 June 2010 05:20 Go to next message
Hi friends,
I created a TreeViewer with TableLayout. The business model just has 2 level hierarchy. And I do not display the root element. So, you just can see the second-level items and their leaves. Each element has attributes like name, path, label and so on which are displayed in the table cell. My new requirement is to add a delete icon for each second-level, putting it in the last place(or column if it is) . Then if user click I will remove this element and its children.
But I am not familiar with the UI part. I just know adding an icon is easy(getColumnImage() in the LabelProvider). But I do not know how to listener the user clicking event. Any suggestion is welcome and appreciated.
Ricky
Re: TreeViewer with TableLayout [message #539927 is a reply to message #539549] Mon, 14 June 2010 05:20 Go to previous messageGo to next message
On 11-06-2010 14:50, Ricky Ru wrote:
> Hi friends,
> appreciated.
> Ricky
You can track user clicks by adding a mouse listener to the tree viewer.
"treeViewer.getTree().addMouseListener(...)"
A better UI design will be provide the delete option inside a context
menu (rather than as an icon). Give the user the option to delete even
using the 'DEL' key. You can track selection changes using
"treeViewer.getTree().addSelectionListener(...)"
Re: TreeViewer with TableLayout [message #540702 is a reply to message #539927] Thu, 17 June 2010 02:47 Go to previous message
Thank you Madhu. Your suggestion is helpful for me.
Previous Topic:Start RCP Plugin without product
Next Topic:Two Masters in MasterDetails Page
Current Time: Fri Jul 25 07:01:41 EDT 2025
Powered by FUDForum. Page generated in 0.05906 seconds
