Home » Modeling » UML2 » Re: SOS advise from EMF specialist
Re: SOS advise from EMF specialist [message #539382] Thu, 10 June 2010 11:00 Go to next message
--------------050607080507010004060506
Randi,
Yes, the UML2 project provides all you need. I've added its
newsgroup/forum to the"to" list of the reply. Have a look the
documentation first:
<http://wiki.eclipse.org/index.php/MDT-UML2>
Randi wrote:
> I need to read UML diagrams that are serialized into XMI. Is there any
> library that would allow me to conveniently read UML XMI - by
> conveniently I mean having some methods to iterate over
> classes/packages/methods/attributest etc. in model.
> I tried EMF, but I am unable to find any tutorial that would show how
> to import XMI containing UML and iterate through those elements.
> Where can I find more information about this ?
> Als I try to investigate the emfdiff from EMF compare ,and how I can
> iterate easily through those elements so I can write this eg in a
> textfile where I can gather the elements which are the
> deleted/modified /added
> Many thanks
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Randi,<br>
<br>
documentation first:<a href="http://wiki.eclipse.org/index.php/MDT-UML2"><br>
</a>
<blockquote><a href="http://wiki.eclipse.org/index.php/MDT-UML2">http://wiki.eclipse.org/index.php/MDT-UML2</a><br>
</blockquote>
<br>
Randi wrote:
<blockquote cite="mid:huqhh3$dsf$1@build.eclipse.org" type="cite">I
<br>
<br>
<br>
<br>
<br>
<br>
deleted/modified /added <br>
Many thanks
<br>
</blockquote>
</body>
</html>
--------------050607080507010004060506--
Re: SOS advise from EMF specialist [message #539604 is a reply to message #539382] Fri, 11 June 2010 09:27 Go to previous messageGo to next message
Did you try to load your model inside the Eclipse Model Editor which is one of the MDT component.
If the model could be loaded then it will work with any compatible tool, if not then you are in trouble and need transformation.
Good luck Rolling Eyes
[Updated on: Fri, 11 June 2010 09:29] by Moderator
Re: SOS advise from EMF specialist [message #628510 is a reply to message #539382] Fri, 11 June 2010 09:27 Go to previous message
If the model could loaded then it will work with any compatible tool, if not then you are in trouble and need transformation.
Good luck :roll:
Previous Topic:Re: SOS advise from EMF specialist
Next Topic:UML profiles and MIWG Test Case 3
Current Time: Wed Jul 23 06:46:32 EDT 2025
Powered by FUDForum. Page generated in 0.26639 seconds
