Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Drawing images on right side of TableItem(Problem with drawing images on the right side of TableItem inside a single column)
Drawing images on right side of TableItem [message #539241] Thu, 10 June 2010 03:19 Go to next message
I'm trying to draw images on the right side of text inside the TableItem (similarly as demonstrated in snippet
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet230.java?view=co),
but within just a single Table column, not within all the columns.
Is this possible to achieve? I think that this should be possible, but I couldn't find a way to do it.
Any help would be welcome, greetings,
Albert
Re: Drawing images on right side of TableItem [message #539261 is a reply to message #539241] Thu, 10 June 2010 04:25 Go to previous messageGo to next message
then simply check the event.index which marks the column of the cell you
are just painting.
Tom
Am 10.06.10 09:19, schrieb Albert:
> Albert
Re: Drawing images on right side of TableItem [message #539263 is a reply to message #539241] Thu, 10 June 2010 04:28 Go to previous messageGo to next message
use event.index as an if condition for each colum in paint code.
Re: Drawing images on right side of TableItem [message #539511 is a reply to message #539263] Fri, 11 June 2010 02:55 Go to previous message
Thank you all, using event.index solves the problem.
Albert
Previous Topic:Browser calls "completed(Event e)" of ProgressAdapter more than once
Next Topic:Browser calls "completed(Event e)" of ProgressAdapter more than once
Current Time: Sun Aug 31 12:59:09 EDT 2025
Powered by FUDForum. Page generated in 0.30544 seconds
